Glastron CVX-20
Guest
Director...
Negative....I got these. They're Real....and they're Spectacular!....:p
attachment.php
Guest
Director...
Working on seat bases boroscoped tank (its good) getting ready to see if the old 460 will run
Rexone
an ordinary American
Glad to hear the Jeep project is getting wrapped up. :thumbsup :thumbsup
djunkie
Broke mo fo
Glastron!!!!!! :D
Sent from my iPad using Tap That Ass
Guest
Director...
So...If you look here....http://www.riverdavesplace.com/forums/showthread.php?82532-Glastron-CVX-20
I have been tinkering with this Glastron that I bought from a guy here at work. Full of water,tree limbs, bugs, pine straw, ect, ect......In talking with the guy I bought it from, he says it has been sitting in his parents backyard, uncovered, since he put it up, due to a spongy..floor in 2004....He said the last time it was run was in 2003 or 2004....I knew the starter and carb were no good, so I had them rebuilt...enging was locked, so the plugs came out and got bead blasted,trans fluid in they cyls, and barred the engine over.l borescoped the fuel tank and was surprised to find clear gas, that smelled like gas, and not varnish, and found no rust or trash in the tank..{tank was filled to top when boat was put up} Today with the gas that was in it from 2004, it started and ran...no knocks, leaks, no water in the oil...didnt run great on 3 octane fuel...but it ran on the hose, came up to temp ect...All the guages worked, oil psi was great....At least I now have a starting point as to where this engine is, condition wise...Built Ford Tough?...
Video...http://db.tt/Fdmi86io
HolyMoly
reMember
Some quality PVC water connections going on there!
And I guess that must be the new style pump that doesn't mind being ran dry. :thumbup:
Guest
Director...
Relax midget, It's all being replaced. I just wanted to see if it would run...
Guest
Director...
You are WAY younger than I thought you were...
Not me..My good friends at Proboat got tired of waiting for me to turn the engine over, and did it for me....while I work on some paint issues on one of theirs...Im pretty old...and feeling it...
TBI
Thumbless Wonder
Better check that belt tension before you take it out Byron :thumbsup
Tom Brown
Epsilon contributor
Running off the hose seems somewhat less than professional to me.
AzGeo
Get some aftermarket replacement valve springs. (new stuff) Install the new springs with 90 to 100 lbs of pressure in the closed position. Make sure that the new springs have less than 320 lbs when in the 'valve full open' position. (example: .450" lift = 300 lbs) Moisture attacks the metal of all valve springs, and what you have has many of them being 'in the open position for years'. Don't take a chance, 16 springs are cheap VS valves hitting pistons, etc. Also take the distributor apart, clean and lube, then set up the mechanical advance with lighter springs. Then do all of the 'normal rehab stuff' to get it back on the water. The Phoenix has risen !
ka0tyk
just add a bottle of lucas oil to the old gas and she purrs like that eh?
RandyH
Huge Member
What kind of blower are you putting on this one? sounds great?:thumbup:
Guest
Director...
Tension...noted...
You would expect anything less?
Bryan, are you going to make a fancy mount for that battery charger or just bungee cord it?
Bungee cord..90 pack currently on sale at Northern...:thumbsup
The new paint looks great. :p
Thought you might like it!
Part of the master plan, thank you...msd ign and dist.
You going with schedule 40 next time?
Pex!
Lucas is what makes the world go round...
No blower...Twin turbo...:thumbsup
Engine is now out of the boat...I will pick all of it up and bring it back to the compound Friday...
That is sound advice. :)
72Hondo
hey a boating thread.... :p
I like it, keep the updates coming.
sprintcvx
Congrats on getting it running.. Nice job!:thumbsup
FreeBird236
Maybe we still had real gas in 03-04, can't remember, but anyway that's great.:thumbsup
Warlock1
Words mean nothing, where are the pictures...hahaha
Guest
Director...
Scored a new wheel for it...thanks for the tip, CC
attachment.php
CampbellCarl
attachment.php
Didn't/don't know if you even wanted/needed one.................just figured that there's not a lot of them floating (boating related) around.......
CC
Guest
Director...
Paint for the Bellhousing
Beadblast
Epoxy Sealer
Black Imron
FreeBird236
Probably just the pic, but the epoxy sealer looks pretty cool.:cool
spectras only
Looks good JBB. Are you going to use a top mount starter? It's a bitch to replace one in the low location in those Glastrons.
FreeBird236
Its dull gray...
Pic makes it look charcoal metalic satin:D
I hated those flat paint schemes when they first came out, but they're starting to grow on me on the right cars.:thumbsup
Guest
Director...
Working on front seat bases....and today scored 2 sets of valve covers to choose from..The Mickey Thompsons would look good in wrinkle or gloss black...
Warlock1
I agree I have always liked that MT style
