- Sep 13, 2007
- 125,726
- 162,563
Wife and I did an Atlantis Submarine in Kona to around 100', that was really cool
We did it as well
What an unadulterated pile of crap! I read the whole thing and that POS doesnāt have a single X-box controller or grab handle from the discount bin at camping world. Who the fuck do they think they are fooling? Limiting factor my ass, should be called ālimited budgetā
Nobody seemed interested in my Bahamas thread, so I just let it go.
Iām 56ā¦. I still have a lot of living left in meI can't believe every comment is I would never...... I couldn't afford it but I would.
I would rather live to 50 then die at 100 having never lived.
Sounds like they found somethingDesperate Last-Ditch Attempt To Rescue Titanic Sub Begins
As time runs out for the passengers on the Titan submersible that went looking deep into the sea for wreckage of the Titanic, a last-ditch effort involving heavy machinery and submarines arrived in Newfoundland on Tuesday night. Three C-17 aircraft from the U.S. Air Force reportedly landed at a...www.dailywire.com
Not in that rickety ass thing, maybe James Cameron's or the one that @hallett21 postedI can't believe every comment is I would never...... I couldn't afford it but I would.
Can only hope. My guess is they are showing the world that they are doing anything possible to save these guys lives or at least bring the wreckage to the surfaceSounds like they found something
Sounds like they heard something and are staggering recovery equipment in case they find it. Notice I said ārecovery equipmentā and not ārescue equipmentā?Sounds like they found something
Some of the comments here have me scratching my head. Hopefully they come out of it alive. After watching some specials about the Kursk a month ago it settles in that they are in a shitty situation, something to not really make fun of. Just like the Kursk they set off on an adventure/event expecting to return to the surface... shit happened and some suffered for awhile before dying a painful, scary, and hopeless death.
Oh yeah, I completely agree it's gonna be a recoverySounds like they heard something and are staggering recovery equipment in case they find it. Notice I said ārecovery equipmentā and not ārescue equipmentā?
I hope we are wrong.Oh yeah, I completely agree it's gonna be a recovery
Me tooI hope we are wrong.
Civilian Space Travel worries me. I hope I'm long gone before I see that go down!Real bummer. This venture is no different than that of Musk & Bezos & Branson chasing flight into space. There will undoubtedly be tragedies and loss of life through the development of technologies for civilian space travel.
Probably didn't want to rely on carrying the necessary impact gun inside.....What happens if the battery died and they cant get out?Does anyone know why they bolt it from the outside? I would think you could achieve the same seal on the inside?
PressureDoes anyone know why they bolt it from the outside? I would think you could achieve the same seal on the inside?
To some it would be a big feather in their cap to say have been to Titanic. Similar to Everest.
Theyāre going at in the wrong direction.
Drag a couple lifting bags down there with the ROV, snatch it. Pull the pin and get the fuck out the way.
You sound like the guy on the Retrocabulator video.Lol
Well, we recently fished a $2 million BHA string out from 16,400ā. 7ā cased to 11,000ā, open hole (6 1/8ā) from 11,000ā to the top of fish.
String was differentially stick so we ran a free point log and shot it off, then went in with an overshot and hyd jars.
I would say this particular event and the work SpaceX has been doing isnāt in the the same conversation..Real bummer. This venture is no different than that of Musk & Bezos & Branson chasing flight into space. There will undoubtedly be tragedies and loss of life through the development of technologies for civilian space travel.
Because the joint has to resist pressure above 5,500 PSI at depth. The exterior of the titanium hatch is machined with bolt pads around the circumference, and there are threaded titanium inserts formed into the carbon fiber hull. The sealing surface looks to be at least five inches wide.Does anyone know why they bolt it from the outside? I would think you could achieve the same seal on the inside?
does the outside pressure not āwork with youā to maintain the seal?Because the joint has to resist pressure above 5,500 PSI at depth. The exterior of the titanium hatch is oversized with bolt pads around the circumference, and there are threaded titanium inserts formed into the carbon fiber hull.
There's no way the required clamping force could be accomplished using an internal fastening scheme.
Sure, but that pressure also wants to compromise the joint.Iām
There might not be one single cable that long but you could splice cables together.
Between two winches you could alternate winding them in while the other winch feeds out the last used cable. Coil the cable on the deck or throw it overboard as they come up.
Rolex uses a similar mechanism for the ring lock on the Deep Sea, methinks.Because the joint has to resist pressure above 5,500 PSI at depth. The exterior of the titanium hatch is machined with bolt pads around the circumference, and there are threaded titanium inserts formed into the carbon fiber hull. The sealing surface looks to be at least five inches wide.
This very well could be the flight MH370 of the ocean, it's been almost 10 years and we still don't know what happened to that plane and likely never will.I just hope that the mystery of the missing submersible gets solved.
It is highly likely that we will never know what happened. 20 years from now, they wonāt know any more than they know today.
Its an interesting mystery that I would like to know the final outcome of, sooner than later.
It sure would be interesting if the submersible is found in the future, sitting un-imploded, on the bottom, miles from the Titanic. Once the found submersible would be pulled back onto ship, we could then see what these guys wrote or did, once they knew it was all over. That would be an interesting conclusion.
I guess we should prepare for an "ocean research tax" to cover the cost of this shitshow.Sounds like they found something
Me and a co worker were just discussing this. I wouldn't watch but it would be interesting to know the human dynamics when 5 people know their fate.I just hope that the mystery of the missing submersible gets solved.
I'll try to remember to watch thatI watched a pretty good documentary on it, it pretty much looks like the pilots purposely crashed it.
They followed all the known flight data and the pilots purposely turned the plane the wrong direction then made the ATC calls for the hand-offs into other airspace, and purposely flew right along the demarcation lines between 2 or 3 international airspace bodies so that each of the sectors would assume they were being directed by the other ATCs.
Like the dude trying to launch himself in some home built rocket.I would say this particular event and the work SpaceX has been doing isnāt in the the same conversation..
Trial and Errorā¦. Learn thru mistakes. Rather be bold and take risks. Typically what spurs innovation and change.
Not to mention itās not like NASA didnāt kill a bunch of people in multiple incidents over the years.
I love that guy. Trolled flat earthers and got them to donate to his rocket. He was going āproveā the earth was flat.Like the dude trying to launch himself in some home built rocket.
or this idiotLike the dude trying to launch himself in some home built rocket.
No because lift bags are open on the bottom. The sub would have some kind of bladder to maintain neutral buoyancyHave to be some really strong bags. Imagine the expansion from 5000psi to ambient! Bags would get larger as they get shallower, and the sub would be accelerating towards the surface.
May be able to sell it as a 2 for 1, visit the Titanic, and become an astronaut all in one day!
Was thinking that as well, the ocean is a huge place. The technology to explore large areas does not yet exist........This very well could be the flight MH370 of the ocean, it's been almost 10 years and we still don't know what happened to that plane and likely never will.
I remember when he was on Tosh.0, funny shit... RIP Rocket dudeI love that guy. Trolled flat earthers and got them to donate to his rocket. He was going āproveā the earth was flat.
Hell of a final ride lol
Pretty sure the guy that died a year or two ago was a "flatearther" in a steam powered rocket. Think about that for a few moments...Like the dude trying to launch himself in some home built rocket.
The people alone are probably 1000 pounds.Absolutely..
If that Sub is currently intact how much would it weigh being pressurized and all?
