6 volt or 12 volt in coach
Bigbore500r
With all this battery talk does anyone have a connection with Lifeline Batteries?
I need 6 of there 4DL Agm batteries that are $500 apiece. They are 12 volt and are wired for 24 volt for my coach.
I dont .... but i'll take this opportunity to tell you that those 3 blue-top optimas you put in the boat made it to Summer 2018! What is that, 8 years? Crazy
DaBank
That is awesome. I believe right after I bought those the company was bought out or something, because every since then they have not been as good?.
Plus 8 years in heat and a big stereo is great. Plus I think the quailty of the correct built in charger helped.
Bigbore500r
Yea i keep that charger plugged in at all times. Thanks for doing it right!
2FORCEFULL
if your 120V load was larger than 3.3 amps yup. Fuse and cable size.
The pull off the 12 battery bank is 10X @ 120V12 - plus the losses the cables induce, and the inverter loss + puekert.
UD
so here's what I found,... the inverter only puts out 120 watts when you use the cig plug... and only 200 watts per plug.. two plug inverter...the way I did my last rv was I put a inverter right above the battery box and ran an extension cord to the tv...I was try'n to get away from that idea because this rv has a 12v and 120v power right at the tv...
Do you have room to install a new hardwire inverter? I assume 120V receptacle has #14-12 awg wire. Could keep factory 120V receptacle and just give it the capability to have 1440 watts
2FORCEFULL
I was thinking of doing that, but this ol desert rig is turning in to a money pit quick, already 6 new tires, 3 new batterys, two tv's, two dvd players, fixed the gen, the water heater, and the furnace..
RCDave
Wasn't it brand new???
LGETT
Diving In
Whatever config allows the most amp hours that fits in the space - Either serial 6's - or parallel 12's.
Not sure - weigh each combo - the one with the most lead wins.
UD
Now that is a fact!!!
AH's, Lead Weight, low amp conditioning charge to knock down sulfation
