2FORCEFULL
- Jan 26, 2008
- 28,989
- 17,745
here's another puzzling find.... while cleaning the smoke damage... I took the stromberg carb off.... I've been running lucus fuel treatment so wanted to see what the carb looked like inside... so I take the bowl cover off.... the carb is clean as new inside....but.... the float was just laying in the bottom of the bowl... the rod that holds it has a screw in from the out side, that was missing... the fuel is gravity fed from the fuel tank on the fire wall.... every time I drive it I shut the fuel line off, and turn it back on just before I start it... seemed to run ok but was a little lazy on throttle response.... would it run without the float??? fuel pressure has to be 1 pound.... or less I would guesss?????? I was able to adjust the idle screws out , seems like they would have had to be all the way in to run if it was flooding over the bowl??? also.... I think it was that way when I got it....
is that possible... or do you think it happened, ( screw came out on the last run/) when I drove it last???? guess I could take the screw out of the new carb and run it to find out...or just never know what happened..I'm a gotta know guy and pay dearly for it.... I remember as a kid my Dad saying time after time, " Why you fuc'n with that!"
