buck35
- Jan 27, 2015
- 5,977
- 5,683
Their a lightly past prime but here you go.Thanks Buck. Post a pic of the blossoms!
What are they ? Sure are pretty !!Their a lightly past prime but here you go. View attachment 747277
Gotta love day one fun! And oh yeah the eating lunch with these!
Corn is going in, but a few minor glitches. Have I mentioned how much I enjoy electronics?
Yeah, was mostly from the drive chain that drives from the hydraulic drive motor to the main shaft drive for the row units. When the electronic row clutch seized up, it took out the front gearbox for that row too. Only way to replace that is to pull the shaft. The hex shaft runs through the parallel arms from each row behind the airbag for the downforce. The black piece with the part number is the top of the gearbox.Um, I don’t think your electronics are supposed to be that greasy!
Bean juice! Drink a literal fu&@ ton of it this time of year! 4 am this morning was the go time. Been in the field and running since before 5, and pending rain amount ( drizzling here currently) I’m expecting to see the 9 pm hour from the seat!Whats in the go cup????
The boxes on the planter are three bushel boxes. Our seed is mostly bulk pro boxes, but we do buy some in lots of 16 bags (1 bag per row). We have two seed tenders. One with a 375 bushel hopper, the other a four tote box holder. Both have scales and conveyors, and the big one has a talc dispenser. They speed up the fill process immensely.How often do you need to stop to fill the seed boxes? Is your seed bulk or bags?
Oops, sorry. Got side tracked and forgot to answer that part. Generally, I fill with seed about twice a day, and can plant around 110 acres per fill at about 20 acres an hour, so something in the 5-6 hours neighborhood for seed, and about every 65 acres on fertilizer, or twice per seed fill.So....How often do you need to stop and fill? And how long does it take to fill?
The pivots are electrically driven. There's a motor on every section that's connected to a gear box. The motor turns on and off by a micro switch thats at each joint. The outermost motor never shuts off, and the rest "keep up" so to speak. When they drill the wells for the pivots, the goal is a 1000 gpm. Sometimes they hit it, sometimes not.OK, stupid question for field irrigation: In the last pic there is the end of the sprinkler setup. I assume those things are wheel driven by the water flow? If so, how many gph is required to run it?
I was about 20 the first time I went on a plane. I couldn't figure out why all those fields were in circles. It really wasn't until the next year I saw the pivot setup. That next year I started driving through "Fly Over" states doing shows. That's when I saw all kinds of new things, like combines and planters.
Where I grew up, we had dairy farms and some orchards, but all those went away. Progress and housing...really kind of sucked. We used to street race by a strawberry patch on Sunday nights, and by dairy farms on Saturday nights. The strawberry patch is a Home Dump and shopping center, and the dairy farms are housing developments
Damn, never thought of the water flow needing to vary on the radius, so as not to drown the inboard crop. I figured it wasn't a hook up and go thing, but wouldn't have figured WiFi enabled micro switched setups either. It ain't no RainbirdThe pivots are electrically driven. There's a motor on every section that's connected to a gear box. The motor turns on and off by a micro switch thats at each joint. The outermost motor never shuts off, and the rest "keep up" so to speak. When they drill the wells for the pivots, the goal is a 1000 gpm. Sometimes they hit it, sometimes not.
Each sprinkler head is sized to apply the same amount of water to the field, so smaller the closer you get to the actual pivot point. Pumps can be turned on by smartphone apps, including the direction of travel, and rate of application. It's pretty incredible at how much tech is in a sprinkler system.
(I built one of the local irrigation dealers new building, and picked up a bit of info on how they work.)
would you believe the sprinkler heads are crop specific? There are different heads that create a different shape water droplet. some crops shouldnt have huge drops blasting them, and have dirt splashed up on their leaves. its really nuts.Damn, never thought of the water flow needing to vary on the radius, so as not to drown the inboard crop. I figured it wasn't a hook up and go thing, but wouldn't have figured WiFi enabled micro switched setups either. It ain't no Rainbird
Yeah, Hula is pretty much right on with his comments. They are all electric. The end tower, at full speed does run continuously, but to slow them down, they run intermittently, using a percent timer to feed power on and off to the end tower, the rest use an alignment system to run when needed to keep up. Some of the newer ones do use frequency drives to control speed. These do run continuously on the end, just speed up or slow down with the freq. drive.Damn, never thought of the water flow needing to vary on the radius, so as not to drown the inboard crop. I figured it wasn't a hook up and go thing, but wouldn't have figured WiFi enabled micro switched setups either. It ain't no Rainbird
Coming out and working a harvest with you is on my bucket list.As many of you know, I hang with @Headless hula a fair amount and he has been after me for quite some time to start a thread here chronicling my life as a grain and vegetable farmer, so finally here it is.
First off, let me set a few ground rules. 1. I’ll try my darnedest to explain things as best I can. 2. If you have any questions about certain parts of what I’m talking about, ask questions. I’ll answer them if I can. 3. Try to be patient as I will post more over time. I can’t and won’t try to explain every bit of Cheeseland Agricultural practices in a single post. 4. I will post pictures as I go and try to make it as interesting as I can.
Beyond that? Sit back, read, enjoy, and interact as you wish. I’m doing this for your benefit, and maybe I’ll learn a thing or three along the way.
Also, if you are ever in the area visiting Hula, make sure you tell him to get my ass th Hula HQ 2.0 so we can partake in a little shenanigans!
Here’s a little teaser pic to start it all off. This is a shot from the seat, or as I call it my corner window office.
I’ll try to keep each post from getting too long, and May add several posts over a short period to keep them shorter.
It is a little early in the season yet too, so I’ll add a few posts over the next couple weeks detailing the winter processes too.
He's always in a bind for drivers Ross!Coming out and working a harvest with you is on my bucket list.
I'm in! Is a resume needed?He's always in a bind for drivers Ross!
Doubtful. Pump da brakes after 8-10 beers. You're in....I'm in! Is a resume needed?
A lot of the fields around here still have a fair amount of ponding. I'm feeling sorry for the local guys.
Getting some nitrogen put down on some snap beans today. Sun is out and things are growing. Still battling a fair amount of wet areas in some fields, but crops look decent here.
Pre cultivation
A shot of the cultivator.
After the cultivator passed by
Dribbling a band of liquid fertilizer down beside each row as well.
Don’t be sorry for asking questions. That’s what I want this thread to be is as informative as it can be.Sorry if you mentioned it previously in the thread but do you guys utilize Tile Drain much?
It kinda varies by crop and by previous crop to a degree. We try to minimize our tillage passes just from a fuel and time savings reason, but it also has to be properly prepped prior to planting, so fall tillage plays in for the following year.How many times do you think you have to pass over a field between tilling, planting, fertilizing, harvesting, etc on average? I'm sure you spend more time in the seat of a tractor than most people spend in a car in a given year.
field.
On average most fields get one spring tillage pass, a planting pass, most two sprayer passes, one in season cultivation tillage, one or two fertilizer spreader passes, a harvest pass, another spreader pass to spread cover crop, and a final fall tillage pass. So most fields will see some sort of equipment pass 8-10 times a year.
I will add that a crop like potatoes that are very susceptible to fungal diseases get sprayed on average 12-15 times a year, so those fields probably see near 20 passes a year.
As for equipment seat time, yeah between planter, harvester, and miscellaneous other tasks, I probably average 750-850 hours of what I call corner window office time.
That’s why I have a portable satellite radio that I put in my tractor and harvester. If I’m gonna pay for it I’m not gonna leave it in my truck.
Case in point. Current situation.
And my radio
Dust is flying
It would be kinda cool to see a rdp t-shirt worn by the clown drivin that big green tractor around in circles all day....It kinda varies by crop and by previous crop to a degree. We try to minimize our tillage passes just from a fuel and time savings reason, but it also has to be properly prepped prior to planting, so fall tillage plays in for the following year.
And my radio
Dust is flying
Thanks Steve. Glad you like it, and I hope it’s informative.What a great thread! I just saw this today and read all 7 pages.
Most of the questions that I have thought of have been already
been answered by you. Thanks for one of the best reads that I
have seen in a long time.
Steve
All I have to do now is write my questions down so I have something
to refresh myself because I can’t remember crap for longer than 30 seconds anymore
The OP sounds like the How farms work guy on you tube. That channel is pretty awesomeSimilar scenario as Millennial Farmer on YouTube. I’ve subscribed to his channel for a while now and got a whole lot of insight into the corn and soybean versus livestock way of farming and why.
Great thread and excited to see where it goes. Thanks for sharing [emoji106]
