HDPE Panels? Where did you buy from,Lowes?Wrapped a side panel tonight. The black material is HDPE, from a local box store. I located all the t-nuts, held the panel in the boat, and drilled the holes through both the panel, and the boat at the same time. Went and bashed the t-nuts in with a 3 lb. hammer, then covered the panel with 1/2" high density foam, then a layer of 1/4" foam with a skrim, then wrapped it with marine vinyl. All the layers have 3m high strength 90 contact cement.
View attachment 665757 View attachment 665758 View attachment 665759
