Hallo aus Deurschland, Hello from Germany, Please help identify this boat.
Snorre
Ich bin neu hier weil ich mir ein Boot gekauft habe das ich erneuern möchte aber bin mir nicht sicher ob es eine Shiaha 19 Baujahr ???
ist ich benötige noch Informationen von euch Fachkundigen bitte.
Snorre
Ich habe noch viel Arbeit vor mir , derzeit entferne ich den alten Lack und da kommt ein grüner Flake Lack zum Vorschein .
Snorre
mash on it
Beyond Hell Crew
Translation (from Google translate) first post -
"I'm new here because I bought a boat that I want to renew but I'm not sure if it's a Shiaha 19 built???
I still need information from you experts please."
I'm thinking he means Schiada?
Dan'l
Snorre
Hello
We can help idenficat my Boad ?
Romans9
Well I have no idea what he said but I know one thing for sure, he came to the right place to identify a boat.
I will be very disappointed if in the next 24 hours every detail about this boat’s existence isn’t in this thread……..
Snorre
Hello, thank you for the information, are you sure it's not a schiada? I have to be completely sure which boat and which year of construction in order to get new papers for it
yz450mm
Hallo, Sie werden hier bessere Informationen erhalten, wenn Sie Google Translate verwenden und detailliert erklären, was Sie genau haben und was Sie damit machen möchten.
mash on it
Beyond Hell Crew
@yz450mm -
Post #4
Seems like he wants to identify this boat?
Thinks it might be a Shiada?
Dan'l
Wedgy
Maybe an admin can help Snorre with better placement of the thread, or?
No fear of old boats, that's for sure!
Mach shnell !! Snorre!!
Snorre
now again Who can help me identify the boat? I don't know exactly what I bought, I'm currently rebuilding this boat, so I need information from you. Thanks Snorre
Try posting your question in the lounge
I’m going to go with Hallet. Built from a 3 piece mold, the deck is laminated to the top of the hull. And it was green metal flake🤣 . Is that a ZF v drive out of a yacht?
Did the gunnels of Mandellas wrap around the transom like that?
Reactions: DUN
I'm leaning towards Hallet
Clank123
It’s a mid-sixties Hallett with a center deck.
I’ve one in the Parker Shop right now. Not a center deck.
It’s a 1966
Also German boat has set plates with turnbuckle pad’s mounted to the hull along with a BeeDee Marine combination rudder support/battery box.
Very standard ski boat setup for those years.
Good luck with the restoration!
Willie B
aberrant member
…’63ish Hallett that someone has cut a portion of the center deck out of for whatever that mechanical thing is😳..: 99% sure…
… if you have ethanol gas in Germany, get rid of those Fiberglass fuel tanks in the front seating area…Ethanol will eat up the fiberglass…
… This is my 63 Hallett…
Snorre
My next tasks are to remove the 5 layers of paint and then repaint the boat
Please keep this thread up to date on your progress.
Bitte halten Sie diesen Thread über Ihre Fortschritte auf dem Laufenden.
Snorre
yes, thank you, unfortunately I was born in the wrong country, I love everything that has V8 engines, I love weapons, but you can only operate all of this in Germany with a lot of restrictions...
yes, I'll keep you updated with my project ✌️
Snorre
Kleaning up the parts ,I would have liked a big block but they are difficult to obtain here 💁‍♂️
Snorre
I need a set of small block pistons with +0.40 overeurekisch, does anyone still have a set?
PlumLoco
Vintage Jawa CZ motorcycles
Looks like it is going to need a new lifter.
You should probably switch to a hydraulic roller camshaft as well, it's hard to find a quality set of flat tappet lifters anymore.
Clank123
Sure like to see you switch to a period correct scoop.
This one is 149.00 from Speedway motors.
Paint to match the hull.
Oh, and no need to paint the engine Chevy Orange. A nice gloss black would look correct with the original hull color.
Snorre
Würde mich freuen, wenn Sie auf eine zeitgemäße Schaufel umsteigen würden.
Dieses hier kostet 149,00 von Speedway Motors.
Farbe passend zum Rumpf.
Oh, und der Motor muss nicht in Chevy-Orange lackiert werden. Ein schönes glänzendes Schwarz würde zur Originalrumpffarbe passen. View attachment 1379875 View attachment 1379876
Der Motor war beim Kauf rot, der Lack blättert ab, aber vorher wird er zerlegt und bekommt ein neues Loch auf 040 Übergröße
Snorre
The engine was red where I bought it, the paint is coming off, but first it is dismantled and gets a new hole on 040 oversize
Am I missing where the current pistons are marked .030?
