Blackmagic94
- Apr 4, 2017
- 5,364
- 7,369
If you had a 548 tall deck with 9.3:1 compression what blower would you run and how much boost could you run on 91 octane at havasu elevation with a carb setup.
If I was going to build this motor today. I would set it up with a crank trigger ignition. Then the size of the blower wouldn't matter. This runs super well. I can't take any of the credit for it. Ray Beers kept the boat stored in a garage since 1982. I was just lucky enough to be able to buy it from him two years ago. It was my dream boat that I watched run 111 back in 06 on a radar gun. I run it on premium 90 Ethanol free with 100LL mixed. It has aluminum Brodix heads. The funny part is it is pretty good on fuel for the most part.
you can also pick up a few Ponies by getting the traditional gear drive loads off the end of the cam.
Its good shit!
You can run a coil on plug application???
You need a distributor regardless.
on a BB Chevy?You can run a coil on plug application
Yep BBF as well, here is a mopar. This goes in place of the distributor.on a BB Chevy?
on a BB Chevy?
Niiiiice. Be still my heart....Never seen that before. Trick idea.
Jesel/Indy heads....
Cant tell if it is a B or an RB, need to see the other side.
Yes but you need a multi output ignition box, and a dual signal setup, usually a 4 tooth crank trigger and a single tooth on the cam (a gutted distributor works well and simple for this).
If you aren't doing efi i would stick to a dizzy, but moving the ignition trigger from inside the distributor to the end of the crank shaft has far better timing accuracy as it eliminates all the mechanical slop along with the fact that running a bigger diameter wheel (7-8" vs 2" diameter) means less deviation in the actual manufacturing accuracy, as thousands of an inch mean much more in degrees on the smaller pickup inside the distributor.
Have any more pictures of the Chrysler? I’d like to check it out. [emoji1303]
Thats pretty trick. The shit you can learn here.
I bet i know a guy that has a machine shop and could make a billet cap for a distributor cam sync sensor
The first one is factory ford from a 1995-01 ford explorer with a 302cidThats pretty trick. The shit you can learn here.
So now that you have this knowledge are you going to step up and run a 14-71IMA need a moment alone...
The load is driving an oil pump.
It also gets takes it off the valve train. Like I said....its good shit!
Crank trigger is good shit, no doubt. But the cam still needs to drive an oil pump unless you are using an external setup, and that is the load on the cam.
Mopars drive it off the timing chain side anyway, not the opposite end. Mopar FTW!!!!
Brian
Nah....looking for an easy 7-10 PSI. No need for race gas. UCH just wants to be into the 60s.
Brian
Did you check over at Good Vibrations?
http://goodvibesracing.com/blowers.htm
Racing Junk might have a few advertised
https://www.racingjunk.com/search?quickSearch=1&categoryId1=&searchString=10:71+supercharger
Sorry,
Off track. I won’t thread-jack.
Back to blowers! View attachment 681461
Maybe you can B.S. Brian into making His thread into a "BlowerFest" thread instead.
That way everybody is covered..
Here’s my dads 14-71 with a chiller. MSD clears but a pain in the ass to get too. Cap and distributor can still be removed.
on a BB Chevy?
