LakeBeard
- Jun 15, 2017
- 749
- 796
Keep me posted on the Trail Grapplers wear/noise wise.
I have the same, here they are after 27k miles. Noise isn't bad, but I drive w/ the stereo blasting...
I rotate mine w/ every oil change, 27k miles and plenty left.You better rotate those tires more frequent then you change your oil, I've had much better luck with the Toyo R/T's or even M/T's for that matter. I'd say you wont get more then 25-30k of life out of them.
I will give Nitto some props on the new Ridge Grappler, it has held up on our chase truck pretty well.
https://www.instagram.com/p/Bih8U0PBn3d/?utm_source=ig_web_button_share_sheet
To each their own...I prefer the stock look.
I want to blend-in and not attract attract any undue attention.
Slightly bumpy at a walking pace, but they smooth right out when driving.
Noise is much less than anticipated, just a barely audible hum on the highway.
And they track straight, unlike Toyo MTs that have a slight radial pull.
The tire are HEAVY...they feel twice as heavy as the P-rated tires the truck came with.
Slight decrease in felt power, and its downshifting on highway grades that it held in 6th gear previously.
I want to program for tire size, but need an aftermarket tuner to do it, and I like my warranty...
Considering how much stiffer the sidewalls are, I honestly didn't expect it to ride this good.
The Kings obviously play large roll in that.
They are E rated. Run 40-42 psi cold. Ride and wear will be good.
I have 20k on my Ridge Grapplers. Running 42 psi. They still look new. Rotated every oil change.
Also your speedo isn't off. I'm running 285/65/18's also. When I pull up the digital speedo and compare to gps on my phone it is the same.
Update on the Nitto Terra Grappler MT’s:
These tires are great, a worthy alternative to Toyo Open Country MT’s (which weren’t avaialble in my size).
They’re amazing in mud, as well as anything off-road that I’ve encountered.
The ride is great for an MT at 35 psi...even at this pressure, which is the lowest noted on the load/inflation table, I’ve got ~900 lbs of excess capacity per axle.
Noise is a gentle hum, not bad at all.
And they’re wearing great - here they are with 20k miles on them. I do rotate and rebalance them every 5k miles. View attachment 756608
Nice! Thought you had Icon delta joint upper arms? Looks like a stock arm in the pic.
Yeah there’s nothing like selling it right after you’ve done the mods you really want…may as well get max enjoyment out of themNice work. I have had a similar itch. Next truck I'm doing it all day 2.
