Outdrive1
- Dec 19, 2007
- 33,618
- 31,019
Wonder if RD has checked his oil since last year.
The local Sheriffs up here run them. My friend, who's a deputy, said they got one in the last batch that is burning a quart in roughly the same. Dealer told them the same, it is "within spec".We have been doing the consuption test for a few months now with Chevy. 2022 6.2 burns a quart every 1400 miles. They state its normal!
Fuel economy is why oil has gotten so thin.Considering they only hold about 8ish quarts that’s gonna be cuttin it close to E on those 10k Mile services
Wonder if a thicker oil would be any better? Always been curious why they recommend that low of a viscosity on the newer gas GM stuff?
Yes, but it has also gotten a lot better. We had an ad pack that resists LSPI much better than previous product. With low tension rings used in everything now, we need to keep some level of seal to the cylinder wall while also preventing microwelding, and we need to timing chains happy, since they’ve made a comeback after a brief 20 year or so run with belts. The viscosity has little to do with anything at this point…and hasn’t for a long time.Fuel economy is why oil has gotten so thin.
Isn’t that the best!Oil was low once.. they stated oil filter loose! Response “you changed the oil”.
Tightened oil filter and topped off.. lol
Now that's fukin funny...Oil was low once.. they stated oil filter loose! Response “you changed the oil”.
My '22 6.2 uses about 1/2 qt. per 6000mi. My son's '21 6.2 uses about 1 qt. every 3000mi. The '21 sounds like a box of rocks on cold startup though.We have been doing the consuption test for a few months now with Chevy. 2022 6.2 burns a quart every 1400 miles. They state its normal!
My 6L does that…I used to add a quart before I learned the change oil message would pop up the next day. LolMy 2007 5.3 would let me know when the 3k oil change was due because it would burn enough for the “low oil” light to come on.
Oddly convenient.
Got a 2017 Silverado with 43k that does the same exact thing. Once I get about 2000 miles out from the oil change I check the dip stick, and it is always below the full line.My 22 Yukon 6.2 needs an extra quart added between changes. Dealer told me that is typical for these.
My 2008 8.1 while towing to the River or Glamis, would burn a full quart.
