HydroSkreamin
StressEliminator
- Jan 12, 2014
- 2,143
- 5,846
What is the sealing tape like? Is it thick? foamy? how much surface irregularity will it accommodate?
Is your resin to glass ratio about the same as open layup or can you glob it on expecting the bag to squeeze out the surplus?
I saw that you rolled the glass out to minimize any trapped air, does this have to be perfect of will the vacuum pull the air out?
Are you going to bag the glass encapsulating the foam rails?
Is that really a 30' Speedster center pod? Where do you get one of those? Pick-a-Part for boats?
Lenmann, glad you’re as excited as me about this stuff.
I’ll answer your questions in order;
Tape-it’s the consistency of Silly Putty, but kind of like butyl without the mess. It’s about the size of your pinky tip, and it’s 1/2” wide by 1/8” thick. We always attach it to a gelled surface for best adhesion and sealing. You wouldn’t believe how much of a leak path a spider crack in gel is. I could hear it whistling with the stereo off.
Here’s a new roll of Tacky Tape.
Resin amount-I didn’t apply it any more wet than normal, but I did roll it out decent, and maybe I could back off on that, but force of habit had me rolling more looking for dry spots that needed more resin than to roll excess resin out. The vacuum bagging should get it better than I can roll it.
Bagging subsequent layups-yes!
Pod-see next installment
