Minis!
retaocleg
15 feet long, 6 and a half wide........
DBMX
I got some extended runs on mine today. It ran great with no issues.... Which is a relief considering this was a bare hull 3 months ago. Probably going to have to go through it tomorrow and make sure nothing came loose.
I always forget how fun these things are to drive. Today was a lot of fun.
Havasu Rehab
Fantastic looking boat
Love it!!
C_J_J_C
Wow.... perfect.
Is that a 10' or 12'?
SOCALCRICKETT
Badchoices03
DBMX
Does anyone know if a 4 stroke outboard (209lbs) would be too heavy for a 10' Schaida?
I know people who put the Tohatsu on theirs and they said its awesome. It's only 5 or 10 pounds heavier than some of the 3 cylinder 40 hp outboards from what I was told. That may be my option if the Yamaha lets go.
I've been wondering what comes on the new ones Schiada is making? There was a FB post yesterday that are few are in process (like the one posted earlier).
They’ve used the Forumla 60 on the double throw down 12 footers. Full cav plates etc.
There’s an article on here of one Schiada did. Gotta be 10 years old now.
DBMX
Yeah... but I was referring to the new ones they are currently making. 2 stroke outboards are hard to come by and I cant imagine someone wanting an older outboard on one of the new boats.
retaocleg
i see jones tunnel similarities in this.......... sides and tunnel look like it..........they made many sizes, deck is different
my point was the hallett mini look like this........
SFV2RVR
Registered Parker Legend
The older Tohatsu 40hp 3cyl 15" shaft motors we used on 10'ers was around 160lbs. I think the newer 4 strokes that weigh 210 are gonna be too heavy. The newer boats are getting the 4 stroke 25hp motors on them from what i've seen.
as long as were going for some new styling howbout some twins? 2stroke, 36hp, at just about 200lbs for the pair. Ya some modifying would have to be done for controls but cant imagine it would be terrible.
Formula 60 is a four stroke.
That would be on the heavier side but if you rig it with everything in the bow it’s doable.. my first one had a little more than that in weight when you added it all up with the jackplate and power trim.. let alone six inches of mechanical advantage because of the setback etc
I remember my first one and for some reason I thought it weighed 125-130 lbs?
boatnam2
Looks like my old river neighbor Dr Dick in sandbar photo.
Flyinfiddy
I believe you’re right! This Nissan NS40C 2 cylinder is same as tohatsu M40C and it weighs 130Lbs. The 2 cylinder M30A Tohatsu I believe weighs 114Lbs.
SFV2RVR
The M40C 2 cylinder weighs around 130. I thought the 3 cylinder weighed 160. I could be wrong about the 3 cylinder though
SFV2RVR
Nope.....I was right. This is the info in the 3 cylinder. Weight is 159lbs
Output
40 hp (29.4 kw)
Displacement697 cc (42.53 cu.in.)
Bore x Stroke68 x 64 mm (2.68 x 2.52 in)
StartingManual or Electric Starter
Control TypeTiller Handle or Remote Control
Gear ShiftForward - Neutral - Reverse
Gear Ratio1.85 (13:24)
Propeller Selection Range7" - 15"
Transom Height15", 20"
FuelUnleaded Gasoline (87 Octane)
Oil TypeGenuine recommended 2stroke engine oil (TCW-3)
Oil Capacity2 L (0.53 US Gal.)
Fuel Tank25 L (6.6 US Gal.) Separate Fuel Tank
Weight*72.0 Kg (159 lbs.)
Alternator OutputOptional: 12V, 130W, 11A (Standard on Electric Start Model)
Max. RPM Range5,000 - 5,700
Start In Gear ProtectionStandard
Thermostat Controlled Cooling SystemStandard
Through-The-Prop ExhaustStandard
Overheat BuzzerO
Power Trim and TiltO
Shallow Water DriveO
Engine lubrication systemPremixed Fuel
NDH2O
Shameless plug if anyone is still looking for a Mini.
