- Sep 13, 2007
- 127,076
- 167,710
good luck with the sale sounds like a cool car.
They are very cool
If I ever get a ride in your speed just don’t give me a headset because I’ll still talk shit about it the whole ride!They are very cool
I like the Speed logo on the sway bar link, little touches like that go a long way.
they have boots in baja right? sure its not uniqueNick is down a front boot in baja it looks like. View attachment 1261438
Dear lord. This is a challenge?? I've been over that exact same spot in our Ultra 4 and didn't give it a second thought.
The "hardcore" side by side folks sure are an interesting bunch.
Looked like they put an "overboot" over it and kept going.they have boots in baja right? sure its not unique
You’re right and It’s a bitch to sort through his editing and catch this stuff.
People have to remember his business is views and likes. The subject matter means nothing. The viewer is the product and somehow the viewers can’t recognize this.
Like @rivermobster said… a spotter… really lmao
The cv pulled out again 5 miles later so they pulled the front axle and used the outer stub to just continue in 2WD, Wes and Nick said the car had no other issues rest of trip.Looked like they put an "overboot" over it and kept going.
It's kinna hard to see but...
Is there even a circlip on the end of the splines? Why did that inboard joint pop out of the diff?
No way that should Ever happen!
Chew gots sum splain'n to to Lucy.
They said there is a cir clip at the end of the splines but it is very small and seems to have wore down so it wouldn’t hold the axle in place no more That’s why it was pulling out of the diff.Most the sxs I have had you can pull the axle out of the trans if the hub is off etc. They just slide in.
Should be a simple fixThey said there is a cir clip at the end of the splines but it is very small and seems to have wore down so it wouldn’t hold the axle in place no more That’s why it was pulling out of the diff.
Nope...
What you're looking at is a standard constant velocity axle design. Same Design they use in almost every front wheel drive car on the road.
If the axle isn't held in place Properly (by a retaining clip on the end of the splines at the differential end) you would see this exact scenario happening on every car out there, it would just fall apart! The axle ends (cages) Have to be held in place, so the center shaft can "float" as the suspension moves up and down, or the front wheels steer left and right. It's a design that's been around for decades.
If that clip broke for whatever reason, now it's floating around inside the diff/trans and the whole thing needs to come apart to remove the broken pieces.
This is a decent illustration of what I'm referring to...
So how would ya get to that clip to get the axles out?
This can’t possible be true Dave. Every sxs back to the rhinos has had a groove and cir clip at the end of the inner splines to retain the axle inside the diff. Rhinos, all RZRs, and X3s have been this way. They don’t just slide in or out, they require a good push or pull to release the clip.I’d be curious to see that. All the axles I’ve ever replaced in sxs they just slide in and out.
Here is a rzr axle (mine)I’d be curious to see that. All the axles I’ve ever replaced in sxs they just slide in and out.
I don’t wanna say I’m 100% sure but I know that the speed axles are different in the way they are installed and designed and patented as compared to your normal CV’s that are average out there. I believe they are using the same design that they had developed for the wildcat xx which is where these pictures are from. View attachment 1261795 View attachment 1261796 They have an adjustment screw that pushes on an inner pin that then pushes out the ring that retains it in place there used to be a video. I can’t find it but you can kind of see it in these pictures.
These are what Max has been racing with in the arctic cat for sometime and they are very easy to change in the field, although if that ring/circlip does wear down, it’s not gonna hold and you got to have another one to install.Interesting design.![]()
I believe this design is only on the rear axles. That’s how my XX is.I don’t wanna say I’m 100% sure but I know that the speed axles are different in the way they are installed and designed and patented as compared to your normal CV’s that are average out there. I believe they are using the same design that they had developed for the wildcat xx which is where these pictures are from. View attachment 1261795 View attachment 1261796 They have an adjustment screw that pushes on an inner pin that then pushes out the ring that retains it in place there used to be a video. I can’t find it but you can kind of see it in these pictures.
So how would ya get to that clip to get the axles out?I’d be curious to see that. All the axles I’ve ever replaced in sxs they just slide in and out.
So far I’m hoping that whenever I get my Diablo, I’m gonna buy a few extra those and a water temperature sensor as these seem to be the two little nuisance issues I have seen a few times.
I hope I’m not leading you all down the wrong path but I am pretty sure this is more in line with the reality than the videos and pictures that were posted above for the other brands and your typical 930 CVs, which are the most widely used.
FF to 4:20. And no I'm not joking on the time!
Well that's exactly the way I removed them.. LOL. Give it a yank and it slides out. I was thinking more like a c clip or something when you were typing earlier, and I was asking myself "how would ya get to it to remove the clip?"
See post #4218.I read on another forum that the axle popped out and would not stay in so they yanked it and he finished the trip in 2wd.
These sort of mechanical issues are the exact reason many of us, like myself, are waiting for a couple years for the real world, normal use issues to come up and be addressed. Saving a few thousand dollars to be the test mules isn't worth mine or my families recreational time. I want to jump in, throw in a cooler, some tools and go rip.All axles on a SXS have the circa clip or they will fall out. Polaris had this issue with the 2017 Turbo and also the Turbo S front axles pulling out due to issues with the circa clip.
Email about your car?@RiverDave I just received the same email as you did, got my call later today.
Look up one post.Email about your car?
just saw lolLook up one post.
Looks like I'm line with @RiverDave
I don't think they can actually deliver at the SSSS, they could probably do some sort of mock delivery.That's really cool. Looks like they are going to try and do Sand Sports show deliveries again this year. Really hope the cars get here in time. Would really be cool to see people getting their cars at the show.
