'82 Juddcraft Project
Jimmy
If it's standard color wires I have never seen any other colors, marine could be different.
Black-ground
Red-12v switched
Green-signal
White-light
You can test the signal with a test light
The signal wires reading 12v on the multimeter. My test lights at home.
It would be pulsing to fast to see on a test light.
Ive call it a day, just finished the copper work for the cooling, just need to get some 1" heater hose to finish it off and some 3/8 hose for the low pressure side of the power steering.
If you're reading 12v on the signal wire then you're good, make sure you have a good connection at 12v switched on the run side of the ignition switch, not the accessory side of the ignition switch, and check your ground.
Jimmy
I'll double check the wiring but the all the other gauges work and its a common 12v behind the dash.
I may have gotten a dud gauge, I'll wire it up off the car to see if it'll run.
There are dip switches in the back of the gauge that are set to 4 pulse V8.
Jimmy
Got talking to one of the auto sparkies at work and he said to try putting the multimeter on DC Hz and go between 12v and signal wire.
[video=youtube_https;TbsXq9Zj7do]https://youtu.be/TbsXq9Zj7do[/video]
I must have gotten a dud Tacho.
Jimmy
Found i have a slow weep out of the carby too.
Its very slow like thats a weeks worth on the intake valley.
Jimmy
Heres the to do list to get in on the water.
Testing the powersteering tomorrow.
Just need to get a belt in the morning.
Need to invert the oil pressure light its coming on at after 5 psi, should be other way round.
Just waiting on a block mount ski tow from Eddy marine, i think they make to order because I ordered it weeks ago and the just sent the receipt now, so should see it in 2 weeks. May have to make it suit once i get it tho.
I'll swap this tacho for a new one.
Take the boat into the local guy to change the oil in the drive and he'll do a insurance check.
If hes happy we're good to go.
Ski season starts November so timed it perfectly.
Jimmy
Got new seals for the carby.
Might do metering box seals too.
Jimmy
The day u want to put the boat on the hose to test the powersteering is the day the old man wants to do the storm water on the shed.
Jimmy
Powersteerings all done.
I dont notice a difference in steering, might make a difference in the water.
Chased a few water leaks out.
Inverted the low oil pressure light, it now turns off at 5 psi.
Booked the boat in for the 13th of November for a insurance check.
Ordered a fuel level sender and gauge, no excuses for running out of fuel now.
Fixed that fuel leak in the carby.
I'm wanting to jazz the bilge outlet up, the laundry tap shrouds my plumber mate gave me look a bit agricultural.
YoPengo
Inmate #47
Congratulations... You're on the home stretch. Cool project.
Jimmy
I wasnt expecting this for another week.
It may even fit!
Jimmy
Hmmm...
[video=youtube_https;mOXJL-RF4Ew]https://youtu.be/mOXJL-RF4Ew[/video]
Jimmy
Somtingwong
[video=youtube_https;lHB0Iks9cTQ]https://youtu.be/lHB0Iks9cTQ[/video]
Jimmy
Dunno what I done but its working.
Had 0.1 ohms from 12v on the gauge to battery with the key in the ON position.
0.1 ohms Ground at the battery to the gauge.
0.1 ohms from the gauge to the dizzy.
I did change around a bit of wiring with the low oil pressure light the other day.
But I can see how it would change anything.
Headless hula
Okay. Gotta ask. What in the fuck is a dizzy?
Jimmy
I was bring optimistic with the ski tow.
It was never going to fit.
How they said it fits a small block??? I dunno its not even close.
So i might even bring something off the transom to stiffen it up.
Its gotta pull my fat guts around.
Jimmy
Are butterflys on a single carb scoop a bit much when its only carbareted? images (26).jpg
Jimmy
Put a new winch strap on the old one was getting a bit ratty and covered in fiberglass resin [emoji4].
Gave it a good grease and hit it with the wire wheel.
It might be a regular thing I might do, roll it out to let it dry because the winch had heaps of surface rust on the inside.
Jimmy
Finished off the bilge pump outlet.
Im wasted talent, should been a plumber used a railshower wall elbow to give it a nice finish.
This stuff brings back horrible memories [emoji31]
Jimmy
Got a new steering wheel hub, I still gotta find a steering wheel the old one's a bit perished and the cap screws are seized in the old hub.
But I'll wait till after we get it in the water.
Jimmy
Is this boat wrapped?
Na painted, looks good though.
Just got a few pinstripes and the name down the side.
After summer i might get all the small marks and chips fixed up and get a clear wrap over it.
The paint marks so easy.
Its got stone chip in it already from the few times I've had to trailer it places.
Jimmy
Hey mate. Why did u blurr out the name , what does it say ? [emoji202]
Have to wait to Christen it and do the whole ceremony thing.
Apparently, each and every boat is recorded by name in the Ledger of the Deep and is known personally to"Poseidon" or" Neptune" the god of the sea.
So u have give back the old name and he'll erase it from his book and all the bad omens go with the name.
Then u say will u accept the new name ect.... then u bring out the 🥂champagne🥂...
Dont worry I'm itching to show everyone.
We gotta do this properly, we dont wanna jinx the whole show.
So patience young grasshopper.
milkmoney
Ok. I guess lol. I have no patience, hurry the fuck up lol [emoji6] [emoji106] [emoji202]
Jimmy
Its been 4 years I dont think another 10 days will hurt ya lol.
Just hope this ski tows finished before the end of the week.
It in getting welded up properly, my bird shit welds wont hold my fat ass.
I'm waiting for a fuel gauge too but it can wait till after inspection.
Taboma
I'm just surprised you didn't leave the shower head on your custom bilge pump outlet --- Bingo, a transom shower :D
Jimmy
I wonder what the wife would think if the one outta the ensuit went missing lol
Jimmy
Just dropped it off for final inspection.
Christening ceremony will be later this afternoon... if all things go well in this inspection.
15mph-18mph winds this afternoon so may not beable to mess around too much but we may find a sheltered spot somewhere on the lake.
milkmoney
Post the real pic we have been waiting for, jumbo, ( mate)[emoji202] [emoji4]
ElAzul
Well-Known RDP Inmate #211
Been following your thread from the start:thumbsup. I have dear friends that live in Sydney and plan to visit soon Australia has been on my bucket list.
One question tho- is there any bodies of water down under where there isn't some sort of creature lurking that wants to kill or eat you?
Jimmy
Gotta run the gauntlet everytime.
Jimmy
Im having a bad day [emoji45]
Theres a blockage between the filler bottle and the leg so they couldnt fill the gearbox up.
Theres a few other small things needs doing like earth the fuel tank.
Put a fuse straight off the battery.
Battery isolator.
Trailer needs tyres.
They said it looks good, i just gotta pull the drive to see whats going on. View attachment 596998 rps20171106_165143.jpg
Headless hula
Found the gear lube issue.
May need to turn the sub titles on for these ones.
Shout out to Hula who was on 24hr tech support, thanx mate.
Hey man, no worries!
Glad we got it sorted!
Jimmy
Yay it passed! The only thing they picked on was the tyres on the trailer need replacing and the neutral start switch isnt quite in adjustment.
So theres probably 1 more days work in it before I can take it out.
Need to jump through a few more hoops to get insured because the boats over 20 years old. But its only paperwork.
Taboma
Interesting to note, marinized starter and alternator not required and only carb requirement appears to be flame arrestor.
Are these items exempted due to having a partially exposed engine ?
Congrats !!
Jimmy
Congrats !!
From the way they were saying i think all the No boxes are just leverage for the insurance company if somthing happened.
Taboma
Hmmmm, so Jimmy blows it up at the fuel dock, claims guy points to sign off sheet --- "aha, should have run a marine starter" :eek:
Shouldn't be a problem, from what I've read on RDP, a good number of members have swapped out for whatever's on the shelf at Autozone and they're still here :rolleyes:
