Building a LED sign truck from scratch..
Doors on the back of the frame are mounted
Have you started selling space yet?
Knowing the seasons are turning and with fall the beginning weekday and weekend events, folks might be looking for a new way to draw in crowds.
I’m going to wait until it’s complete before we start selling space on it.
Instead of just doing rotating static images, I’m going to have Michael make five second commercials that end with an image.
wzuber
Probably be a good idea to do some test runs on all systems to insure all is working correctly b4 taking peeps $$ and then having to appologize and deal with any issues should something arrise.
H20 Toie
Party on Garth
Failure is not an option
It’s being assembled, tested.. the. Taken apart for paint then reassembled and tested again.
Saddles for the fuel tanks are in.. filling the stake holes in the bed..
Jay Dub
so fun following this thread. mad fab skills.
dezertrider
I did not go through the entire thread but in case it has not been mentioned. Make sure to insulate all of the metal panels. Those will radiate more heat then the screens over heating it unless the truck is parked in the shade in December
The whole truck and all the mods are all getting painted white and it will have insulation etc..
wzuber
Nice, what kind of insulation?
I see a lot of screwing has been going on. Looks good, clean & very professional.
I gotta ask Eric.. I’m not sure what he’s planning on using.. the cabinet is air conditioned as well.
He said the doors get one inch home insulation and the sides and roof get two inch home insulation
King295
Well-Known Inmate #20225
This thing is rad, you won't be able to miss this rolling down the road or posted up. Nice work RD and thanks for sharing the build.
Switches to control on off for the screen.. couple of power outlets just in case, network cables as well.
Your ad here
No? Why would I need that?
The diesel fuel get hot when running through the engine and then goes back to the tank. Over time the fuel in the tank will be very hot and hot fuel can cause problems. The engine may have a fuel cooler setup but with external tanks and Havasu summer heat it may be something to look into.
Why would it go back to the tank?
DRYHEAT
Diesels are fuel injected and have a return fuel line back to the fuel tank.
Not all have return lines back to the tank depends on the system and type, the heat isn’t really gonna hurt it, thousands and thousands of reefer trailers, running at full tilt in the desert, don’t have fuel coolers.
Fabhouse
Barker has skills. He's showing them here. Not many, my self included, would go to these lengths for the end result, a marketing truck. Kudos, and a huge thumbs up for respecting the craft no matter the application.
Dave-You now have the Schiada of sign trucks-as I would expect.
FreeBird236
I was lucky enough to have him clean up the underside of my 50 Chevy, awesome work.
Do you plan on running a fuel cooler for the generator?
I think that genset has a small fuel cooler, like a trans cooler? Pretty sure that model had an electric lift pump, and the tank is below the radiator. Seem pretty stout, I think they used them in Iraq.
Heylam
with the onboard generator, I’d include a refrigerator in the build.
