@BigRedBryan13
- Apr 20, 2024
- 99
- 413
The blown by twins boatWater looks good, pretty darn clear.
Boy that is shallow back there.
Which is the 660 boat?
Good times at the lake, I have a new respect for jets, got to go for a ride on a proven legit 660 boat. Holy fuck is all I have to say. Lol
I want this for my ring tone!!My brother just found this pass of me from 1998 on an old VHS tape.
Somehow he got out on the float in the middle of the hold rope at Lake Ming while I was on it.
Boat ran 8.00’s and right at 130.
Not bad for an all steel 427 on Alcohol.
Guess I’ll have to get it on a thumb drive!
So cool to have a memory like that on video, mine are only in my mind.My brother just found this pass of me from 1998 on an old VHS tape.
RIP Truitt.
Nicest man in boating.
Thanks for that second picture.
Never seen it.
The man was a storyteller.
Felt fortunate to hear them!
Great guy got close to him when I was restoring the K boat came out to Parker when we were there anybody remember that flat bottom bar he had in his den what a gentleman
Bryan Glidewell's boat, he's got that thing dialed in. Liquor Box driven by Mike Harrod on the same team also hauls the mail! Both are very cool guys to hang out withThe blown by twins boat
Been 141mph so far. Should be able to beat that this weekend.Great photo! Has anybody got an LS to run "really well" in a jetboat? I'm guessing yes.
There’s a few that are running very well. Guy out of Texas has a winger that runs in the 5s I believeGreat photo! Has anybody got an LS to run "really well" in a jetboat? I'm guessing yes.
What did you set the cavitation plate at?Couple other projects/work/family been taking time away from the Long Deck but making progress.
Here’s a shot of the “Honcho” strut brace as it gets closer to final routering and finish fit. All bolts will be flat head socket type when finished.
Stiffening plate now mounted under turnbuckle pads along with -12 pickups.
Clips for Vdrive countoured enough to go back in for engine line up. Need steering sprocket first so we can get that placed before putting Vdrive back in.
View attachment 1376503 View attachment 1376504 View attachment 1376505 View attachment 1376506
They are not set at this point as everything has to come apart for polish and anodize.What did you set the cavitation plate at?
Thanks! I really appreciate your help, I'll measure tomorrow, and jot down what you wrote for the next time I float her!They are not set at this point as everything has to come apart for polish and anodize.
The plate set up is typically different for a Biesemeyer bottomed boat vs a standard flatbottom.
I saw where you took the Kalawaiian out and wasn’t quite sure your plates were set right.
Typically the older flatbottoms have deeper propshaft angles, motors not far enough forward and “Ski” props on them so it takes a little work to get the boat to “set”.
I’d like to know…
How many inches from the transom to the back of the block
How many inches from the transom to the center of the vdrive plate(also what vdrive?)
What size prop?
There is other measurements that could help but those two will tell us alot.
As a base set up in your boat, I would…
Put the override handle in the full forward position.
Set the plates 1/4 of an inch up from flat.
Make sure your straight edge is at least 2 feet forward of the leading edge of the plates.
Easiest way to do it is to clamp 6inch piece of 1/4inch keystock to the bottom of the plate as you move across an bring the plates down to touch it with your straight edge flat to the bottom.
Then put your straight edge across the back of the plates to be sure they are straight across.
When that’s done…adjust the far right turnbuckle down 3/8 of an inch, so a 1/8 inch Down versus the bottom of the boat.
Then go to the next turnbuckle and turn it down to give the right corner an even gullwing to the outer edge.
Depending on the way the boat is set up, this should give you a good place to start.
If boat is too loose pull the handle back 2 clicks and see what happens.
Good luck.
PM me a phone number if ya wanna talk live.
Dave
Buckling up for a pass in “Jokers Wild” at Long Beach.Absolute Legend.
205.01 Oakland 1972… View attachment 1376321
Julian and Swabee, two of best ever in circles and drags…
Have had this picture on a wall since 1973… View attachment 1376323
Larry signed off on my IHBA PCE C/J license back in 1999! He was a great person to talk to! RIPBuckling up for a pass in “Jokers Wild” at Long Beach. View attachment 1377379
RIP Sir.
RIP...God Bless.RIP Sir.
I like it. Building things with mockups and jigs gives great results.
Thanks.I like it. Building things with mockups and jigs gives great results.
