- Sep 13, 2007
- 126,527
- 165,449
I might not be back
Oh no! Lol
I might not be back
That thing is bitchen! Ok, how much? Everybody wants to know!
its all good. You're really my type.I don’t love bonesfab. Lol
want to make sure we get this quoted before edit...lolits all good. You're really my type.
15 feet long, 6 and a half wide........How long is it?
He'll grow on you. ...by his own admission.I don’t love bonesfab. Lol
"it's not a tuma..." the govinatorHe'll grow on you. ...by his own admission.
I got some extended runs on mine today. It ran great with no issues.... Which is a relief considering this was a bare hull 3 months ago. Probably going to have to go through it tomorrow and make sure nothing came loose.
I always forget how fun these things are to drive. Today was a lot of fun.
Wow.... perfect.
Is that a 10' or 12'?
Those are badass! Weren't they called thunder ducks at some point?Rubber Rockets! The fastest rough water mini you can get! The small 2 stroke outboards are sure fun to set on go. View attachment 1233548 View attachment 1233549 View attachment 1233550 View attachment 1233551 View attachment 1233552 View attachment 1233553
View attachment 1233554 View attachment 1233555 View attachment 1233556 View attachment 1233557 View attachment 1233558 View attachment 1233559 View attachment 1233560 View attachment 1233561
Its a 10.Wow.... perfect.
I would ask Marc or Paul. They should know.Does anyone know if a 4 stroke outboard (209lbs) would be too heavy for a 10' Schaida?
I know people who put the Tohatsu on theirs and they said its awesome. It's only 5 or 10 pounds heavier than some of the 3 cylinder 40 hp outboards from what I was told. That may be my option if the Yamaha lets go.Does anyone know if a 4 stroke outboard (209lbs) would be too heavy for a 10' Schaida?
I've been wondering what comes on the new ones Schiada is making? There was a FB post yesterday that are few are in process (like the one posted earlier).
Yeah... but I was referring to the new ones they are currently making. 2 stroke outboards are hard to come by and I cant imagine someone wanting an older outboard on one of the new boats.They’ve used the Forumla 60 on the double throw down 12 footers. Full cav plates etc.
There’s an article on here of one Schiada did. Gotta be 10 years old now.
my point was the hallett mini look like this........i see jones tunnel similarities in this.......... sides and tunnel look like it..........they made many sizes, deck is different
You’ll be looking at the starsDoes anyone know if a 4 stroke outboard (209lbs) would be too heavy for a 10' Schaida?
The older Tohatsu 40hp 3cyl 15" shaft motors we used on 10'ers was around 160lbs. I think the newer 4 strokes that weigh 210 are gonna be too heavy. The newer boats are getting the 4 stroke 25hp motors on them from what i've seen.Does anyone know if a 4 stroke outboard (209lbs) would be too heavy for a 10' Schaida?
Im pretty sure my Yamaha weighs around 190 lbs.Mid 90's 40hp Mercury outboards weigh 177 pounds.
Those bastards from down under are flat ass fearless and crazy.dingis derbis.........you are the balast
I believe you’re right! This Nissan NS40C 2 cylinder is same as tohatsu M40C and it weighs 130Lbs. The 2 cylinder M30A Tohatsu I believe weighs 114Lbs.I remember my first one and for some reason I thought it weighed 125-130 lbs?
The M40C 2 cylinder weighs around 130. I thought the 3 cylinder weighed 160. I could be wrong about the 3 cylinder thoughI remember my first one and for some reason I thought it weighed 125-130 lbs?
Nope.....I was right. This is the info in the 3 cylinder. Weight is 159lbsThe M40C 2 cylinder weighs around 130. I thought the 3 cylinder weighed 160. I could be wrong about the 3 cylinder though
Output | 40 hp (29.4 kw) |
Displacement | 697 cc (42.53 cu.in.) |
Bore x Stroke | 68 x 64 mm (2.68 x 2.52 in) |
Starting | Manual or Electric Starter |
Control Type | Tiller Handle or Remote Control |
Gear Shift | Forward - Neutral - Reverse |
Gear Ratio | 1.85 (13:24) |
Propeller Selection Range | 7" - 15" |
Transom Height | 15", 20" |
Fuel | Unleaded Gasoline (87 Octane) |
Oil Type | Genuine recommended 2stroke engine oil (TCW-3) |
Oil Capacity | 2 L (0.53 US Gal.) |
Fuel Tank | 25 L (6.6 US Gal.) Separate Fuel Tank |
Weight* | 72.0 Kg (159 lbs.) |
Alternator Output | Optional: 12V, 130W, 11A (Standard on Electric Start Model) |
Max. RPM Range | 5,000 - 5,700 |
Start In Gear Protection | Standard |
Thermostat Controlled Cooling System | Standard |
Through-The-Prop Exhaust | Standard |
Overheat Buzzer | O |
Power Trim and Tilt | O |
Shallow Water Drive | O |
Engine lubrication system | Premixed Fuel |
