First Shakedown
jmeads
video of shakedown or it did not happen. lol
Outdrive1
Boat looked great on the water Glenn.
BUDMAN
HAVASU BOUND
Damn!! That’s a bad bitch.
420HOA
FIRM MEMBER
74 spectra20 v-drive
Beautiful Job sir, the best thing is at a glance its so clean and then you start to see all your fabrication, I remember when you mocked up a transom in your shop, what a build!!!
420HOA
FIRM MEMBER
BamBam
What happened to the build thread on this? I remember progress from start to the install of all the stainless hardline.
skifaster
Hard Member
I watched the original build thread and wondered what happened to it. So great to see it finished. Saw it on the water last week looked great. The hard line work is so unique and probably the coolest Schiada rigging I've seen. I saw this boat in its original state in the Water Ski Racing World Championship is Belgium in 1995. Quite the upgrade. Great work.
TBulger
Doesn’t get an nicer Glenn, remember when this started, the detail is incredible. Congrat’s
lenmann
Really looks great, and the rigging is over the top. Nicely done. I know its been quite journey, it must feel pretty good to have it in the water. Your original thread was one of several that sent me down my personal rabbit hole.
I am going to appropriate your wiring schematic for my sled, so thanks!
What's the red LED in the steering wheel for?
420HOA
FIRM MEMBER
Low oil pressure light
16 qts in the system I hope it never comes on while running 😉
lenmann
One more question: What is all the writing up under the dash all about?
lenmann
Dutch
someone rewired it over in Europe and that was their wiring diagram
I thought it was a significant part of the ol girls history so I left there
Thats awesome! Seems like a lot of these old Schiada's have a story to tell, yours has travelled the world.
AZLineman
Adjusting to retired life
Amazing and so clean! Pure artwork! Congrats. Prop/gear/Hp?
sintax
This test set up was:
43's in the box
Menkins 11.5 x 15 1" K monel shaft
1005 HP 895 Trq @ 5900 RPM 91 octane pump gas 605 CI 4500 carbs 90-92 jets
22.6% over driven 11.4 # Boost 38 tooth at crank 31 tooth @ Blower
And how’d she run? Who built the engine?
420HOA
FIRM MEMBER
Lil rich on the primaries, lil under propped, lil under geared
GLC (me) built / assembled the engine
QMP machined the block
Crower worked the crank and rods
Carb shop did the toilet bowls
Mooneyham did the blower
AFR did the heads
Dyno'd at Verbancic brothers
Barber welding built the SS strut / rudder / fins
Greer Rush built the v-drive and strut / fin set up
Art Carr built the transmission
GLC did all the rigging / installation
sintax
AFR did the heads
Sounds like it’s gotten some love man! I didn’t know you were a v-drive guy when I was out at your place in Parker. Did you ever finish your remodel?
My nieces love that damn lily pad btw! Thanks again!
AZLineman
Thx for the info! Are the carbs boost referenced or are the PV’s plugged. Thats alotta jet with Pv’s but you def have the cubic inches. 10/71?
I recently got a new 2 blade from Dallas thts 11-3/4 x 16.5 and it carries the nose great. Like I said above your sled is an amazing work of art. The hard lines are over the top. Great job. I look forward to seeing it in person
420HOA
FIRM MEMBER
Carbs are Not boost referenced
Went down to 90 jets on the primaries for test two and was still a little rich
Just received my Grose prop in the mail but haven't run it yet
I will drop to 89 jets for the next test session
Hoping the Grose prop carries the nose a little better with more top end speed
If not I'll up the gear
AZLineman
So NO power valves then? We wana see that Grose wheel ❤️❤️❤️
HighVoltage329
I had to move the prop forward trimming the strut & shaft for the Grose prop, but well worth it.
It's much smoother and better lift & bite than my tried & true Menkin's.
420HOA
FIRM MEMBER
AZLineman
Beautiful. With an investment like that I think I would let it sit on the coffee table all winter long just to keep me motivated. Lol. The prop i just got from Dallas has a similar shape to this with the long leading edges compared to props of the past. You’re 21 is a work of art and worthy of one of these props, mine is not nor is my wallet these days. Lol.
jmeads
Curious, how much forward did you have to move the prop? Thanks
lenmann
How do you know that it needs to move forward?
Or backward?
How do you know if you’ve gone too far?
HighVoltage329
Moving the prop forward helps carry the nose of the boat but to high gets squirrely. The Grose prop rides further up on the shaft so I could no longer fit my prop puller between the strut and the prop. I cut 1/2" off the back of the strut and 3/8" off the prop shaft thinking I could shim back if needed with a nickel of two if needed. It liked the 3/8" forward. What it helped with was keeping the nose from dropping down once the main acceleration starts to slow around 95+.
Before with this prop the boat would start to rock side to side at high speed.
