Boat Question Hallett 210 Tab Angle
2FORCEFULL
What does a trim tab with a strake on it have to do with a whammo plate? I’m confused.
if you read the thread title, it's about trim tabs,..but if you read post 10 it is a thred de-rail, concurred by post 11, once the kiss of blessing by the pope... it became total derailed.... of coarse it will all my fault by 2am.....lol....trim tabs...
What are the dimensions of the whamo plate and how far above the keel is it mounted?
guest hs
Anyone want to take stab at what Boat this is and what these notched do?
stevesdcb
They built a closed deck with a 525sc back in 94. 490 PSHP. It ran in the 80's.
Wonder what tabs they used, possibly the small Bennetts, they know how to drive the boat a lot better than I, need to call Jerry.
Melloyellovector
Was this taken just before the crash :eek:
It’s from HIH vid, screen shot. Lmao
Small group took off before us from Thomspon bay. 270s 300 etc plus the normal havazoo crowds. WMC takes off like a Fuken RC car on steroids zero to 60 in 2 seconds. Mike yells out if you try n keep up. All while I’m takin off hat and telling kids hold on.
So made a few hot passes flopping around in everyone’s slop that left beforehand us. And I was jumpin some of the stuff on purpose hoping for some good air pics. Got em
Waiting for pics to see if it gets better :D
Melloyellovector
If it’s the one I’m thinking it is, it’s yellow and white with red pin.
525sc with a stock bravo drive and Bennett tabs. And not a gps speedo.
And for sure not going high 80s either
Jerry never rigged race 210s.
stevesdcb
My boat is kinda of a hybrid, not stock but not a race set up. I'm thinking I need more than the stock 10" tabs but how much more, shit I dunno. Just showed my wife that pic:D
Melloyellovector
I told you who to call, Bob Marine Ind West will take care of ya.
Hp750 or 900 tabs should be good. Bennett’s will technically work to a point. But if you get in the mid 70s plus you’ll appreciate a little more meat to stabilize it
UltraLucky
Have you got the boat together and logged some time with the new engine? Standard lower or -2”? I went through the same deal On the tabs, Bob recemended the 900 and I ended changing the plates to 1000 after running the boat for 20 or so hours. Didn’t help the speed but does react quicker to tab settings. If you mount them horizontal your going to need the longer tabs. Parrellel there is a lot more surface of the tap in contact with the water. If your just looking for more stability at higher speeds I’d go horizontal. If you want better ride control throughout your speed range I’d go parrelell
as a lot of you know,... this discussion, argument..or what ever has been going on for about 10yrs...I took a boat to havasu and RD couldn't find the time to come out and ride in the boat....so it never has been laid to rest,.. I have a boat in my yard at vegas...with the plate... if it didn't work... I would have kept trying things till I figured it out... but it did work... getting others on RDP to agree...not happening...so, I guess for the sake...it does nothing
It's not a popularity contest.. I'm saying lets go test it. If 50 lbs of pressure moves that plate then so be it.. I don't think it will generate 50 lbs of lift, and that close to the transom that's not gonna do much. A whale tail (or variant) on the drive 2' further out adds exponential leverage, as well as square inches.
I'm not banging on it for a personal reason.. I just honestly don't see how it could make a spit of difference in any scenario.
Other than the stabs at Steve from those that have nothing to add to the conversation.. (Which is why I deleted the comments.. and if they continue I'll just delete the members)
I'm truly enjoying a thought provoking thread on RDP about boat setup. :)
I'll be happy to lay down the thought processes behind mine (including that ride plate response), but I have a few things I have to do tonight. :) Tomorrow is another day though! I say we keep it going, and I look forward to everyone's thoughts. :) I look forward to the "rocker plate" conversation as well.
spectras only
Dave, The 'Whamo' plate in 2FF's picture definitely seem short to be very effective. Having an extension box would put the drive further back allowing a longer rideplate to be somewhat effective. A whaletail on the drive itself would be effective, albeit ugly and should be installed on fishing boats only.:D I have my 280 Merc tabs installed 1/2 above the bottom instead of flushed. This way, when tabs are above neutral, it won't drag. I set the tabs at neutral with drive up slightly when the boat start to chine walk past 70.
Would definitely like to see GoPro footage with Steve's setup, running 3/4 to full throttle to see action at the plate.
In my picture, it shows the boat's chine is literally out of the water at the stern, so tabs must be set level to stop rocking the boat from side to side. I'd love to use 380 tabs, then I could raise the tabs higher. But, the 380 tabs would interfere with my drives while turning so it's not gonna happen.
2FORCEFULL
the dimensions vary because of bottom angle, but what I do is put one that has the most surface...able to reach side to side... the plate goes up to the bottom of the out drive... the results are progressive...as in every time you hit a wind wave or boat rollor, it lifts the transom, slightly, and keep the boat on keel, that and at full throttle tame the bow rise on the 210 Hallett, one of the boats I really saw a great improvement was the Nordic rage, I've onwned quite a few of those , and they all did the same thing..the bow would rise past were it was effective in busting through the waves and bang the crap out of you and the boat,,, with the plate, it would keep the boat more on keel and after every hit it would cause more transom lift,,,,in turn keeping the boat on keel..un believable for sure , but, for those of you that have owned and rigged Jet boats you know the difference the little ride plate makes....
2FORCEFULL
I think this has been, and hopefully continue to be a very interesting thread,..sure there are the response's from the out of work stand up comedians, but, I really love the fact that what I said about the 210 over 10 yrs ago here is finally coming out to be truth....10 yrs ago, no body would come on here and agree...response's like... my Hallett is perfect stable at 90 mph with no tabs and such would make my eyes roll,, self proclaimed wizards and such that never have owned a 210 Hallett, but one of their friends did.. I've owned probley a dozen or so... small block to 500 plus hp big blocks...pretty much every 72 mph Hallett was gps'd more like 67.... or less ...and the weird stuff really starts at 65 mph... but, seat time pushes the speed up a little further,... and experienced driver could say 70 mph if there is enough power.... knowing how to peddle a boat comes in to play, you can get the needed transom lift with just the throttle...so statements from one driver to the next vary...
2FORCEFULL
try this.... get one of your short free board boats going 75mph,.. and stick your hand in the water out the side...tell me how much pressure it takes to put your hand flat under water...the way the plate works, it does nothing on smooth water, it keeps the transom from burring and the bow from launching off rollers and wind waves
2FORCEFULL
if you look at the bottom one at the V... pretty much looks the same as my plate idea..but, it's for ever... you would have to do a lot of work to get rid of it if it didn't work..I've been putting these plates on for over 10yrs with all good result
2FORCEFULL
just my thought here....but I think you would benefit more with wider tabs closer to the drive...but they don't rig boats that way for a reason... that being you could get in some big trouble not knowing how to drive the boat...meaning... a guy that knows nothing
I learned first hand driving my twin turbo Schiada what happens when you chop off the throttle with too much plate at 100 mph......
2FORCEFULL
when ever I think of tabs, I think of air plane wings,, they make the tabs wider.... not longer
2FORCEFULL
it's this simple of a test,one 5/8'' wrench... run the boat in the water conditions…. go to the beach, two bolts and the plate comes off and run again...then not only do you benefit from change, if any in the quality and control of the ride..., but you also will have video of before and after video to see the difference of the water spray coming off the transom to the drive
2FORCEFULL
I will also say this, I had a plate and a -2'' short drive laying on the ground....so I could do either...the boat was a 500hp powered Hallett 210 closed bow..the boat needed some thing done to calm it down....both took about the same amount of time to install... so that wasn't a factor...but, I went for the plate install... ran the boat and had no need to go further...the boat got sold and I haven't heard back on the new owners thoughts on how it performs..
2FORCEFULL
I really like your response , I would say go run the boat and see what if anything it needs... and also as far as rigging, have some one that knows the boat and what they are doing set it up...
buck35
Is the wammo plate something you built ,or purchased?
Does it mount to the drive or transom?
Taboma
Back to the Arneson Rocker Plates for a moment.
After Steve posted about these plates yesterday afternoon, I got to thinking about how the mechanics and leverage cause them to bend to create a hook or rocker, rather than to simply change angle.
Reminded me of how my cavitation plates bent on my old Hondo flatty and how cavitation plates differ from trim tabs.
Reading OSO I'm given to believe these Arneson Rocker Plates were installed and tested on larger offshore race boats, depending on the hull, with mixed results. Most of the complaints and cause for returning to their Kiekhaefer 280 or 380 tabs was due to issues with turning, they weren't allowing the boat to roll over as much into the turns. Or they weren't able to use the long tabs to cause the hull to roll into the turn.
Makes me wonder if they were tested on smaller performance I/Os, where the Hook and Rocker aspect might have a more profound effect, while negating some of the drag caused by trim tabs.
So back to Steve's original question ---- any small boat experience with these ? Can these even still be purchased new ?
I found an older page on the Arneson Web Site with information, but I do not see them for sale on their products page.
I found the mechanics of the leveraging system that creates the hook and or rocker extremely interesting. Certainly not simply a trim tab.
These are rather large, possibly to much surface area for a smaller performance hull.
But I found this picture of a smaller Donzi running a smaller (Not as wide) set.
But back to my initial thoughts on caviation plates bending (Hook/Rocker) versus just changing angle I found this thread RD wrote on cavitation plates. If you look at the Arneson design, the plate only moves an inch or so up, or down, again very similar to a V-drive cavitation plate, totally different than the range of most trim tabs.
Quote from River Dave Jan 13 2016 ----
"If you are a modern day I/O boater you might not even know what a down pedal is in a boat. In V-Drives there is typically two pedals. A down pedal (or a switch on the dash or gunnel) and a gas pedal. V-Drives don't have "trim" like an I/O boat, so they have what is called "Cavitation Plates" on the back of them. They bend those plates up, neutral, down, or infinitely in between to adjust trim of the boat. By bending the plates they are actually bending the running surface on the back of the boat adding Hook (down) or Rocker (up) to the boat. They are basically an extremely efficient trim tab, that has the ability to add positive trim as well when they are in the up position. Picture a trim tab as dragging a plate in the water to create lift, where as a cavitation plate you can move it very little and create a ton of lift, via bending the running surface, instead of dragging something behind the boat."
What’s a set of plates cost these days? Built, installed and running OTD
I don’t think that is even a valid analogy. You have an entire boat displacing water and taking most of not all the pressure off the plate.
The closest analogy would be a notched transom. You are attempting to make the boat behave like a larger one with a notched transom, which should stabilize the boat. To what degree is debatable, at least with the plate parallel with the bottom.
2FORCEFULL
it mounts to the transom... what I use is a step and trim trim tab.. diversified used to make them ...kinda hard to find.. but they are out there used..and if you get lucky, n o s
stevesdcb
Yes, boat is together, have about 8 hours on new motor, running stock drive with Bravo 24. Initial break in was on Sac river, no elevation, smooth water, boat took a set ran great at 60 to 65 mph, still easily climbing didn't leg it out. Took the boat up to Almanor, elevation 4500', same prop, lost some RPMS, choppy water rollers, 60 to 65 mph was getting bounced around pretty good, (didn't adjust tabs down) had both hands on the wheel, wife was holding her boobs a lot.:D
I think you have a little more HP & a -2?, how are your tabs mounted?
stevesdcb
Damn, one minute you had that boat, I was following your pics & posts, then it disappeared like a fart in the wind.
Taboma
Not sure you're looking at it correctly. The occasion for which this Wammo plate makes contact isn't when the entire or even normal planning surface is creating displacement, it's when the hull starts to roll back or pivot as the hull climbs the wave prior to launching. All the plate is doing as it now makes contact with the water (pressurized water rising upwards, after being displaced from under the keel), is providing a slight amount of resistance to that pivoting motion. I've never tried it, but I can tell you it worked on my neighbors Eliminator in the same manner it's worked for Steve.
Understood, and agree. If you HAD a transom notch, would it not function similarly in that situation? It would depend on how big the notch is certainly. I changed my wording to notch here, because that is more closer in meaning to what we are discussing, and what we would generally find of boats of this type and size.. a transom notch near the bottom of the V, not a step across the entire thing.
A notch or step may introduce other changes to the boat handling, but the high part of the notch would make contact with the water in the manner you described in your scenario.
Taboma
Yes I'd read a bit about that boat on OSO, hadn't realized he pushed it to 118 :eek: That's just nuts, since my 2nd boat back in the late 60's was a 17' Formula Jr. and very similar to the smaller Donzi's, I've always dug those things. My buddy and I used to tail-walk that Jr to Avalon and back quite often --- awesome fun going over, kinda wet and wild on the return leg, LOL :p
I'm going to edit this since we're on the subject of Trim Tabs. This same early 60's vintage Formula Jr, was at least at that time the best rough water riding hull I've ever experienced. The entry of that deep vee hull was extremely soft even in the largest swells. But the drawback, with it's rather low HP (289 Ford) at the altitude of Lake Arrowhead was lack luster ability to pull up a large water skier from a deep water start. So I installed helm adjustable trim tabs. Not electric or hydraulic, but manually operated via morse cable. Worked fine for setting them down and getting out of the hole, worked fine for bringing them back to a neutral running setting, but holy shit it took a lot of push to get them back down again once underway. So for the most part once you got them level it added some rolling stability, but very little attitude adjustment until you'd slowed back down.
Well I wouldn’t go so far as to say “truth”. I am still very much of the opinion that the whamo plate does nothing. I am willing to put it to the test though
Taboma
Yes, the degree of influence would depend on how high the top of the notch is from the keel and or bottom (If it's full beam notch).
But at least as I see it (And is visible in Steve's Pachanga video) the water exiting behind the transom is being displaced (Or relieved) upwards with pressure (Created by the boats displacing the water), the resistance offered by the plate against that pressure during the pivot, not only slightly diminishes the pivot force, but slightly lifts the keel, resulting in a subtle correction of attitude.
I think I'm making sense, lol :D
I'm in agreement.. The only question is if that is even enough to do a damn thing at all that someone would or could notice. :)
Taboma
I couldn't tell you first hand, but Steve sure thinks so or I doubt he would have done it on so many different boats --- and my neighbor sure thought so as well, when he mounted the same type of plate in the same spot as Steve. When I saw it on my neighbors Eliminator I questioned him about its purpose and his story was the same as Steve's. That was the first time I'd ever seen it, the picture Steve posted was the same as my neighbors. The only difference is, once my neighbor established the proper angle, he manufactured a very clean version out of welded stainless plate.
At least it's relatively safe, in a manner that wouldn't cause the transom to "Trip" and submarine your shocked ass :eek:
spectras only
IMHO, if a boat's longitudinal center of gravity is well calculated in the building process, it shouldn't have the need for a ride plate. Drive angle and trim tab input should suffice maintaining level ride at all conditions. My boat's CG is totally off having twins, making the boat azz heavy. Single engine Mirages are pretty dialed in during manufacturing process. It is a trade off for having the safety to get home when one engine goes kaput, and no one in sight out the middle of nowhere in the ocean.
Every boat has a center of buoyancy (CB), which is the center of the underwater volume of the vessel. She also has a center of gravity (CG) which is where all the mass would be concentrated if it had to be compressed to a single point. If the boat is to float properly on her design waterline, then the CG must be in line vertically with the CB…. if it’s not, then the boat will correct for it by changing trim (and thus underwater shape) until the new CB is in a vertical line with the CG.
This pretty well sums up the problem. There’s not much you can do about the CB for a given boat (which wanders around with heel angle, but we won’t worry about that since it’s out of our control), and the CG of the raw hull is pretty much a given as well. But the moment you start installing equipment and people it all changes… often dramatically.
sml
I'm truly enjoying a thought provoking thread on RDP about boat setup. [emoji4]
I'll be happy to lay down the thought processes behind mine (including that ride plate response), but I have a few things I have to do tonight. [emoji4] Tomorrow is another day though! I say we keep it going, and I look forward to everyone's thoughts. [emoji4] I look forward to the "rocker plate" conversation as well.
What about the stabs at cole trickle from steve? Delete away lol
sml
guest hs
Training wheels
