Cdog
- Apr 8, 2008
- 8,689
- 18,847
New engine going into the FE today. Mazda 2.0 4 cylinder. 180 HP 200 tq. Spec sealed engine.
Judging by the picture, I’d say it was clearly the blue wire right there in the middle.Todays project was trying to find a phantom electrical short in here on the DC voltage side.
Metso Cone Crusher.
Ugh! No idea. Came from Mazda like this and they dyno’d without that bolt I guess.How is that even possible, no thread in there? The engine you had in the FE had less power?
I dunno, when I blew it up there appears to be a black on with the insulation cut that could have been resting against the cabinet cover.Judging by the picture, I’d say it was clearly the blue wire right there in the middle.
So the jalopy saga continues!Project Frankenstein!
So my buddy calls me and asked if I could fix a couple things on his ex drag/street car and like a dummy I said sure.
Weld tabs on cage for belts
Fix rear brakes
Change fuel pump
Well once under car I found rear suspension geometry F***'d pinion angle was 18 degrees negative, trac bar was all wonky/not parallel to diff and the butchery was off the charts.
I tried to get him to back half it and he was not going to so I did what I could
View attachment 1310215 View attachment 1310216 View attachment 1310217 View attachment 1310226
View attachment 1310237 View attachment 1310222
View attachment 1310218 View attachment 1310219 View attachment 1310220 View attachment 1310221 View attachment 1310223 View attachment 1310224 View attachment 1310225 Fuel pump and filter mount
View attachment 1310228 View attachment 1310230 View attachment 1310232 View attachment 1310233 View attachment 1310234 View attachment 1310235 View attachment 1310239
Not what I'd call picture perfect by any measure but the chassis is now "neutral" it will stop and should go and stop straight.
NOR A DRIVEWAY JOB LOL!
Fix rear brakes
Change fuel pump
So it's on it's feet /I need to raise it an inch but fairly close to the target.So the jalopy saga continues!
It has a front motor plate and a mid plate and no trans mount so I say ok get a factory x member and low and behold the engine and trans are offset to the right and not equal front to rear.
So the car has front and mid motor plates and he wants a trans mount so I get a factory x member for simplicity and like the rest of this jalopy the engine is offset to the right and different front to back...
I am not making new plates right now and he is running out of $ so.....Made a janky offset stepped bracket and had to massage for exhaust clearance View attachment 1313799 View attachment 1313800 View attachment 1313801 View attachment 1313802 ..
Then it went to re plumb fuel and add gauge diaphragms for primary and soon to be added nitrus fuel system....
View attachment 1313804 View attachment 1313805 View attachment 1313806
…When I worked for Litton Data Systems… Every single wire had a stamped number on it… and there were books upon books of wire designations… Had to be absolutely perfect as we were saving South Vietnam from communism, for some fucking unknown reason???I dunno, when I blew it up there appears to be a black on with the insulation cut that could have been resting against the cabinet cover.
Regardless, if that rat's nest of unnumbered wires came from the factory in that state, it's a wonder the machine runs at all.![]()
Dig the Camaro on the lift
I like AV shit, wish I was better at it and had more resources to finish it outNo pics but household electrical. Changed out a light switch then started on AV shit.
That's cool
Bodywork is an art that I just can't even begin to master.1964 Impala Convertible. Getting ready to block and then more blocking. Dash, trunk, hood and jams are completed. Should be in the both next Saturday.
Agreed...patience and skills that some have, and I am surely not one of them.Bodywork is an art that I just can't even begin to master.
Very nice!View attachment 1326837 View attachment 1326838 View attachment 1326839 View attachment 1326840 View attachment 1326841 View attachment 1326842 View attachment 1326843 View attachment 1326844 View attachment 1326845 View attachment 1326846 Built a new 402 for the G8.
Forged stroker crank , diamond pistons and BTR H beams.
Also decided on a stage 3 blower cam ,new springs and a trunion kit while I was in there.
Now I can’t decide if I port the LSA blower or go 2650…. Full snowball
Such a rad package. Might be a little
That’s pretty bitchen! Is the oem finish smooth? And if not are you going to texture it?View attachment 1326848 View attachment 1326849 View attachment 1326850 View attachment 1326851 View attachment 1326852 View attachment 1326853 View attachment 1326854 Adding an air fuel gauge and need a good place to put it. Already have 2 aeroforce gauges but they are down low and a pita to watch. No great options out there for g8 pods.
Company started 3D printing a new option so figured I would give it a try. First real go at body working something and I’m beyond happy with the results this far.
I now know why it’s not profitable to sell something like this. To make it right I have a ton of hours invested.![]()
Yeah it’s smooth.That’s pretty bitchen! Is the oem finish smooth? And if not are you going to texture it?
Have you checked out SEMs products?Yeah it’s smooth.
I’m going to do a flat black enamel and a satin clear should look like stock plastic when done.![]()
I know about them but no hands on experience.Have you checked out SEMs products?
