yz450mm
- Jun 10, 2013
- 3,660
- 7,545
Mine is good, but the 614 car, is horrible. He just hit 100 miles, so he definitely needs to reset his springs.
The springs sag, like every other spring, you re-adjust the pre-load to get the ride hide back to the ideal location.Reset his springs? What does that mean? Do the preload collars loosen over time? I guess they probably need some break-in time.
I had to reset my preload twice in the first 200 miles... threw away the springs and went with Eibachs.I put almost 200 miles on mine over the last week with no issues. I'm losing ride height due to sagging springs. It looks like your ride height is pretty low also.
It is, it's a known issue with the stock springs, but really, mine got reset at around 80 miles, and they don't appear to have sagged anymore. I don't think the hype about "NEEDING" new springs is a real thing.I reset can am springs at 1000 miles. Then replaced at 2500 miles.
Sagging at 100 miles sounds quick.
Can't go by years as a lot of SXS owners barely do more than 500 miles a years. LOL!
Also desert and trail miles are a lot easier on belts than dune miles.
Best I have done is 2800 miles on a XP1000 belt and my first Can Am went just over 2,000 miles.
I do about 3000 miles on a belt. I change them even tho they are not broken. I can feel the slip some so time for a new one.
Longest I went on my turbo s was 4500 miles that’s dunes and trails. I had top pieces missing too. But it wasn’t worn on one side like this one.
My rides are typically 500+ miles a trip. So it’s a full prep before every trip oil, trans, diff, air filter. Basically every 25 hours. We do these about 1 per month every season. Air filter may go two trips depends on how dusty it was and if I lead or not.That’s allot of miles for both of you guys on a belt. I’m sure I’m the exception, but typically I start the season with an oil change, new air filter and new belt. Unless I do a Baja trip or something like that, my oil is good for a season, I probably change the air filter once more in a season and the belt is always good for a season. But I don’t do as many miles as you guys either.
If going to Baja I do the full prep over, even a new belt just because it’s cheap insurance, and part of a good prep. The other belt become spares. Typical Baja run has been 600-700 miles. Then when I get back, it’s new oil, air filter, siphon any Pemex left in the tank and run fresh fuel and an injector cleaner through it. And unless the belt slipped or got hot, I’ll inspect it, mic it and use it for the rest if the regular desert season. If not, I l put the pre-Baja belt back on and the Baja belt is marked as a back up.
Also how often are you guys opening up your CVT and blowing out the clutches? As for me, unless it was just not a dusty trip, or we don’t do a bunch of miles. I try to do it as part of my wash & put away prep after a desert trip.
Only if you scream as loud as a never Trumper lol!It is, it's a known issue with the stock springs, but really, mine got reset at around 80 miles, and they don't appear to have sagged anymore. I don't think the hype about "NEEDING" new springs is a real thing.
What is the latest on deliveries, are they caught up with first orders that were placed ?
They have resumed deliveries this month but have thousands of pre-order cars still to deliver. Will probably take until next year for everyone to get their cars.What is the latest on deliveries, are they caught up with first orders that were placed ?
So the design is still 2020 with a few upgrades? and will be a 2026 car?They have resumed deliveries this month but have thousands of pre-order cars still to deliver. Will probably take until next year for everyone to get their cars.
Yes with a lot of upgrades and refinements.So the design is still 2020 with a few upgrades? and will be a 2026 car?
Still blowing up clutches, belts. Still no customer service. People are still popping motors trannies and driveshafts. CVS are still a problem too.
That sounds like every SXS. Shit breaks, it’s how easy is it to fix that is the difference. CanAm, RZR’s have an extended service network. Speed has a very limited service network.Still blowing up clutches, belts. Still no customer service. People are still popping motors trannies and driveshafts. CVS are still a problem too.
Exactly,That sounds like every SXS. Shit breaks, it’s how easy is it to fix that is the difference. CanAm, RZR’s have an extended service network. Speed has a very limited service network.
I know of 3 shops that will not work on Speed. All 3 did when cars were first released. They all stated. Mfg support sucksExactly,
Clutches for these are like 5k from speed. Ouch!
They all have problems just speed has more for how few units are out there.
Aftermarket is slowing fixing some of these
Do you work on them time and material and/or factory warranty?I'm a shop that will work on them (transmissions and front diffs)
Where are you located? I need to do RZR trans bearings soonI'm a shop that will work on them (transmissions and front diffs)
Sean can you get parts to service or rebuild the Speed trans or front differential? Also you have mentioned on RDC that you don’t think the bearings originally spec’ed are being used. If someone wanted to bring you a trans to get the “Ritchie prep” to it. Can you get the good bearings and do all the things you did at Weddle?I'm a shop that will work on them (transmissions and front diffs)
Recently it’s been said that Speed is not even opening up the broken transmissions and are just doing full replacements, and that the broken Transmissions are being sent back to Asia. (Assume for some sort of credit?) This has some wondering if Speed will even offer internal parts to rebuild or service the trans & difs?
Robby 4th, Max 17th ProStock TurboSo how did Speed do at KOH??
Haven't heard much talk about them.![]()
That was so 2023. lol. I’m told and what customers who have had trans, dif, clutches, driveshaft failures are saying, That Speed is just replacing the failed part. The bad parts get put in a bin or pallet and those are being shipped back to Hisun. It’s probably how Speed is getting refunded for warranty failures.To my knowledge any major failures of engines or trans actually get shipped to North Carolina to the race shop where they are disassembled and see what went wrong.
Thats not possible sir. I read it right here on rdp. Speed sucks. So it must be true. BP will be along shortly to confirm.My customer service from Speed has been great. I've showed up unannounced and they had the car repaired and back to me 4hrs later.
Don’t ya know it lolThats not possible sir. I read it right here on rdp. Speed sucks. So it must be true. BP will be along shortly to confirm.
What’s ironic is when I post that I had good service they say it’s because I’m RiverDave.. lol.
Could just be they do a good job?
Speed car out selling houses! lol
Lake Havasu City Realtor on Instagram: "✍🏼Get ready for an adventure with Team RDP in beautiful Lake Havasu, Arizona! While most agents stick to the traditional routine of scheduling showings, we believe in bringing excitement to the home-buying jou
63 likes, 12 comments - teamrdprealestate on February 19, 2025: "✍🏼Get ready for an adventure with Team RDP in beautiful Lake Havasu, Arizona! While most agents stick to the traditional routine of scheduling showings, we believe in bringing excitement to the home-buying journey. In our...www.instagram.com
4,000 pre-orders plus minus.So without reading 200 pages of this particular speed thread, what car are we on for delivery? Weren’t there something like 20,000 pre-orders war years ago?
I’m not bashing. I’m just trying to see what the facts are after watching this latest RG video discussing car 761.
About 1500-2000 delivered do you think?4,000 pre-orders plus minus.
Somewhere around a 1,000 cars.About 1500-2000 delivered do you think?
What does that have to do with a Speed discussion thread?From pen and paper to 280,000 units, was 5 years.
Thanks Henry.
Dan'l
