How does one go about getting a prescription for a schiada? Asking for a friend
Viva La Mexico! $45/ mth at any pharmaciaHe was paying $70 without insurance. I have never seen a place for $60 for 6 months with no insurance.
Yeah that's an option. Spend a day drive to mexico and save $5.00Viva La Mexico! $45/ mth at any pharmacia
Where will you be injecting?Going with test cyp 200mg once a week. 22gx1” said to hit the gyatt
Ouch.He said to do my glutes
You will feel a 22g. If you can, request a 18g to evacuate and pierce the rubber septa. Then switch to a 26g for your injection site. Don’t use a thin needle to pierce the septa, it bends the tip and subsequently will hurt and bruise later. Also your butt is a bit of of a twist, you’re injecting oil so it doesn’t just shoot out like a vaccine (and it’s a small needle.) Takes pressure and a little time to evacuate once you’re buried in your muscle. Thigh is pretty easy site to access and manage. Gonna be weird the first few times. Breathe and take it slow.Going with test cyp 200mg once a week. 22gx1” said to hit the gyatt
I think I’ll just order pins and have them delivered to the house. They aren’t expensive and then i can get what I want. It was kind of awkward in cvs when they told me the needles I ordered were out of stock and I needed to come back Monday, but maybe that’s just in my head and everyone wasn’t staring at me.You will feel a 22g. If you can, request a 18g to evacuate and pierce the rubber septa. Then switch to a 26g for your injection site. Don’t use a thin needle to pierce the septa, it bends the tip and subsequently will hurt and bruise later. Also your butt is a bit of of a twist, you’re injecting oil so it doesn’t just shoot out like a vaccine (and it’s a small needle.) Takes pressure and a little time to evacuate once you’re buried in your muscle. Thigh is pretty easy site to access and manage. Gonna be weird the first few times. Breathe and take it slow.
you’ll feel better in VERY short time. And…
Get snipped if you haven’t already![]()
Go big or go home.I've been using glute as well but not with the harpoon they rx, instead using what i've used for peptides which are 1/2 inch 27g. They prescribed 1.5in 23g. I split my dose MWF and experimenting with dosage, haven't yet taken the full 200mg in a week though, working up to it.
Wuhan?Also another tip. Fill the syringe with air before you piece the bottle, push out that air and the pressure will help fill the needle. Found that trick working in the lab extracting antibodies.
To clarify as that may sound weird… I was a chemist/immunologist. Ha ha
I got tested a couple months back but I think the test was skewed.
I tested 950 natural but I had my blood drawn right after going to the gym. Wonder if that’s what caused the numbers to be high.
Don't be nervous, it's so easy and the needles are short enough you can't do any harm. My wife take TRT as well but we ordered her 27g off Amazon. For all wondering, it's a very small dose. They keep women in the 70 range max. Help produce estrogen and other side affects worth while for meI’m going to look into the CAM deal that sounds way better. I ordered 100 18g 100 25g 1” and some prep wipes. Should be here before I get off work. I’m nervous but figure I might as well start today
Always start on Monday. Chest day.I’m going to look into the CAM deal that sounds way better. I ordered 100 18g 100 25g 1” and some prep wipes. Should be here before I get off work. I’m nervous but figure I might as well start today
200mg. Once a week? You'll be over 2000 total TS on that dosage!Going with test cyp 200mg once a week. 22gx1” said to hit the gyatt
I’ll double check but I thought he said once a week. He gave me 4 ml’s so a months worth?200mg. Once a week? You'll be over 2000 total TS on that dosage!
Nope. 1mL of 200 per week won’t get you there.200mg. Once a week? You'll be over 2000 total TS on that dosage!
Maybe on the small one. No chance on the big one.These are mine when I do take home. Have no idea the size. T and HCG for the big one and the small is vitamin D
