twin outboard hallett vector
MARCYTECH
CUTLESS Designs
Recently did some new reeds in the engines as I suspected mine were starting to be pretty worn out. Symptoms are Very hard cold starts and lotsssss of smoke on the launch ramp.Opted to some boysen 2 stage reeds. Sort of an intimidating job but i got it done and it was a great fix. Boat fires right up on the launch with minimal smoke now! The new reeds came with shorter bolts too as the stock ones block a lot of the reed cage. Pretty cool!
Had it out for 4th of July and we had a great time.
MARCYTECH
CUTLESS Designs
It’s time for new and additional gauges. I want to go with livorsi but am having trouble deciding on looks
I’m leaning toward white face, chrome race ring and black angle bezels
Other options are silver face with the rest the same or stick with black face like I have now?
Anyone wanna give their opinion?!
Here’s some pic samples. My dash is the one with the black gauges
ChrisV
I'm a fan of silver gauges. More classy look for your boat.
lenmann
Definitely a nice upgrade on the gages, really classes up the dash and gives it a more contemporary look. Well done sir!
papabear639
Awesome boat...If it were mine, I'd go with what is in the center picture. The picture on the right works really well because the gel has silver in it and it ties it in., Your boat has other black accessories in the cockpit that the black angle bezels will tie into.
counterpart7
White face, chrome race ring and black angle bezels
White matches your boats base, I think silver would look out of place personally. White is timeless.
lenmann
Different yellow boat Len. 🤣
Ooops, starting Wednesday mornings with a bloody mary is starting to look like a bad life strategy. Thanks for keeping me on my toes.
ChrisV
More like a great time! Enjoy!
MARCYTECH
CUTLESS Designs
Summers comin so I wanted to get a head start on some upgrades I’ve been wanting to do.
First thing was adding some water separators for the fuel system. Just a nice piece of mind I guess!
I also drew up and made some fender holders to clean up some of the mess under the hatch since I don’t have ski lockers to shove them into. Got them powder coated black and I couldn’t be more stoked on how they came out.
MARCYTECH
CUTLESS Designs
Got the gauges mounted up and holy smokes am I completely happy with the way they changed the look of the dash. Just gotta wire them and we’re off to the river for Easter!
Here’s a before and after
Any ideas of what to do about that god awful glove box cover? I was thinking of getting a billet offering from Eddie marine. Not sure what color I’d do? Yellow? Black? Machine finish? I wish it wasn’t there honestly but I’m stuck with it for now.
MARCYTECH
CUTLESS Designs
Took the boat out to Elsinore today to make sure everything’s working right after all the work over the winter. The engines are runnin like tops and everything’s perfect. Wife and baby had a great time! Headed to havasu this weekend and gonna rip up to the cp regatta at pirates with some friends. Good times ahead!!
MARCYTECH
CUTLESS Designs
Winter project in full swing over here! Redoing the engine and tab set up finally.
MARCYTECH
CUTLESS Designs
Updates!
I dropped off the boat at WOT marine on December 7 and lots of progress has been made!
First off they found the transom was mostly wet and rotten so the project snowballed
So far they have done an all new transom and knee braces in coosa board and glasses it all in. Since we did a new transom we decided to cap it also so that should look cool. Here’s some progress pics. Can’t want to see it after the gel!
Looking good! I don't even want to know how much that work cost! The good news is, with Coosa, you won't have to ever deal with it again. 👍
MARCYTECH
CUTLESS Designs
Some more updates! The areas in the bilge that didn’t get painted are getting carpet.
Gel on the outside is done as well as a rear cap! So happy with the work wot is doing
MARCYTECH
CUTLESS Designs
In the thick of two projects right now. 4x4 prerunner square body explorer and this boat. But it’s March and the boat has taken priority lately.
I’ve been reluctant to start because I didn’t know exactly how I wanted to rig this thing but I came up with and decided on a plan and layout.
For the outside of the transom I made some baseplates that will sit inbetween the transom and backplates to help spread the load
Inside the boat was the hard part to figure out. The engine bolt holes split the stringer pretty perfectly so that game me an opportunity to tie the engine bolts, transom, and stringer/knee braces all together fairly easily.
I decided I wanted to mount all of my “equipment” to the main base plate I was going to make so laying stuff out took time cuz I wanted it to look as nice and organized as possible.
Everything is drilled and tapped into the 3/8” base plate so no extra holes have been drilled into the new transom!
Here’s what I came up with so far. The center pump is going to control the two jack plates. I decided to go with electric Lenco trim tabs to avoid having 2 extra pumps in the boat.
Next will be figuring out routing for fuel, hydraulic lines and wiring of course but we’re off to a decent start so far!
Everything got taken off today and sent to the powdercoater.
MARCYTECH
CUTLESS Designs
Some more updates. Still unsure how I want to bring the lines for the jack plates through the hull. Anyone got pictures of nice rigging so I can get some ideas?
Anyways. Here’s some pics
NeedlesRat
These are how the hydraulic steering lines on our DCB is. Very clean, and made by IMCO Nevada. Don’t know if it could work with your setup but worth a call to them.
MARCYTECH
CUTLESS Designs
I like both of those options and was hopi g to find exactly that. I’m going to call them and see if they have them in a -4 size because that’s what the jack plates use
Thanks! I’ll probably put one bulkhead infront of each engine. As low as I can without drilling through the coosa in the transom. I really want to avoid putting more holes in that stuff
22Shockwave22
Hardin Marine has some also,
I'd also call Teague and ask them what's available, they might be able to make a -4 for you.
MARCYTECH
CUTLESS Designs
Came up with a plan for the Jack plate lines that I’m happy with. Made my own bulkhead plates with some 90° bulk head fittings getting lines made tomorrow!
Things are getting checked off the list little by little!
