Don’t get me wrong the Kings were worth the wait View attachment 676090
Oh man if I did that you wouldn’t see my KingsYou need new tires and less poke on the wheels bmx boy....lol
I don’t even have the truck yet but I’ve ordered the Kings LOL, since there’s 4-5 week build time. I guess I’ll suffer in the meantime [emoji4]
Going to go with King 2.5 coilovers up front, 2.5 piggybacks in the rear on stock leaf packs.
Standard King valving.
2.5” lift in front, minimal in rear, want to level it out and not lift it unnecessarily.
Depending on the UCA’s my truck came with, I’m going with Icon Deltajoint UCA’s, or Camburg Uniballs.
The brand snob in me wants Camburg.
But the Deltajoints are sealed and don’t require maintenance (or make noise) like uniballs.
I’ll run the factory wheels with 285/65-18 (33”) Nitto Trail Grappler MT tires. They’re the closest thing to Toyo Open Country MT’s...which is basically the same tire. Toyo MT’s aren’t available in this size.
What do you guys think?
Moderate off road, nothing really high speed out here. Getting to hunting spots. Lots of clay and mud. And epically shitty roads LOL
I had deavers on my 3/4 ton.
This is a half ton with way softer springs, I’m gonna see how it is with the factory springs before I decide to do deavers.
Nice! The stock Rancho's are terrible. Hopefully your King setup will arrive sooner than expected!Fresh off the truck.
Let’s see how long I’ll have to live with these crappy Rancho shocks
Looks like I have factory stamped steel control arms, so I can run Icon Delta Joint UCA's.
Apparently GM offered these trucks with aluminum arms also.
And beginning in 2016, they added forged steel arms to the mix.
From what I gather, there's no rhyme or reason on which arms your truck was built with.
You're restricted to running Icon Uniball UCA's if equipped.
The Camburg kits are all uniball, and they come with adapters no matter what arms your truck has.
Different UCA companies vary in what they offer, so do your homework.
This is all new to me...why does GM make shit so complicated LOL
Exactly. Fox had a ton of issues. Aluminum arms would gain a 1/2 inch more lift with 2.0's being cast thicker. I have a 17 with stamped arms.
Did you check out Total Chaos uca's?
I want to give Icon’s Delta Joint a try[emoji106]
Im cuious how the UCA construction has anything to do with which aftermarket arm you can run? They should all use the same frame mounts (GM leanred their lesson from the early 2000's when they built their 2wd with coils and 4WD and some other packages with torsion bars), and I cant imagine knuckles being much different if at all.
From icon and what I’ve found:
This system ONLY fits vehicles equipped with the large spindle taper bore (.783"). For models equipped with small spindle taper bore (.6875") see part #K73002
The stamped steel arms have a smaller spindle taper bore.
The aluminum arms have a larger spindle taper bore.
So I guess it’s the spindle?
Very interesting. I wonder if you could just have it bored out to the larger diameter taper? Or, I bet you can find some take off factory knuckles (they aren't spindles. I hate when companies use the incorrect terms then they get adopted by the masses that dont realize better).From icon and what I’ve found:
I’m not hating these tires.
I’m thinking about keeping them and saving a grand...
I think this is going to be a real nice setup.
Done yet???
So the shop that did the install did cut the service perch/stop off. I have about a half inch between the arm and stop. Haven't made contact with it yet. Might cut it off also.
Looks great. My stock struts and shocks were done also. 17k miles.
they sure have been good for meI don’t even have the truck yet but I’ve ordered the Kings LOL, since there’s 4-5 week build time. I guess I’ll suffer in the meantime [emoji4]
Keep me posted on the Trail Grapplers wear/noise wise.
View attachment 689148 Those stock wheels are killing the look.
Wheels will make a huge difference.
Here is one if the many trucks I should have kept.
Slightly bumpy at a walking pace, but they smooth right out when driving.
Noise is much less than anticipated, just a barely audible hum on the highway.
And they track straight, unlike Toyo MTs that have a slight radial pull.
The tire are HEAVY...they feel twice as heavy as the P-rated tires the truck came with.
Slight decrease in felt power, and its downshifting on highway grades that it held in 6th gear previously.
I want to program for tire size, but need an aftermarket tuner to do it, and I like my warranty...
Considering how much stiffer the sidewalls are, I honestly didn't expect it to ride this good.
The Kings obviously play large roll in that.
You better rotate those tires more frequent then you change your oil, I've had much better luck with the Toyo R/T's or even M/T's for that matter. I'd say you wont get more then 25-30k of life out of them.
I will give Nitto some props on the new Ridge Grappler, it has held up on our chase truck pretty well.
https://www.instagram.com/p/Bih8U0PBn3d/?utm_source=ig_web_button_share_sheet
The 33" Toyo's shouldn't have any radial pull, maybe in a 37"+ tire but that is going to be damn near most every manufacture.
