- Sep 13, 2007
- 126,105
- 164,127
Disregard the drywall texture etc.. Going to fix that next. Got a DI system (spotless rinse) from PB&J water awhile back and I wanted it mounted in a fashion where I can hook my pressure washer up to it, run hard water for cleaning, flip a valve and then have DI water for the final rinse.
You can see the by pass along the front for the haddwater, and you shut that valve off and open the other one and it will run through the filters to preserve them.
I’ll run the stick filters for the treat of the summer and winter and then do the internal conversion kit that gives you enough Filtration to run thousands of gallons through them and that should be good enough to last years without having to mess with the filters!
Going to try it tomorrow, then texture the drywall and done!
Now when Stacy’s car needs a quick rinse for the outside it should take minutes. . Also makes cleaning up boats/off road insanely quicker.
