Current Situation - a picture thread
throttle
c ya on da lake
spectras only
Got the wheels cleaned up and new tires on my Volvo project. Biggest hurdle will be to sort out the wiring. Main wire in the engine compartment were burned long time ago and the owner removed it.
welldigger00
Ok, so my new jeep has provided me with several hours of entertainment. Front, and rear wheel seal leaks, valve cover gasket leak, and full service work. The front differential had to come out, so I went ahead and changed axle u joints, unit bearings, new pads and rotors. Rear axle got new bearings and seals. These jeeps are so easy to work on, the only hang up was an inner race on the rear axle bearing that didn’t want to come out, so I had to weld a bead around it, and it shrunk down when it cooled, and slid right out.
Dr Rob
Ok, so my new jeep has provided me with several hours of entertainment. Front, and rear wheel seal leaks, valve cover gasket leak, and full service work. The front differential had to come out, so I went ahead and changed axle u joints, unit bearings, new pads and rotors. Rear axle got new bearings and seals. These jeeps are so easy to work on, the only hang up was an inner race on the rear axle bearing that didn’t want to come out, so I had to weld a bead around it, and it shrunk down when it cooled, and slid right out. View attachment 1453272 View attachment 1453273 View attachment 1453274 View attachment 1453275 View attachment 1453277 View attachment 1453276
I thought leaks were standard equipment on a Jeep.😁
