Why is that? We love our Baja ShelfNo recommendations on builders but I would encourage you to think real hard about that Baja shelf. Everyone I know that has done that wishes they had gone a different route.
What finish is your pool bottom?View attachment 1367068
We love our shelf, but we made ours deeper than most since it is so hot here in Phoenix. Ours is 17" deep. If you intend on putting some kind of chair on the shelf, make sure you check the recommended depth of the water for the chairs you like. The majority of the loungers only work in very shallow water (or they have to have an extender added which looks unsightly, in my opinion). We went with chairs instead of loungers and they are comfortable and way more useful, IMO. So, find chairs/loungers that you like first and then ink the depth of the shelf in your plans. Definitely put in an umbrella hole or two, as previously mentioned.
Also, be sure that you put a light on the shelf. Our original plans from our worthless pool builder didn't have it and thankfully we had a friend who is a pool builder look everything over and make suggestions. The shelf would have looked dark at night, but with the additional light now the pool is evenly lit.
Fire bowl water fountains for the win![]()
I like the color, is it rough on feet and bathing suits?View attachment 1367253
This is Shasta's "Frisco Bay Blue". We wanted a bright blue that looks like the water in the BVI. Very happy with how it came out.
NIce.Not out there, but we went with a reputable pool builder out of Riverside and we still had issues. Overall, we are happy that we have a pool, but I wouldn't expect to have any contractors do anything around my house without having some sort of issues... It may just be me, but I expect a certain level of professionalism from these "big name" contractors. One small example of the kind of crap we experienced was when they brought their truck out for dirt removal, they left about 2 quarts of oil in the street right in front of my house. I mean, if you know that your truck leaks that amount of oil, how about you put a f-ing pan down so you don't leave oil stains all in front of my house man! Anyway... Enjoy the build experience! It will all be worth it in the end.
Here's my build.
It’s white plaster with blue quartz. I’m not sure of the exact blue. I’ll try to find it in my paperwork.Water looks good
Do you remember the color of the pool finish you did ?
Definitely go with a pebble finish. It will outlast plaster twice as long. Im told the white plaster is not as good as it used to be. They have different size pebble finishes. They have a “standard” then a mini, and now micro. The smaller the pebble the smoother it would feel.I like the color, is it rough on feet and bathing suits?
My sister in law had temporary fence and posts put up to pass inspection... There are holes in the concrete but at least no fence to block your view.Here's my next dilema, If I don't want to fence in the pool, I need to install slats in all of the chain link fencing. I don't like slats, I don't like the way they look, and in my opinion they catch the wind and want to rip the fence out, and it's also a full 1 acre of fencing. That being said, my lot is sloped, so the raised area where the pool is going is not the same height along the length of the area.
I don't want to take away from my view, and the S/W corner is where we plan to put the spa. So i'm debating whether or not I put a fence down on the ground below the pool, or a short one on top of the wall. There is a retaining wall all the way down to rest of the lot, maybe this still counts as 6ft????
Any ideas that I'm obviously not thinking of?
View attachment 1367405 View attachment 1367406 View attachment 1367407 View attachment 1367408 View attachment 1367409 View attachment 1367410
I’d be worried about liability with not having it fenced off.My sister in law had temporary fence and posts put up to pass inspection... There are holes in the concrete but at least no fence to block your view.
Their yard is fenced off, just not to county code for a pool. The temp fencing got them past the inspection. The OP has fencing, just doesn't want to block his views with fence that will pass inspection.I’d be worried about liability with not having it fenced off.
what are the lit balls floating? amazon?View attachment 1367068
I have the standard chain link fencing around the property, so I'm guessing it's the 2". My wife is starting to lean a little towards the slatting the chain link because she wants a little bit of privacy.you could do mesh on the outside attached to chain link fence. just have to make it not climbable. after inspections if wind blew it off, and you don’t have budget to “repair” then so be it. Lol
if your chain link is the small link you would be ok. Don’t need anything, 2in or smaller.
other option is to do automatic pool cover Or even a safety mesh cover. Then your view etc would remain exactly as you have.
the removable safety fencing, if considering check with building official first it’s about 50/50 with cities allowing for pool safety.
typically most cites / counties require
door alarm, floating alarm, fencing/gates.
but a safety pool cover can eliminate 1 of the above.
There are different types and different areas either require them, require a style or don’t at all. In San Diego County I had to have one for both the pool & spa . And the bobber type like a chlorine tablet floaty was no longer ok. So I had to buy two of these side deck mount ones that when the water moves the pressure changes sets the alarm off.I have the standard chain link fencing around the property, so I'm guessing it's the 2". My wife is starting to lean a little towards the slatting the chain link because she wants a little bit of privacy.
I'm good with a door alarm, we have our first grand baby, so when she's walking/running age, I'm not gonna be mad if I get an alert that she ran out back.
Whats a floating alarm?
I had to buy them as well. One for each "body of water". Used sticky tape to get past inspection then removed them.There are different types and different areas either require them, require a style or don’t at all. In San Diego County I had to have one for both the pool & spa . And the bobber type like a chlorine tablet floaty was no longer ok. So I had to buy two of these side deck mount ones that when the water moves the pressure changes sets the alarm off.
In theory it’s good. But if you have a spa spill way that circulates or even a skimmer hose that could hit it, it triggers the alarm. So in reality they don’t work as intended.
I bought two Pool Guard brand sensors. Because the final sign off was before the plaster and water in the pool. I just had to show two new sensors in the box. After I passed my final I chose to return one alarm and keep one alarm. The Pool Guards are $250 ea! Plus you’re supposed to drill a hole in the coping to hold it. Yeah that was not happening.
Here’s a picture of the box.
however, DO NOT leave the umbrella in it for an extended period of timeIf your putting in a Baja shelf, be sure to put a hole in it for the umbrella.
Yeah my inspector told me as long as I showed him two new in the box sensors, and a copy of the receipt, I was ok. I kept one, for just in case we had people over with small kids that could not swim, I could set one in the pool. I also have a Ring Camera that views the pool and records if someone’s around the pool. I can also make sure the pool guy does his job each week too!I had to buy them as well. One for each "body of water". Used sticky tape to get past inspection then removed them.
I think we've decided to slat the fence, it gives a little privacy, and we can always take them out if we don't like them. we're gonna build something low on top of the block wall probably around 18", most likely rusty corrugated steel, similar to Topock Marina. The outdoor kitchen I'll be building will be similar.Here's my next dilema, If I don't want to fence in the pool, I need to install slats in all of the chain link fencing. I don't like slats, I don't like the way they look, and in my opinion they catch the wind and want to rip the fence out, and it's also a full 1 acre of fencing. That being said, my lot is sloped, so the raised area where the pool is going is not the same height along the length of the area.
This thread can be Hijacked, my wife may want the same chairsHey Babe,
I like those chairs, are you happy with them? Mind sharing the brand and any review? Maybe in a DM to not thread jack.
Hey Babe,
I was not expecting them to be that pricey, LOL.I got them from Tupelo Goods (link below). We really like them and they are way more functional and comfortable than the loungers, in my opinion. The only issue we have with them is because our shelf is so deep, the front of the chair floats up a bit, so that's why we have them up against the wall. Honestly, I don't think I'd want them in the middle of the shelf anyway, so it's no big deal to us. I'd definitely buy them again. The company recommends a depth of 11", but told us that they would work at our 17" depth. Just something to consider.
Loop Modern Outdoor Lounge Chair
The tupelo Loop Lounge Chair is the perfect addition to your outdoor space. With its everlasting durability, superior comfort, and timeless aesthetic, the modern Loop Lounge Chair will elevate any landscape, patio, fire pit, or gathering space. Price is for each (1) chair. Weight capacity: 500...tupelogoods.com
https://nationalconstructionpools.com/ Give Tracy a call , his was a neighbor when I lived in Desert foothills . He does some very nice pools in Bullhead and the surrounding areas.@Melloyellovector
We're waiting for a 2nd rendering, but we're thinking about getting a 3rd estimate from another builder out here. Do you have recommendations for who or who not to use?
Do you do jobs out this way?
Hello!!!!! This is @DaytonaBabe we are talking about. That is how they roll!!!I was not expecting them to be that pricey, LOL.
Whats your name, I'm gonna give him a ring in a few.https://nationalconstructionpools.com/ Give Tracy a call , his was a neighbor when I lived in Desert foothills . He does some very nice pools in Bullhead and the surrounding areas.
Keith and Maureen , we lived on la Paloma Drive it’s been few years , moved to Fort Mohove so my wife could be closer to the hospital were is employed in the ER and on call sometimes . Tracy probably will remember us because my wife had her ambulance for her business parked in the driveway Until HOA got complaintsWhats your name, I'm gonna give him a ring in a few.
Thanks my wifes a Nurse as well, but she's over the ER, did it for 20 years.Keith and Maureen , we lived on la Paloma Drive its few years , moved to Fort Mohove so my wife could be closer to hospital were is employed on the ER .
That‘s nice way of putting it, we move to Havasu because was she recruited to fly with Air Evac . After 10 years she was done medical transports and back to the hospital and she also has American heart training Center as a business .Thanks my wifes a Nurse as well, but she's over the ER, did it for 20 years.
Cool thanks, just got off the phone with Tracy, he's gonna try and come by this weekend while I'm in town. Sounds like he sorta quit doing pools unless it's friends or family, apparently I made the list.@dirtslinger2 , also,my wife has another friend that she has worked with that her husband is a pool contractor and builder in the area . Mynk Construrtion also has build some nice pools and houses . John Mynk 928 234 8735 . At least you have some more options to get some prices from some local builders .
Yeah used this guy too. Never seen him again after giving them a deposit. Basically I had to general the pool as the crew would show up and had no idea what to do. Imo it was a shit show and extremely poorly handled. The end result was good but a pain in the ass the whole time. Would definitely look elsewhere.Brian worked for Sandcastle when we built ours. He saved me thousands when he assumed a slope angle on the estimate.
Brock was stand up & ate the extra labor & rebar redo the inspector demanded. Been a great pool.
I don’t know anyone out there I’d refer. Basically I only see and hear the bad. So hard to say who I’d trust, lol@Melloyellovector
Thanks for the reply, it's hard to pick, if you use the interwebs at all, you'll hear that so and so is the best, then followed up by so and so is the worst.I don’t know anyone out there I’d refer. Basically I only see and hear the bad. So hard to say who I’d trust, lol
I don’t do jobs out there, Iv talked about it for couple years about getting a crew set up. Been to busy in Ca
Shoot me a PM, I wasn't able to send you one.Keith and Maureen , we lived on la Paloma Drive it’s been few years , moved to Fort Mohove so my wife could be closer to the hospital were is employed in the ER and on call sometimes . Tracy probably will remember us because my wife had her ambulance for her business parked in the driveway Until HOA got complaints
There are some cool deck types of materials that you can tape lines on the base coat, and skip trowel the color coat. Pull the tape, and now you have "grout lines". The only ones I did were years ago, and for heavy traffic areas. They had about 5 years before needing touch-up or repair. I honestly don't know how long they'd last in a residential situation. It was pricey to do it that way.Since people like pictures here, here's our 2nd rendering that showed up last night.
Thanks for your reply, The one builder who is recommending the kool deck, is the same builder that is telling us we don't want dark tile, or a Salt water pool, all based on the hardness of our water out here. He would be installing the Kook Deck on fresh concrete, and from my research that appears to be the way to go with it. He appears to have a good working knowledge of pools in this area and fighting calcium.We’re in Boulder City. When we had our pool built 4 years ago we were on a tight budget. We had a decent amount of preexisting concrete so the builder recommended cool deck to have it all match. He would not warranty the cool deck on the existing concrete though. It starting peeling off within a year. I would not do it again.
We have very hard water out here and we have a calcium build up problem.
We went with a salt pool because my husband has eczema and salt water is supposed to be easier on it. The builder did not recommend it because of the hard water. We should have listened. We are on our third salt cell already and we are constantly fighting pH issues.
Your rendering is beautiful. If you stay on top of cleaning and brush the pool daily, you should be fine. We are not good at that.
