1fastsedan
- Apr 6, 2010
- 352
- 494
Red just hits different on the water. Cant wait to see the results.
Poncho does do good work!
Looks awesome! I can't wait to see the pictures of it back on the new trailerBeyond happy with the results! Now onto the inside!
He does very nice work! Come to find out he was the one who regelled my first schiada 23 years ago at a shop in Stanton CA. So he’s been doing this for a whilePoncho does do good work!
He does very nice work! Come to find out he was the one who regelled my first schiada 23 years ago at a shop in Stanton CA. So he’s been doing this for a while![]()
Looking good!New stringers are in and templating for new bulkhead. The bulkhead is getting a few changes and floors/bulkhead should be set in the next week or two. Really happy with Pancho’s work.
Bulkhead was adjusted to your specsLooking good!
You said "template" so I will just suggest the possibility that inside corners on the opening get a healthy radius. Sharp corners = bad.
Pancho is the MAN!
OOOOH say some more about those waste gates. What do they do better than the standard single ports from Carson?New turbos and dual port wastegate actuators. @cj222 helped make some actuator adapter plates!
I am using turbosmart dual port actuators. Dual port allows boost control for different tunes utilizing a MAC valve. This setup utilizes pressure to bottom of port so you can increase spring rate in exchange increasing boost. The top port bleeds off through the MAC valve. The standard Brummett actuator doesn’t have a sealed bottom/underneath of diaphragm so you are only feeding pressure to top pushing down diaphragm when it reaches spring rate. His new dual ports are very nice but pricey. If you wanted to turn the standard into dual port I think you could sleeve the bottom of housing/actuator rod and add port to bottom housing. His dual port has a larger diaphragm also but not sure if that is as important as having a decent seal on both bottom and top of diaphragm. Im shooting for a 7lb and 12lb tune.OOOOH say some more about those waste gates. What do they do better than the standard single ports from Carson?
And damn that @cj222 dude is one hard working son of a gun, he's got his hands in basically every v-drive thread in this place. Does nice work too.
That is a beautiful piece! The Boat is going to turn out sweet. Thank you for sharing your build, not enough of this around here !New turbos and dual port wastegate actuators. @cj222 helped make some actuator adapter plates!
This is pretty interesting and points out how little I know about this stuff. When I was building my sled I just called Carson and said "need turbos". He asked a few questions and said send cash...
Besides just changing out your springs if you wanted to change boost quickly I think you can bleed off your top port line through some sort of manual or electric valve that would provide similar results (backing off some of the boost to the actuator so you produce more boost to the intake) "BUT" Im no pro! From my research there are many ways of plumbing the actuator air lines. The MAC valve is electronic and will be controlled by my Motec ECU.This is pretty interesting and points out how little I know about this stuff. When I was building my sled I just called Carson and said "need turbos". He asked a few questions and said send cash...
Is the block at the top of the schematic the intake manifold?
How is the MAC actuated to achieve the higher boost?
Not knowing the specifics of your motor, does 12 psi require race gas or something other than 91 octane?
Like the others have said, thanks for bringing us along. I love this kinda stuff.
Thank you!Show winner piece right there.....
Will you be displaying at Billy B's show in Needles in Feb?
Oh, did I say that out loud? Crap...that was supposed to remain a secret.....hahaWait a minute, Billy B's Boat Show is back? Need more info...
@jstnoc the old Vaughn looks amazing. Pancho is the man.
