HST4ME
- Nov 9, 2015
- 6,999
- 15,935
I'll take my 09 dmax that isn't going to give a fuck whats hitched up behind for the next 300k miles.
Replace pads and rotors.It’s kind of both but only when I’m hard on the brakes. The truck slows and stops fine it just won’t stop if I slam on them.
so what do they do To cause a jerking sensation while I’m coming to a stop?
I'd take that old Ford of the Nissan as well, but maybe not the American half tons.I will take the old crappy 97 F-350 that I used to own, anyday over that Nissan.
How about this... one time I am towing 12,000 lbs in heavy rain, down a grade. I have to turn left at the bottom of the grade. I start braking, and my trailer brakes lock up. I let off, and try again...same thing. So I start pumping the brakes trying to slow down to turn (it's a 2 lane hwy with a long left turn lane). If I can't get slowed down, I have to get back over into traffic (my total rig is 60' long). I determine that working the brakes, I can get slowed down. I make my left turn.
I pull over to check things out when I get to a turnout. My trailer brake/light cord had come unplugged. So the trailer brakes weren't locking up, the trailer was trying to jackknife the rig, but didn't.
I will take a long wheelbase, big brakes, old beater, diesel, F-350 over a Nissan any day. View attachment 917054
Sent From Tapatalk
You may be right on the brakes, I never really looked at them while I owned it. LOL. I know it had a crappy little transmission cooler that I wouldn't put on a Pinto.I'd take that old Ford of the Nissan as well, but maybe not the American half tons.
That ford does NOT have big brakes compared to modern trucks. The rear has 12" drums for God sakes. The 2020 1500 Silverado has 13.5" and 13" rotors with WAY more clamping force than the old 3/4 tons.
The extra wheel base definitely helps but much of that advantage is mitigated by modern stability controls which allow independent braking of each wheel to straighten the truck and help straighten the trailer.
ReallyReally?
Uneven surface condition...caused by a variety of things, but not warped.so what do they do To cause a jerking sensation while I’m coming to a stop?
Define “fade”that my brakes would fade when towing down hill, changed the fluid and now they don’t.
where’s your evidence to suggest otherwise?
Brake fade is a term sometimes used when the brake fluid in the lines and calipers become so hot that it boils. You could have fresh brake fluid and overwork the brake system via heavy towing or doing a track day. Most oem brake systems run dot 3 fluid. In my track cars and high performance cars i run a dot 4 due to it having a higher boiling point. If your boiling your brake fluid your pedal pressure will go away and slowly come back slowly as you pump the brakes, but if you cook the fluid you can loose all stopping power. FYI I've got plenty of rotors that are warped due to excessive heat off my track car.......does happen and is one of the reasons carbon ceramic rotors are offered on high performance vehicles.Define “fade”
what specific symptoms did you experience? If you claim fluid quality to be the culprit...when was the last time the fluid was flushed/changed prior to this incident?
