Capping my Daytona
81Sprint
So who's the go-to to get a boat capped these days? Need the transom cleaned up also from the outboard brackets/controls and a few holes filled. Had a place to send it but doesn't look like that will work out. Not sure if Shoemaker is still doing it, he capped my Sprint and did a good job.
LakeMeadLavey
Call Dustin at Menace Marine in SCV believe he has a really good glass guy that shares his shop.
Lots of talent already mentioned above. You really can't wrong with any of them. 👍
Morehart
Depending where your at Steve @ rss_gel_works.
81Sprint
Reached out to Pedro at Saleen, and just talked to Shoemaker. Haven't talked to Greg in probably 7-8 years and he remembered me, or my Sprint anyway lol. Pedro is super nice but definitely on the higher end of pricing. I'll see where Greg comes in and go from there
wzuber
Does @Hammer here do glass & gel work?
I thought somebody here does with quality results from the pix shared here previously.
Hammer
That is RSS Gel Works and Steve. They do nice work. Heard they are pretty far out on project start dates but well worth a call or email to them.
^^^^ This, I'm not really affiliated anymore. But I can put you in contact with them.
81Sprint
Shoemaker quoted me a great price, and they did a really nice job on my Sprint so looks like I will be taking it to him next weekend. Finally! A light at the end of the tunnel (no pun intended) 😁 for this hull to be ready to put back together
81Sprint
Need to find some of the aluminum anodized trim for the gunnels, the original stuff is all faded. Been searching around doesn't seem to be carried by anyone or at least not online
The only color anodizing you can do that's UV proof is black (or clear, because there's no color to fade). You might just strip the color with EZ OFF oven cleaner and polish it.
81Sprint
I'm not really worried about it fading, boat will be covered indoors while not on the water. But if I can't find it in red will probably go that route
Gelcoater
I’d go polished👍
I’ve seen black ano fade, almost purple and spotty. Definitely last longer than say red or gold but does still fade.
I’d go polished👍
Black ano does fade, but there's a process to make it UV proof....look at all the doors/windows on commercial buildings and supermarkets, black anodized but they don't fade. It's not cheap, and it's not regular black ano. I have a customer who does jeep stuff and everything aluminum is black UV anodized....looks the same 20 years later after living in the sun.
The process is different...instead of using organic or inorganic dyes with a sealer like you do for normal colors, you need to use an AC electrolytic coloring process which basically is stannous sulphate...very few do this.
blue wonder
I don’t think they make it anymore, if I was doing it I would take the molding off you have and have it powdercoated to match the rest of your rigging, just don’t try and straighten it or anything, leave it bent the way it is, right off right back on
wzuber
Polished stainless would look really nice too.
Bakotrash
Friend of mine here in Vegas, did the floors and set the intake, also did the rounded keel. He's a talented guy
Did you do a round keel on your Sprint? Just curious...........I'm currently building a Sprint myself.
wzuber
that would be interesting to see... a round keel on the very shallow v of the sprint.
81Sprint
No I left the delta pad, friend of mine with a Sprint put one on his. I haven't heard that it was life changing. I asked Shoemaker about it way back when I was building mine, he suggested to leave it alone.
tx-19
No, just the cap area and the transom where all the holes from the outboard were filled. Other than that it is original
What’s Greg charging to cap the boat,have a friend wanting to do his Cheyenne
81Sprint
I would call him for a quote. With all the work I had done, holes filled etc it was a hair over 6K
wzuber
Very reasonable price considering all the work involved and cost of materials etc..just the thought of all that sanding makes me tired......haha
Bakotrash
Shoemaker told me same thing, but some say its life changing. Idk
wzuber
Clarify life changing........
Loose, sketchy, dangerous disastrous can all be "life changing".........😆😆😅
I would talk to Jeff Bennett if truly serious, then talk w/someone that's done it and get their experience of the difference/results to see if they align w/your goals. The sprints are great looking hulls but being such a shallow v with very little rocker it's my understanding they get sketchy fast. Just because you can doesn't mean you should comes to mind. Haha. It likely comes down to...you can... but if your going to spend that kinda money to make that hull do what you want you'll be money/time ahead to find a hull better suited to do what you want much more safely from it's inherent design....ie...tunnel hull or Roger's type v- bottom..
Bakotrash
Probably just get the shoe depth correct and leave the rest alone. I really don't have the desire to "hang it out" anymore. LOL
wzuber
Smart choice. Especially on the lakes and rivers where help is a long ways away if you find yourself skidding slideways or tumbling across the water or worse. Ruins a lot of people's day.
