FlyByWire
I just work here
- Aug 13, 2016
- 3,371
- 12,184
1000hp toon. Insane to me. Makes my single 400 feel so insignificant.
![Face with tears of joy :joy: 😂](https://cdn.jsdelivr.net/joypixels/assets/6.6/png/unicode/64/1f602.png)
I lost a complete lower on a 2.5 (280) off of my DCB in front on Copper Canyon in 2000. Sheared the bolts. I am sure it's still down there with the cleaver attached to it.treasure hunters like me get excited over this![]()
Run 80 you think?
We shot both the V10 400R and 500R in Sarasota FL at the end of last year. Then finished up collecting content on the 500R in Havasu right after SCFW. All the boats were running the actual engines at both shoots. Today there were about 15 boats with the new engines running in Charleston. It’s always amazing working with Mercury Racing. To say they are professional is a gross understatement.Tommy Gun was doing the stills for that shoot, he just posted them on his Instagram.
I’d also like to point out that AJ and the crew at BCM work on a whole different level than most shops. The work they did to swap 7 outboards practically overnight for the Havasu shoot then turn around and swap them back AGAIN after the shoot was nothing short of impressive. AJ works very hard for the industry relationships he has and it’s awesome he and Taylor were able to come out and spend a couple fun days.
Thanks man!All your pics on Instagram are just awesome.
If you people aren't subscribed to Tommy's account, you're seriously missing out!
Login • Instagram
Welcome back to Instagram. Sign in to check out what your friends, family & interests have been capturing & sharing around the world.instagram.com
kinda needle-in-a-haystack,but if you punched in a GPS waypoint certain times of year the visibility is decent and pretty shallow around 50 feet.that would be a GEM to find!!I lost a complete lower on a 2.5 (280) off of my DCB in front on Copper Canyon in 2000. Sheared the bolts. I am sure it's still down there with the cleaver attached to it.![]()
We’ve tried. Buddy and I geared up and dove looking. Top had good vis and 20 bottom was horrible. Had to follow the bubbles up. Couldn’t see my hand. Total vertigo.kinda needle-in-a-haystack,but if you punched in a GPS waypoint certain times of year the visibility is decent and pretty shallow around 50 feet.that would be a GEM to find!!
wonder if that was from mud stired up or micro vegetation type stuff that changes with water temp?We’ve tried. Buddy and I geared up and dove looking. Top had good vis and 20 bottom was horrible. Had to follow the bubbles up. Couldn’t see my hand. Total vertigo.
Now at the weight of these outboards vs a strong I/0 is there any advantage anymore especially with the price tag of a 450-500?
68-78k would buy you a nice solid drive and great 800-900 hp big block that can be reliable. From reading it seems the outboards ain’t as solid either with lower unit failures.
For center console boats I can see where multiple are run. But a lake cat twin engine deal there’s room for twin I/os
I think even twin 500s are lighter or at least equal in weight to a 8-900 big block. Mercury 700 is spec’d at just over 1,500lbs and a 600 is listed as 1250lbs. Mercury requires a transmission on the 700 according to the website.The thing is it will only take 2 400s with a warranty to outperform that 800-900 HP big block you rolled your own on with. I warranty bolted to a drive you will probably break.
It only requires a trans because it's paired to the #6 drive.I think even twin 500s are lighter or at least equal in weight to a 8-900 big block. Mercury 700 is spec’d at just over 1,500lbs and a 600 is listed as 1250lbs. Mercury requires a transmission on the 700 according to the website.
Moving the center of gravity back also allows the hull to air out more.
There’s drives that will work great on 8-9 hundred hp. Now if they go to a 6 or equal that power can be taken up easily. Guess it comes to preference. Eventually warranty runs out too.The thing is it will only take 2 400s with a warranty to outperform that 800-900 HP big block you rolled your own on with, that is bolted to a drive you will probably break.
You can with a 400r. The prop shaft is what plagues the new outboards, I haven’t heard of any gear failures.With the 450/500r can you punch the throttle at stand still? Will the drive handle it? I drove my friends super charged big block with an scx Cat and I had to ease into the throttle. Which I hated.
With the 450/500r, can you punch the throttle at stand still? Will the drive handle it? I drove my friends super charged big block with an scx Cateraman and I had to ease into the throttle. Which I hated.
500R is rated at 726 poundsI think even twin 500s are lighter or at least equal in weight to a 8-900 big block. Mercury 700 is spec’d at just over 1,500lbs and a 600 is listed as 1250lbs. Mercury requires a transmission on the 700 according to the website.
The Mercury I/O specs are motor only correct? Any idea what a 600 with B1, steering, exhaust etc weighs? I know it changes from boat to most.500R is rated at 726 pounds
I’m curious to see what happens with 600 outboard sales.
Agreed but there’s a few center consoles 35-45ft that offer 3 600s or 4-5 450s. 500s with the weight savings get interesting.I think the 500 and 600 outboard are 2 different customers with 2 different types of boats.
Center of gravity is as much or more important than the overall weight of the engine.I think even twin 500s are lighter or at least equal in weight to a 8-900 big block. Mercury 700 is spec’d at just over 1,500lbs and a 600 is listed as 1250lbs. Mercury requires a transmission on the 700 according to the website.
