Fabricator/TIG Welder near San Dimas
rivergames
My Coworker needs a stainless table frame made for his new remodeled home.
He Needs the feet, legs, & frame fab's and welded up using a 14 or 16 gauge stainless.
Anyone have any recommeded Fabricators/Welders around LA/IE?
@Fabhouse , you know anyone in the area? Bobby over at Walden Speed shop in Pomona, but he's the only guy in the area I know out that way.
evantwheeler
@monkeyswrench Not aware of someone in the area I would recommend. To be built correctly you will need a large fixture plate with uprights.
This. Stainless is a real hooker, it moves a ton when you weld it.
@rivergames I wouldn't be surprised if this ends up being a $5k+ table base
The orange and pink square/rectangle shapes are carbon steel?
Fabhouse
My initial thought was 5k plus. It looks far more simple than it is. I would assume the mild steel frame with SS legs is to save on material cost.
rivergames
The Blue is 2"x2" cross members with a 1"x2" Frame.
I thought he wanted all SS. Just using the difference colors to show which ones are 1"x2" and the others are 2"x2"
evantwheeler
It is explicit calling out stainless steel for the round legs, but just calls out steel for the tabletop frame. Its not an issue welding carbon to stainless, and he'd save a bunch of money building it with the dis-similar metals, might want him to clarify that.
This is something we could build, but not for a while due to current obligations with contract work in the field, and it wouldn't be cheap unfortunately. I'm sure there are some one man shops around that can handle something like this without the overhead that we have as a union shop.
rivergames
Thanks you for the info guys! I will relay the message!
clark
Micro-Tig 748 E. Edna place, Covina 91723--(626)3397017--His work is truly exceptional and reasonable
RIVERBORN
I’m in Bakersfield. We could handle it if need be. Depending on time frame
Regularly go down to Pasadena and Temecula for movie theater work right now.
I am a small fab shop. Welding and structural steel contractor
