jstnoc
- Feb 12, 2008
- 543
- 514
taking equal amounts off each case?Custom mid plate c500 in the works.
Yes for a 3/8 platetaking equal amounts off each case?
Hold downs for the axis mounts in the CNC machine
Looking great!Motor is coming together nicely but still a lot of parts to make then wiring harness and dyno.
Cam sync - no distributorLooking great!
What does the sensor on the cam drive do?
All right, I had to ask Chat GPT why I would need one, because, well, I'm a carburated dinosaur...Cam sync - no distributor
New efi systemAll right, I had to ask Chat GPT why I would need one, because, well, I'm a carburated dinosaur...
Here's the summary:
"In a high-performance marine engine, where reliability and power delivery are critical, a cam sync sensor ensures maximum efficiency, power, and engine longevity.
Are you setting up a new EFI system or upgrading an existing setup?"
Love this thread and look forward to the updates. Keep em coming.
Mad skills and appreciate the attention to detail.Last piece to finish the motor bolt ons - Scanned motor and Intercooler in CAD to get proper alignment. Built base plate and getting ready to weld on.
When is dyno tim
Within next 30-60 days!When is dyno time?
Might have missed it earlier in the thread but I see a Kinsler 450 pump and EFI? Coolness. Could you tell us more about what I’m guessing is your surge/supply tank wrapped in plastic in this pic? Looks like a regulator built into the top? Are you running the pump supply under some pressure to help with Vapor pressure? I’m getting into rigging my fuel system soon for mechanical injection.Motor is coming together nicely but still a lot of parts to make then wiring harness and dyno.
I have a standard high volume feed pump on the block that feeds the tank you see wrapped in plastic. That tank feeds the high pressure kinsler. The tank has built in regulator and a return port back to my fuel tanks.Might have missed it earlier in the thread but I see a Kinsler 450 pump and EFI? Coolness. Could you tell us more about what I’m guessing is your surge/supply tank wrapped in plastic in this pic? Looks like a regulator built into the top? Are you running the pump supply under some pressure to help with Vapor pressure? I’m getting into rigging my fuel system soon for mechanical injection.
Kinda what I figured looking at it. I guess what I’m asking is if you’re supplying a slight positive pressure to the Kinsler pump? Being EFI your injectors could deal with that but me being mechanical there’s other steps involved if i approach the system this way…I have a standard high volume feed pump on the block that feeds the tank you see wrapped in plastic. That tank feeds the high pressure kinsler. The tank has built in regulator and a return port back to my fuel tanks.
Here's the summary:
