riverroyal
- Nov 4, 2007
- 14,490
- 20,193
You have 2 floor jacks?
Baller
Baller
Nice boxYesterday I put on a set of Shock Therapy tie rods I got on their Black Friday sale. These guys make nice parts and pieces.
Some of these machines have quite a bit of toe change through suspension travel. Eliminating the bump steer makes the car a lot more consistent, stable, and less fatiguing to drive.
Their outer tie rod pins are adjustable to eliminate bump steer. I made up a little setup to measure the bump steer with my laser level attached to the brake caliper. The laser level shined a light onto my cabinet where I stood up some cardboard. I then just cycled the suspension and made marks on the cardboard at full compression, full droop and ride height. I then played with the outer tie rod shim stack that came with the kit and did that several times until I got the tightest measurement, and there is almost no toe change now.
Nice box
I think I am going to have to do some something like that on my spare tire mount....for some reason the guy that built my cage made the spare tire mount only carry up to 30" tire...
Can the Talon run a 32" without major transmission work? I know the YXZ requires a swap of the first 3 gears in the trans
Thank you! Are you the one selling or just found it on Craigslist? I think we have the sway bar mounts, but not the end links with the rod cage, so I may check if one of our friends want the mounts and get that deal.I’m
Cognito RZR Sway Bar links, Rod Cage, Sway Bar Mount - atvs, utvs,...
These parts were used for 2 trips, Cognito rear sway bar links, rear rod cage and rear sway bar mounts. These came off my 2021 Polaris Rzr Turbo S4, they will fit other models, please check website....inlandempire.craigslist.org
I’m not selling just found them the other day when looking for RZR upgrades on the cheap.Thank you! Are you the one selling or just found it on Craigslist? I think we have the sway bar mounts, but not the end links with the rod cage, so I may check if one of our friends want the mounts and get that deal.
Sorry @LargeOrangeFont if this is thread jacking.
Dammm that looks good !!I forgot to update…
The car is in Havasu on Bluetooth shocks until tomorrow afternoon.
Had a nice dinner at El Parasio before heading home
No worries. That looks like a great deal for that stuff!
Picked it up this morning for $325! Thanks again!I’m not selling just found them the other day when looking for RZR upgrades on the cheap.
Good to hear about the AA clutch and tune, my R needs a Clutch for the dunes, and they were at the top of my list.Finished installing the new AA clutch kit, installed and flashed the car with their Stage 2 tune that runs 91 octane fuel. The car has stock front shocks in it right now, but the revalved rears.
Took the car out yesterday for a 30 mile run with my daughter. Very happy with all the changes. This is what I was hoping to achieve. The car is more responsive and faster. It spins the tires a bit on the street out of the hole in 2wd. Throttle response is much more crisp, and the car puts power down much better. The AA recommended clutch weight setup was right on the money. This was my first time using them, and I will use them going forward.
The rear shocks are working awesome, there is big difference in compliance and ride quality with just the revalved rears. The fronts will be done hopefully in the next week or so.
I can really feel the difference of the front bouncing through stuff and the rear absorbing bumps and dropping into ruts like it should. The 2 ends of the car are fighting themselves a bit now, but it is still a huge improvement over stock.
DC Shock Services was great to work with and did a great job for me. Excited to get the front shocks to complete this thing.
@LargeOrangeFont i already did exhaust and clutch kit I want to do the tuner did you upgrade any of the intake or charge tubes I heard it’s recommended to do them if doing a tuner what do you think?
That is the UTV Kingz unit. I have my rear seat backs lowered on the frame for the kids so my rear harness bar is a similar height to yours. The mounts can be adjusted for the height of that crossbar anyway if you wanted more bed clearance for instance.This looks like the UTV kings spare tire rack, I am about to buy the thing but curious, I have an aftermarket cage and my crossbar, where the harnesses strap on, is about 3/14 inches from the bodywork to the centerline of the tube. The pics look loke yours is a bit higher, I can fab some new stand offs for the pivot points...if necessary. How high is your crossbar?
Awesome carrier, I’m on my second one (2nd car) and no failures after 6000 hard milesThanks, LOF.
I will be modding as you did.
Anytime you wanna ride rzr or pit bikes just let me know me and the boys are always downLooks and sounds like a great trip...I really wish I had the crew for this kind of thing...
Who the hell was wearing shorts out there? How did you convince your wife to go?We did a couples weekend trip from Havasu to Laughlin and back a couple weeks ago. One day up there, a day ride and then one day back to Havasu. It was about 300 miles total, and we stayed at the Tropicana.
I made this rear seat rack storage a couple years ago for my old RZR and it also fits this car. Just pop the rear seats out and pop this in. I had a different bin before, but it did not work with the aftermarket cage.
This is a Plano 108 qt Sportsman’s Trunk. They are available at Home Depot for about $50. I added a strip of 1/4” foam rubber into the channel in the lid making it 100% dust and weatherproof. The lid of this trunk is also reinforced so you could mount other stuff to it for longer trips if needed. We threw our clothes bag, some extra tools and snacks in the trunk. It worked great. We are doing an AZ peace trail ride soon and I’ll be mounting my extra gas cans to the lid of the trunk. At least that is my current plan.
The trunk is just bolted to the storage rack.
View attachment 1196772 View attachment 1196773
A couple pics of the trip
View attachment 1196777 View attachment 1196778 View attachment 1196776 View attachment 1196775 View attachment 1196774
Car is really working well. I’m very pleased with the build and the results. I don’t know that there is anything I’d change at this point.
Had the car at Sand Hollow yesterday.
We’re absolutely in. Steph would go anytime in any weather. I’m the wimp that hates to be freezing. (I’m more of a warm pool fan).Jeff runs warmer than I do. We got a little lucky with the weather. It was 3 days after rain. Cold but no dust on Friday. Sat and Sun were a little cool but windy. Very low dust all 3 days because of the moisture still in the ground.
Convincing the wife wasn’t bad. Other wives were going, so there was peer pressure and other women to talk to. We planned quite a few stops, not a rigorous ride schedule. Goal was to be at the hotel by dusk each night.
Hot shower and warm hotel room every night. Brunch at Topock on Friday, Steak dinner at SaltGrass (really good meal) Friday night and Guy Fieri’s Mexican restaurant on Sat night (very good as well). A couple cocktails and some slot machines… it was a pretty easy sell.
Honestly it was a way easier trip than Alamo, and you’ve done that one.
The wives won a combined total of $1600 on penny slots .
We paid the valet guys at the hotel to self park in the valet lot for security.
This trip was a home run all around. We will be doing more of them, wife was sold and wants to do another one. We can get you on the next one
Well that is crappy!Well.
The rack showed up today and I, being unable to sit around, decided to go after it, you know...just test fit, etc.
Opened the box.
I have a pattern on stuff like this, I find the packing sheet/instructions and lay out all the hardware.
No packing sheet. No destructions.
OK. Can't be that tough to figure out, let me see what I got here...
Waitaminute...what the heck...
See anything wrong here?
Yep. They didn't finish the machining process.
If you flip the one with no holes over you'll see it is drilled halfway through, and threaded...like it would be set up to weld onto the hinge side of the clamp
Some feller overseas was having a bad day. I am not sure if the same feller was bagging the hardware packs, but he appears to have shorted me about 10 1/4=20 lock nuts too.
SMH.
I called the number, sorry only way to speak to us is via the email, so I sent them an email, and I will endeavor to persevere, and move forward.
Yes...got fender washers. Figured they were for the gas strut pins. I am gonna look closely at your pics to see where you drilled for yours.
I have it mocked up as best I can. I am going to have to open up some of the holes, and will probably go up to 5/16 NC grade 8. Once I hog out the holes there in the latch mount pin deal I think the 1/4 bolts will fall right through.
I am thinking I may make some other mods, too.
I have plenty of time to fiddle with it waiting for the clamp piece, LOL. I could set my little bench top mill up to fix it. but don't want to spend an hour on the setup for this deal.
I really appreciate the pics, will follow your lead there. those dogbones deals are the only pieces I have yet to figure out, so...if it isn't too much trouble, I would love those pics tomorrow.
I had to modify the spare tire mount I got to fit my aftermarket cage and 32-33” tires. Got that all done today with my neighbor. The diagonal bars going to the rear harness bar landed right where the spare tire rack mounts needed to go.
View attachment 1178049 View attachment 1178051 View attachment 1178050
