Zaairman
Tig ole bitties
- Dec 20, 2007
- 2,541
- 33
So, will the new shop be connected to the garage door to nowhere?
Also, this equipment is destroying your thatch.
So did you stick BoBo in the exhaust pipe in case it rains tonight? I think he would just fit in nicely...
Got all the trees yanked out of the ground, and the shops baesment dug today....Heavy equipment is cool!
Might I suggest keeping this particular door closed?
Brian, I think I see a blade of grass beside the new shop basement. It's probably just some sod residue from the dig.
Either way, you better get on it with some Roundup before it sprouts and fucks up that barren waste land look you've paid so dearly for. :thumbsup
Very cool. Do you have the plan for the pool already??
Looking good!! :thumbsup
JBB so no rebar or gunite? I've never seen a pool built that way before...
it looks like he will be able to jump from the second story porch right into the deep end!
Thats to control damage from freezing I assume? Looks like it will be very cool.:thumbsupGalvanized steel wall / vinyl liner...
Sure aint no west coast pool!
Fill us in B, I've never seen anything like that either! Whats the advantage of this kinna build?
:hmm
Pretty cool man:thumbsupand I can sit my high capacity guns nearby, in case of zombie attack.....and not be in violation of any laws...
compare pool types
Will you be getting the custom mural on the bottom? Maybe a giant BoBo? And in Cali there is no standard,in Compton a 55 gallon drum and a hose.................
Oh,and please post a pic this winter of you sitting in the snow next to your frozen pool,high capacity gun in hand waiting for the zombiesDon't they stay underground when it's that cold?
And doesn't all the humidity during summer rust your guns?
Are you building a waterfall into the pool?
Brown wants to know if he can be the first one to piss in the pool?
Pool looks cool. :thumbsup
Byron you should get your Jeep running again - you could tear up all that stuff!
hey ummm....
how many gallons is that pool gonna be? that filter looks WAY too small!
I have a 30k gal pool, and i got the bigest filter they made at the time (you should too). you can go much longer between cleanings this way!
are you, or can you, go salt water with vinyl?
if not, look into one of these deals....
http://compare.ebay.com/like/320719631960?var=lv<yp=AllFixedPriceItemTypes&var=sbar
Filter is matched to pool and pump size and it will be a salt water pool
It's looking nice.
It's interesting to see how they build a pool in your area. Do they compact the hell out of the backfill? I'd worry the less dense backfill would destabilize the pool walls.
What now? Gunite?
Is the pool going to be heated? I would imagine a decent array of solar panels would put you in pretty nice, almost year-round, comfort in your part of the continent.
Compacted wet, numerous times...it is solid...what's next is a concrete bottom, and a vinyl liner...real men need no pool heater...
But what poor about Bobo?? He's not gonna like that cold water one bit!
having a wetsuit made for Bobo
They are digging the footings for the shop today.....
looking good....
Whats the plan for the shop? Is it going to mate some how with the other garage?
poured walls to meet the old shop walls ...full basement, main floor,...attic floor...
will you be able to open the garage door and drive into the main floor or will that be your attic? (hard to tell based on elevation)
