Nordie
- Sep 5, 2009
- 7,876
- 12,309
Yes, it's like anywhere else, you need a pad cert. Florida is some of the strictest inspections I've ever had to deal with. It seems that the east coast you get away with a little more than the wast coast. This is all hear say, but I know what I've experienced. The inspector physically got on the roof and checked the nailing patter of the sheathing. For you carpenter types 4 on the seam and 8 in the field, after a top side inspection the inspector will crawl in the attic and check for shiners.
You should see the window installs, I had to buck every window into block, code is double ¼" tapcons @ 8" OC all the way around. We used 2 x 6's for the bucking.
The strapping to the slab and footings will carry up every stud and tie into the trusses, if it's the exterior the outside of most homes are CMU, all trusses are anchored into a tie beam via tapcons and nailed into the trusses.
Building on or near the beach you have to hold so much water underground, and it has to be directed to inlets that goto the intercoastal water way. The one place I worked on was designed to retain a minimum of 2000 gallons of water at all times.
I think the homes you see floating away are probably older homes that are not up to the new codes.
I don’t mean this in bad taste. But when homes are moved 100s of yards, does the state have to come out and re survey properties before you can rebuild?
Will there be just a large amount of property that people just walk away from?
