79 Howard resto
nrbr
Thank you! Plan for now is Parker enduro and the elsinore enduro. If we feel comfortable putting big power to it ( handling wise) we may go gn racing a little
wzuber
Nice, sounds like a fun plan. I'm enjoying your efforts, quite inspirational. I almost worked on mine yesterday. haha
wzuber
I'm curious and would like to clarify, it appears when you placed the stringers you bedded them on 2 strips of 3 oz. mat? How much wider were the strips than the stringer wood? In the photo it appears maybe 1/2" each side? Do you then come back and grind that extended area to help create a fillet type area at the base of the stringer or do you just let the following tab/layers wrap and roll over it? How does that work?
nrbr
You are correct about 1/2" larger each way. After it dries I just barely kiss it with a 4" grinder knock off the big stuff then ready for tabs.
wzuber
I see, thanks for that reply. When you tab it do you mean you are laying a strip of mat/cloth the length of the stringer extending up and out from the base connection? If yes, how far up/out? Is there a standard ratio for that dimension?
nrbr
got floors sprayed today! Strut is still taped off in this pic. Pretty stoked on boat today
spectra3279
Vaginamoney broke
What did you spray the floor with.
Looks nice
Sent from my SM-G900T using Tapatalk
wzuber
Product called prescoat that I get at the local glassshop
floors look sweet, What grit do you prep with for a clear coat like that? Do you mean prestec or is there a diff. product call prescoat?
nrbr
Yes you are right prestec. 80 was my final grit. A 150 would make for a shinier surface I'd think. I was on borrowed time at the time we sprayed. Gonna run his one as is for enduro then colorsand it when shes pulled apart for anodizing. That's the plan anyways
nrbr
Telescoping/ removable tongue. For launching and so she will fit in the garage
nrbr
Got the plates finished , polished and off to anodized (a long with another set we are doing for a buddy). Had to add this tube to hold swivel jack. Its removable with bolts tapped into 1/4 steel. Welded a plate on the front but left the back open so I could put nuts on as well. Rudder guard tomorrow !
nrbr
Nothing extremely exciting but just waiting on steps and fenders do I can bondo a fee spots and paint it. Stainless fenders are a bit more then I remember
nrbr
Picked up some stainless fenders ! Plan is to weld this plate steel to trailer chassis while fender is bolted to same plate. Should look like a "floating" fender. No steps or bars just a fender. Still messing with clearances ect. I forget how much room to leave between tire and top of fender. 1 1/2" I've heard fully loaded. I'm thinking 2 1/2 or 3" with just the boat ?? Engine and 100gallons of fuel should squat it down an inch I'm guessing
wzuber
trailer build looks great dude, keep chargin. what type of paint finish are you going with? wet or powder?
nrbr
Thanks! Single stage urethane after epoxy etching primer
nrbr
Pics are out of order but trailer has been primed , lightly sanded, then painted! With any luck bunks will be carpeted and installed today
nrbr
All wired up and lights installed! Also set the rudder stuffing box today since we seem to be on a roll light in 1st pic gets pushed in flush
cofooter
Thats cool the way you mounted those fenders!
nrbr
Waiting for some bondo to dry so I thought I'd send a pic of the latest parts! Eliminating down pedal spring completely bu installing a full hydraulic down pedal system!! This boat is very flat so we think it will benefit quite a bit from this. Especially for parker 336 where itll be at speed for quite some time .
Maestro
Damn.......
Thats coming out very stellar....
nrbr
Weve got a lot done but no pics here's what I do have. Scrambling this next week to make race
74 spectra20 v-drive
I love the front cover, nice work on that, the fly wheel cover is incredible as well... looks terrific!
wettrthebettr
You did a Great Job , I am impressed how your 1708 laid out.
I just did some glass work on my stringers and hull bottom, and had a difficult time laying a sheet 23" x 72"
I used west system 105 and 206 harder , I wetted the 1708 then laid it down, It was very difficult to get the air bubbles out before it kicking off.
Keep the up dates coming,
nrbr
Thankyou! I used a poly/ vinyl blend on the resin. I dont have a lot of experience (or the bankroll for ) with epoxy resin. I'd like to get more familiar with it though
wettrthebettr
WOW have you been a busy bee, Those motor mounts came out supper nice.
I like that old school Fuel Gauge, Can't go wrong with that one.
Your way ahead of me on the RESTO , I'm waiting for the tanks and an engine.
The Epoxy is easy one pump epoxy to one pump Harder.
I did not like the way it turns white when you tabbing, with 1708 the epoxy and looks like air voids.
But it is not trapped air, I drilled in one and it was solid.
Keep it going, PJ,
wettrthebettr
What is the thickness of the engine mounts?
I'll have to get some 6061 and cut some up.
wzuber
most commonly 3/8" 6061 is used F & R however if you really want the ultimate in badasserie you could step up to 7075. Are you planning a top of stringer mount system such as the O.P.'s here and many other circle racers installs or the more common between the stringer mount resting on
2-1/2"x2-1/2"x1/4" angle? Amongst the many cool rigging details employed here by the NRBR I really like the chamferred angle on the motor mount pads, in a machine shop it's relatively simple, outside of that a bit more tedious effort. It's clean subtle details like this that make a well built race boat stand out from the others. Nice work NRBR.
wettrthebettr
I was just going to cut the front a simple u shape and bolt it to some 1/2" angle aluminum to my stringers.
I have a 71 Campbell cruiser not a race boat with 12 X 2 stringers .
The rear I have is the standard Glenwood with keys bolted to stringers.
I seen those cool rigging's, they would of been nice in my Aquacraft flatty.
Very nice boat and set up you have.
wzuber
clarification......not my dealio.
A project of that specific caliber is a little above my pay grade yet, but maybe next year?:rolleyes:
I was simply addressing your question on motor plate thickness and acknowledging the OP'S quality detail work.
I have a spare front motor plate very similar to the one pictured if you'd be interested.
wettrthebettr
Oh, I thought you were nrbr.
Yeah a simple u shape mount would be find.
how far do you live from Sacramento,CA?
wzuber
I'm in Diamond Bar,. L.A. County, east boarder near Cal Poly Pomona. I'll pm you my number, you can call if/when interested. I'd rather not tread any further on NRBR's thread. thx
nrbr
Lol no worries at all. Correct mounts that bolt directly to block are 3/8 6061. Update on this project , ran it last weekend and didn't perform like we wanted after throwing 6 props at it. Coming back apart and turning back over to see where we made a mistake..... it's a little evil on de acceleration.
vdcruiser
What is the shaft angle and how far is the strut barrel from the transom ?
wzuber
Evil on shutdown, is it white knuckle evil or shit yur pants evil? Either way that doesn't sound like much fun at all especially on a race boat where hard deceleration going into turns is kinda handy. How are its characteristics in the other areas? Does it set well, handle chop well, accelerate out of turns well? Have any video to share by chance?
nrbr
It has a small period of time the moment you let off where it will aggressively try to turn on it's own, usually right. Boat rides very flat unless you're hard on gas. After talking with some people that have similar boats I've come up with : change steering pulleys to ball bearing and tighten the shit out of steering cables, change the shape of drop chines and drop the gear. No video yet as the ski boat is having a prop made . But will have video next time boat goes on the water. Cant wait to clean 2 boats next test session...
vdcruiser
I know my 21 Howard is different, but I went with 7.5 and 27" and it did wonders for it. Of course I was trying to get it to carry the bow and take a good set at full throttle, and I usually decelerate gently.
