YeahYeah01
- Apr 2, 2020
- 2,248
- 2,907
Need some advice.
Project truck that I've had for to long but starting tinkering with again.
1977 f150 with the 351M. I know it has an RV cam.
It's never ran right and I've almost never driven it or ran it because of that. I rebuilt the carb and put fresh fluids and sparks plugs. Got it running but it was running like shit. Sounded like a tick but thought that could be the cam. But I put a vac gauge on it and had almost no vacuum and it was bouncing everywhere. Figured a stuck valve so pulled the covers. And ended up pulling the rockers off to. Found about 6 bent push rods. 2 so bad they would not come out. Had to pull the intake off to get em out.
I'm going to order new push rods but I'm thinking of pulling the lifters to to inspect them. What the easiest way to pull the lifters? I've never done it, then do I just check them with a straight edge? Are the easy to put back in?
I have no clue what caused the bent rods. Hoping its the problem and not the symptom. I do have one stuck valve that I'm going to soak down and see if I get it unstuck.
