Midwest Post Hor Thread
Headless hula
Got started cleaning up the saw last night. Took it off its custom stand, degreased it, sanded off the rust, and painted it. I bought a gallon of oil based paint and was going to roll it, and bought a rattle can of the same stuff to hit the tight spots with. Last night decided to do a test spray with the rattle can and ended up spraying the whole thing. I'm going to return the gallon today and hit the stand with a second coat. Also took the metal casters off. They do not lock and when you open the saw it slides a foot or so. I'll pic up some hard rubber locking caster to replace them with.
Not sure if the oiler pump is working, will give it a test tonight when I start cleaning the rest of the saw up. It was filthy but I'm not complaining.
View attachment 809732 View attachment 809733 View attachment 809734 View attachment 809735 View attachment 809736
My shop table has swivel castors on all 4 legs. No brakes either. I just cut some "tire chocks" out of some scrap 3/4 plywood...
I dont like chasing my table across the shop. :D
Headless hula
Kinda fun getting the pole barn tin above the garage door track. :p
Taboma
What's the J-box and cable for ? Unless you'd have to kill me of course :eek: Camera, speaker, disco-ball ? :p
j21black
Headless hula
Forced air garage furnace. It'd be kinda nice to not freeze my balls in here once January rolls around. ;)
Gas line will be exposed. I'd rather not have it in the attic.
There's materials that are available to put in the attic space without concealing any joints, but to put black pipe up in that enclosed space isn't code, and generally a bad idea.
Headless hula
Hold the tin up with the drywall lift, pull the track bracket with one hand, slide the tin behind it with the other.:D
Headless hula
The opening above the door spring is so I can get into the attic to insulate it.
Saved a piece of tin to cover the hole when that's done.
Headless hula
I finished re-wiring the door operator and got the last 2 pieces of steel on the ceiling.
My buddy John showed up to check out progress, and and shoot the breeze after he got done from work.
Then @HydroSkreamin stopped in too..
We made an executive decision to go to the little Mexican joint in Omro and have some supper.
A few margaritas later,....and solving the whole worlds boating problems, I landed back at the hula HQ for a a night cap.
Sounds like theres going to be some late season boating/prop testing goin on on Sunday. :D
Might try and get ahold of a tad bit bigger wheel to go and run a number in the hula too.....:cool:
:eek:o_O
Mayhaps a 85mph pass is possible????
Whodafuqknows......:confused:
Headless hula
Hey, @Tractorsdontfloat , you still balls deep in corn and soybean harvest?
Could use a prop bitch/truck handler on Sunday......:D
I know I could just text ya, but what fun would that be?
You just might catch a 100mph boat ride.
Hell, you might just catch a 80mph boat ride....
Either way, I know you've never been that quick on the wet.....:p:D
What's that tractor run out at? 6.4?????:eek::eek::eek:
Tractorsdontfloat
Hahaha! Yeah. Three weeks behind in the corn storm with no end in sight. Water...er rain specifically is the last thing I wanna see right now. Dry is good. Otherwise I’d come over and play.
Headless hula
K.....
So I'll see ya in January when I tell ya the fish are biting......
Noted.....
Dick. :D
TripleB
FWIW I’m just giving him chit, the Hula Hut 2.0 will be unbelievable when done
Headless hula
Have almost everything shoved into the middle now.
I need less stuff...
Headless hula
Diamond grinding is done on this little project. It used to be the garage for an old lake home.
Owners had it converted into an exercise room after they built this little joint.
If you look through the glass on the front door, you can see Big Green Lake....
Nordie
You guys make me miss the MW, I wish my experience was a little better.
Oh well I'll be there for a few days next month. Wish I had the time to make it up north to see some of my family. They're all on the border whether it be Ill or Wisco.
Headless hula
My kind of channel there.:cool:
This is the boat ramp that's a mile from my place.
Waiting on hydroskreamin to get here.
He's never driven, much less ridden in the hula too yet. Only had it for 2 years now. :eek:
Headless hula
Nice cowl, it must of added 2 mph:)
Actually, it didn't.
The wind picked up just as I started to run it. Wasnt worth trying. Shes pretty light in the bow, and gets flighty as it is, much less with any kind of gusts....
Should've been a 1 mph gain just cuz its blue. :D
