23 kryptonite
Headless hula
Ran to where my air compressor had been in storage and hauled it to the new shop.
It's an old rol-aire. Leroi 2 stage pump, 175psi and 120 gallon tank. She makes quite the breeze. ;)
Xring01
I have come to the conclusion, that you prefer to work on boats, than to drive them...
You should try driving them for a change, most people think its alot more fun, than working on them... Especially in the summer time..
No I dont want to hear any excuses like
My dog ate my sand paper, or
My house burned down, or
Stupid shit like someone stole all my tools...
Just saying... driving boats is far better than working on them...
Headless hula
Lol... I've posted a few pics in the post whore thread..... been driving the hell out of it. ;) figured I would finish out the thread...
Headless hula
It's a fuckin hotrod. 23' that drives and rides like a 27-30'er....
I can't explain it via words. You need to ride on it. At 65 you have no idea you're going over 40...
Its smoother, quieter, and faster than any 2 stroke ever ...
DrunkenSailor
Boat looks real good at speed. Hows the water pressure? I'm thinking you can raise that big bad white motha another inch.
Headless hula
The water pressure is LOW.. I'm constantly getting tossed to guardian...
It's a careful balance for sure.
Pin the throttle and trim it to the moon is not a suggested mode of operation with this deal. It likes just a tick above neutral trim and a tad more jackplate.. .
Just ran @ 72ish on glass in the rain
Poptart never got her hair wet. ;).
This boat is a fucking riot...
DrunkenSailor
Awesome. Sounds like your having some much deserved fun.
GregG
Assuming still in break in mode with the motor. Lot of props to choose from.
Headless hula
Replaced the starboard side interior panel. The old one had a cutout for the cable style throttle and shift levers.
Headless hula
Finished the rigging. I used 2/0 for battery cables, and feeding it fuel with a 1/2" line.
This was the night before a "lunch run" on the weekend of the 4 horseman poker run here in oshkosh.
Headless hula
Friday morning of the 4 horseman.
I took it to the water around 730 a.m. still had to finish bleeding the power steering, and a shakedown run. I bled the steering at the ramp. The electric pump starts 5 seconds after the engine starts running. As long as you're quick to keep the reservoir full, it's a really simple operation. A few cycles of turning it lock to lock, I could hear that there wasnt any more air in the system.
Ran it around a little bit in the bay out in front of the house, and brought it to my dock. Seems everything checks out so far.
Break in according to the manual says keep rpms at 4500 and limit wot to 1 minute every 10 for the first 2 hours.
Headless hula
Ran from the house east across the lake into oshkosh. Met up with a bunch of friends from out of state. :)
We crossed lake winnebago and met up at stockbridge harbor for lunch. Its around 11 miles from the mouth of the fox river.
The guy with me is from Minnesota. Last time I saw him was at desert storm. :p:p
Headless hula
Came back home and put it on the lift. Drove my pickup back to dockside tavern where the friday night festivities happen.
It takes 40 minutes including idling out of my channel to being tied up at the docks on the east side of oshkosh. By the time I returned from stockbridge to home, my first 2 hours of break in were completed.
Having a beer with Rick Mackie.
Headless hula
Poptart came over after she was done with work, so I left the poker run crap and took her out for a ride.
Headless hula
I put a 25 3 blade fury on it to start, as that's what I ran on the opti. It was "ok" at best. Basically on the limiter, was easy to blow out while getting on plane. A labbed 26 bravo was a big upgrade. It's on the limiter right at 80, showing 18% slip.
A few weeks later a couple wheels showed up to go and try...
The one in the top of the pic is a 26 maximus, the other a 25 max 5.
We weren't sure if the 400 would pull the big ass 26... it's a YUUUUGE prop...
I'll be damned if it did.
Ran 80 at 6660.
The 25 max 5 ran slightly better at the same rpm and 81.
I liked the feel of the maximus over the max 5.
Now were going to run a 24 maximus to see about getting the rpms back up to 7k.
There. Thread is now caught up to being current.
Only took a little more than "2 weeks". :)
Headless hula
Looks great!! Does this 400 like the bigger diameter props or is it just the V8's ?
We're still sorting that all out. Having the jackplate is a great advantage. Boat sure seems to like 1.75 above bottom. I do not have to lower it to get on plane. I bought some go pro knock offs on Amazon and haven't even tried using them yet. I need to get a suction cup mount, then I'll try and get some video of the gearcase at speed. :)
lake p.a.l.
Gonna be an awesome boat. Do you have the 1 piece prop shaft or the pile of shit 2 piece? If its 2 piece, make SURE you only run Merc props, have receipts for when it breaks, not if.
575cat
Did Adam have his Outerlimits there or is it still boke ?
Headless hula
It was suggested that I take data every 500 rpm or so.
Note the ecogps reading on the right side of the screen....
Over 5 mpg putzing along at 35mph!
3mpg at 65!!! Wow! Midrange cruise is awesome!
This is the 24 maximus. Fuel tank is full at 55 gallons. All the crap on board. Not looking for a huge top end number. Just normal boating.
GregG
A few weeks later a couple wheels showed up to go and try...... a 26 maximus, the other a 25 max 5. We weren't sure if the 400 would pull the big ass 26... it's a YUUUUGE prop...I'll be damned if it did. Ran 80 at 6660.
There. Thread is now caught up to being current.:)
So the best GPS speed you have seen so far is 81mph. Interesting.
Headless hula
My guess is it'll wring out at 83.
Went 81 with over 25 gallons in the tank, all the normal boating shit on board. Anchor, 4 big ass fenders, 2 pillows and 2 blankets in the cabin, small tool kit in the bench seat. Theres lots of extra "stuff" in the boat. I'm sure if I pulled all that shit out and ran it in fumes with literally me and a life jacket on board I'd pick up an easy 3mph.
I dont really give 2 shits about the big end "number". I want it propped correctly, continue to have fantastic handling characteristics, and enjoy a wonderfully long range. :)
It's pretty easy to cover 100 miles here in a day. To go all weekend without filling up the tank makes for a helluva good weekend of boating! :cool:
pwerwagn
Inmate #4800
Looks badass!!! I dig it. 80mph is an awesome number for a boat that size that can get that fuel mileage!!
lake p.a.l.
Sounds fantastic Hula!!! What kind of wind chop is it happy in? I'm sure you can slow way down, put the nose in the air, & get thru almost anything. Great boat, congrats
Headless hula
Thanks!
Right? Comparatively, the best I observed with the 250xs was 4ish mpg at around 45 mph.
I'm digging it for sure!
Headless hula
It loves a 1' chop. Been thru all sorts of cruiser wake washing machine stuff and it skips over the top at 55-60. Slower it gets rougher. Folks out east rave that it's a rough water boat. I can't find anything to disprove that.
All my speed #'s have been literally on piss flat, glass conditions. Sticky water.
That type of water will also magnify hull deficiencies and weird handling characteristics. String straight, no chine walk, nothing weird. With the 26 bravo, I'd over trim it, to get the rpms up, then it would take some sawing on the wheel. With the 24 maximus, I'd let anyone drive it to 70 no problem.
Singleton
So pissed my schedule will not allow a visit this trip.
Would of loved to fill the gas tank (1, 5g container at a time) or at the marina for you and taken a tour.
This is likely the last time I bring my daughter to Chicago to visit my dad and step-mom. Not 1 photo of me or my dads only granddaughter. All photos are of my dads second family. Not sitting well with me. I should of gone north to start and just spent the 4th through 7th with them and taken my daughter north to see family. However, before this trip, I wanted my daughter to know all her grandparents, not feeling the same after 3 days with them!
Headless hula
Robert, there's always a spot here for ya. When your schedule allows, itll happen. ;)
Bummed to read about the family stuff. Some folks just dont get it. Hopefully it doesn't affect how your daughter feels about the midwest.
Singleton
My next trip to the Midwest will be all wi, so munch daughter can see my moms summer house and the family cabin (that trip will be in the next 2 years).
Headless hula
Glad I zoomed in close enough to hide the disaster in my new shop. :eek:
Have been slowly getting organized in there, but it's still a hot mess. :(
Headless hula
Figured I'd better update this here.
26p maximus short tube.
Ran it back to back with a bone stock example.
Gained 4 mph over the standard version.
The longer tube is added drag, and does not allow as much trim.
If I can get my hands on a labbed version, that'll give me the last 300 rpms, and maybe 2 more mph.....
Holy shit batman.....
Headless hula
Getting a set of K-Planes ready to be installed. I had to change out the studs for longer versions.
chased the threads to get the red locktite cleaned out.
C08H18
What prop did you end up liking better - the Max5 or Maximus? I think I read you cut off the diffuser on the Maximus? Is it the same length as the Max5?
