941Punk
some beach, somewhere.
- Jul 28, 2008
- 3,775
- 6,144
Imagine having a guest appearance with LuckyStike and have him explain things. LOL
On a holiday weekendPretty solid videos, when will you be doing the single screw, river bar docking segment?
You should do a jet bote video for docking and un docking. In your spare time..
Am I doing it right?Those with singles motors…….. I should shoot a video on how to fake having a bow thruster. Here is the basic concept. When leaving the slip, build up as much momentum as possible backwards, Then bump to neutral, then forward. I am adding the neutral, since most of you have outdrives, and can’t just throw it in forward, like you can with a diesel transmission. While throwing it in forward, turn towards the direction you want to go. When done correctly the inertia of going from reverse to forward will nicely bring the bow around. I suggest practicing this. It’s easy and very valuable to know. After a while this will become second nature and you will use this move for a myriad of reasons. Like straightening out to put single engine boat in slip. Reverse is your friend.
Also…….. if you have to turn your single engine boat around in a tight spot……. It will make the turn tighter, if you do the entire turn around in reverse. In this case, forward is not your friend.
Great videos, keep ‘em coming!Shouldn’t make much difference in off plane maneuvering..
I am not sure what you are trying to do in the video?
Spent time in the summer with the wife doing circles trying to get them as tight as possible. She thought that I was crazy at first but understands now after some time in the boat. I tell you I am so grateful for all those that including me in their boating lives. It can be stressful and I didn’t really have any idea all though years. Especially on the holiday weekends.
Lot of factors come into play. normally turning out will handle better ( around the docks) but be slower top end. also staggered motors are harder to handle around docks because drives are so close togetherGreat videos, keep ‘em coming!
I only have 2 things to add. On my twin ob carrera, props in vs out make a fairly noticeable difference around the docks. I feel like I have a fair amount more control with my props spinning out vs in. I’ve swapped lowers same day a few times and no matter what props are on it, same results.
Only small tip I can add, on mine the propshafts are 1.5” above the bottom. I’ve noticed putting a little positive trim in it also gives me much more control I’m reverse. Otherwise most of the thrust just ends up on the transom and probably down the tunnel to some extent. But if I trim up just slightly positive it makes a lot of difference. I’m sure it all depends on motor height, hull design etc…
Well, very little viewers there since Covid the Bistro's been shuttered but yes that ramp was cheaply done maybe 10 years back. I was there watching them pour the "New" ramp and they didn't go out nearly far enough. I used the launch service and would have to be very tide aware cause they'd shut service down at +1 if it was headed to negative tide that day. Lots of thumps like yours as trailers fall of end of that shorty ramp. Glad you were able to yank it back up.Ironic You say that !
I came in last Saturday at a minus tide . . . I'd completely forgotten about 'The Drop Off' where that ramp ends.
My little boat sits low on the trailer and launching barely gets the truck tires wet.
I was backing in the trailer, while my buddy was in my boat idling around.
I always go slow, and I was looking in my side-view when my trailer just 'drops' !
Oh shit !!! . .I totally forgot . . . I hit the brakes quickly and popped the truck back in gear . .got lucky . . no prob. as it didn't fall but a little.
Could've been good entertainment for the Bistro Crowd !!!![]()
I was just F-ing around really... My buddy took this random video of me waiting for my wife to park the truck and trailer. I typically bump forward then cut the wheel and bump back to swing my bow around. Kind of an example of this seen in the video. My last boat (26' Hallett deck) was more responsive than the 28' Shockwave. I could practically spin that boat on its own axis. I am still learning the characteristics of the new boat. Still need some practice.I am not sure what you are trying to do in the video?
But that is not even close to what I am describing. I don’t see you even attempting to bring bow around.
My scenario can be used in very tight places, such as coming out of slip with another row of slips, behind boat. The key is to build up reverse momentum, so that the change in inertia when shifted into forward, brings the bow around like it had a bow thruster. Sometimes in a tight situation, you might have to do the manuver a couple of times to get the bow 90 degrees from where you started. When done correctly……. You look like a real pro.
Just remember…… when doing this manuver, there is no room for error, or you will run into boats behind boat. It must be done confidently. Which takes practice.
For me, I know exactly how much momentum I need to bring bow around. I also know when I only have the space to get my bow approx 45 degrees out of the manuver. This means I have already decided that I will need to do the manuver twice to get my bow around to 90 degrees, so I can now head out the marina channel.
It’s funny to see the look on peoples faces when I untie at a slip…… and put boat in FULL reverse. The faster you go, the quicker the bow comes around. But you have to remember to steer the bow in the direction you want bow to go. If it takes 2 tries…… remember to straighten out steering before putting boat into reverse for 2nd attempt.
As a side note……. For those of you that rarely throw your boat into reverse, you should probably familiarize yourself with all the different ways your boat can be maneuvered in reverse. Just saying. For instance, because of prop rotation, it will turn one direction in reverse better than the other. Do you know on YOUR boat, which direction this is? There’s only one way to find out! Lol
I think 'Bumping" is key here... as is the ole "In n Out"I was just F-ing around really... My buddy took this random video of me waiting for my wife to park the truck and trailer. I typically bump forward then cut the wheel and bump back to swing my bow around. Kind of an example of this seen in the video. My last boat (26' Hallett deck) was more responsive than the 28' Shockwave. I could practically spin that boat on its own axis. I am still learning the characteristics of the new boat. Still need some practice.
You forgot to add with blower surge...How about a video of backing up a single engine v-drive into an outer harbor slip. Twins outboards or IO‘s it is easy as the videos demonstrate.
Good video, could you do one for driving inboard ski boat and a jet boat?
The how “not” to is already pretty well covered by youtube you just have to look for it.How to, and how "not" to videos would be great. Especially if the are for specific problems people are having in certain circumstances around the dock.
Now that would be great entertainment !And it’s not a bouy it’s a fender etc.. just a few short years ago ain’t wasn’t in the dictionary either..
If I made a coastguard video nobody would watch it
When at Lake Havasu, I back my closed bow single engine 28' boat into a rented Havasu marina slip with my wife on the engine cover, mooring lines in hand, ready to keep us from hitting the slip finger as we slowly idle backwards towards the opening. If it is a fairly calm afternoon I won't completely embarrass myself. If it is breezy, the bow acts like a huge sail and it's pucker time! No matter how many times I do it, I can't routinely line the boat up so it is perfectly perpendicular to and directly in front of the slip opening. Backing into the slips in front of Topock 66 with the current going one way and the wind the other only works for me if I have a choice of several empty slips and I keep to myself which slip I am aiming for! At the Springs, we try and dock at an end tie. An instructional video for us single engine guys backing into a slip (and maneuvering forward out of it) with a fairly narrow fairway between slip docks would be most appreciated! Thanks!
Nothing more difficult around the docks than a V-drive wake or surf boat. Don’t like to back up, and when they do will only turn due to the paddle wheel affect from prop rotation. Steering rudder has almost zero input on boat in reverse. Something I’ve had to practice with a lot. I can see why the new ones have bow thrusters, especially for those who don’t have experience or the desire to learn how to operate their vessel correctly. This is coming from my play boat that doesn’t shift out of gear while running. V drive makes that cold bitch seem like a pleasure.Actually I would like to go film all of these in a more “pg” fashion so that people can use them to teach their kids and wives etc.. currently boatless (well kinda) so I gotta go get another boat. Lol
Or borrow some for some off plane driving instructions
Best one yet
Dave is going to lose a bunch of people here if they are honest lolBest one yet
How so?
If people that drive around somoeone that needs help and don't tow actually log off your site like you said at the end of the video.
I'd love to see a similar video on a 21ft V-Drive with a T400 with all gears. Reverse is a bitch on those things...This is a series of videos I recorded earlier this summer for fun and informational purposes. It doesn’t really fit the “pg / industry” narrative so we added a YouTube channel to our YouTube called “after dark” This particular series is six or seven episodes.
I will update with more episodes next week!
Something I still have a bit of a struggle with on my x-flight is this, especially if its windy....the front end of the boat captures enough air that you end up fighting to turn. It's the biggest single engine boat I've ever had...my 27, 33, and 36 cruisers all had twins.I was just F-ing around really... My buddy took this random video of me waiting for my wife to park the truck and trailer. I typically bump forward then cut the wheel and bump back to swing my bow around. Kind of an example of this seen in the video. My last boat (26' Hallett deck) was more responsive than the 28' Shockwave. I could practically spin that boat on its own axis. I am still learning the characteristics of the new boat. Still need some practice.
