39000 miles so far. Not one issue.Smooth sailing over here no issues. Getting ready to hit 2,000 miles.
Should have 4,000 by end of the year.
First towing test October 7th
That looks good! I want to do that with mine when it happens. Might go Fuel forged though.
I really like how this looks. Likely will be what I end up with. View attachment 1156043
Looks good! You may consider a 325/60r20 too. It’s what we did on the truck for @boatnam2 with the same wheelsI really like how this looks. Likely will be what I end up with. View attachment 1156043
Have any more pictures of that? Looks nice.Looks good! You may consider a 325/60r20 too. It’s what we did on the truck for @boatnam2 with the same wheels View attachment 1156180
I don’t have many pics and I’m not sure why. Here are two others. I know we had to tweak a brake line when the tires were at a full turn because of the offset of the stock wheels. But it wasn’t too bad. The overall diameter of the tire is just above 35”.Have any more pictures of that? Looks nice.
I don’t have many pics and I’m not sure why. Here are two others. I know we had to tweak a brake line when the tires were at a full turn because of the offset of the stock wheels. But it wasn’t too bad. The overall diameter of the tire is just above 35”. View attachment 1156280 View attachment 1156281
Depending on the tire, I saw around $50+ more for the bigger size. No such thing as a cheap tire for anything over 35" anymore.I priced out that size. Shit they are expensive. $100 each more than 295/65/20
I have 315/60/20's on my Ram. I would go up to 37" or drop to an 17/18" wheel if I had to do it again. Not enough sidewall with the 35'sDepending on the tire, I saw around $50+ more for the bigger size. No such thing as a cheap tire for anything over 35" anymore.
Off the top of my head, a 37 with an 18 can still get a pretty high load rating for that big trailer you tow! That’s at least one benefit to what you have.I have 315/60/20's on my Ram. I would go up to 37" or drop to an 17/18" wheel if I had to do it again. Not enough sidewall with the 35's
And your truck is still one of my favorites that we did!
Brandon is a solid dude. I am gonna be hitting him up soon for tires on my enclosed trailer3 things i love about truck
Looks
Power
3 things i hate
Ride
Unpainted under hood
Bed liner that looks like shit already.
LakeMead boater was a pleasure to deal with, he wasted plenty of time answering all my questions on getting what I wanted, even mounted 2 different tires to see what i liked, I don't mind making a drive for this type of good service.
Wheels/tires/lifts. Even with the lifts, we are pretty particular with what we will/won't do. We just happened to stumble into a relationship with CJC and started doing more Carli installs towards the end of 2020.Do you build/mod cars or just wheels/tires/lifts?
Beautiful!!!So I was feeling brave.View attachment 1160451
So tight if you tap the brakes it will hit. Can’t touch the brakes until the van has cleared. Got to drag them just a touch so you don’t come in hot.Tighter than ole dicks headband!
Is it the door or the motor/beltSo tight if you tap the brakes it will hit. Can’t touch the brakes until the van has cleared. Got to drag them just a touch so you don’t come in hot.
So much for my leveling kit.
Didn’t try. Wife won’t relinquish it anyway.The picture may be deceiving but will the door actually close with the truck in there? It doesn't appear that it will due to the truck length but could be the photo angle.
Antennas on the CabIs it the door or the motor/belt
No. That will look Like shit in my opinion and it changes the distance to the bump stop. So the over load leaf won’t start carrying weight much before the bump stop comes into play.Take that block out of the back and live life![]()
I don't think it would look bad. The Fords sit fairly stink bug as it is.No. That will look Like shit in my opinion and it changes the distance to the bump stop. So the over load leaf won’t start carrying weight much before the bump stop comes into play.
Only reason I want it to fit in the garage is so I can geek out in detailing and be out of the sun.
I can always take the air out of the tires lol
But you are right, it does bring that axle closer to the bumps at ride height. Wouldn't do anything to the springs or overloads though, just the bump stops.
I looked at the lowering blocks. The blocks have the bump stop pad built in. So I think that would change that to the proper clearance.It will look awesome.
Buy the 2wd bump stop.
If all F250s use the same bump stop, the point is moot.
What year is it? (not reading through the whole thread to dig up all the details) I'll see what I have availableOk guys WTF is with these brake pads? Brake dust is ridiculous!
Thinking of changing pads. Anyone done this yet?
‘22 has a whole 3,000 miles on it. Brake dust is insane.What year is it? (not reading through the whole thread to dig up all the details) I'll see what I have available
Does it stop good?‘22 has a whole 3,000 miles on it. Brake dust is insane.
Stops great no squeak. But dust like I’ve never seen.Does it stop good?
Only complaint on my 21 Chevy 6.6 gasser is the brakes. They suck. And they squeek like crazy some days and some days no noise. No brake dust.
I have heard the same and makes perfectly good sense.Not sure if it true or not.... But I've been told that softer the brake pads = better stopping but makes for more break dust and faster wear .....
Soft/Hard are terms made up and thrown around by people who don't know what they're talking about.Not sure if it true or not.... But I've been told that softer the brake pads = better stopping but makes for more break dust and faster wear .....
Abrasive friction will typically create a lot more dust than adherent friction, and more rotor wear, while typically providing a higher coefficient of friction and keeping the rotors nice and clean of rust (for you midwest/northeast folks). An adherent material will be lower dust, low rotor wear, at the expense of poor rotor cleaning action and sometimes as the expense of some performance....but with modern material, not much if any
Very abrasive pads, lower tensile strength (softer...lol) iron used for the rotors.Thanks for the insight.... I received my info from BMW as their damn brakes make a LOT of dust and rotors are replaced with pads.....when I questioned them about it...
Wrong.Low dust
Good repeatable braking performance
Quiet
Easy on rotors
You can pick any 2… maybe 2 and a half.
Wrong.
Many high temp adherent materials exist now....when they're run in their happy temp range, we actually see dimension ADDED to the rotor, in the form of a friction transfer layer. Adherent pads have low dust. Quality pads have good repeatable performance, are quiet, and adherent pads are easy on the rotors.
