21RC V-Drive Triple Axle Trailer
SFV2RVR
Registered Parker Legend
I finally pulled the trigger on my triple axle trailer down at schiada. Here are some of the build pics as it is being built. Its gonna have 17" torq thrust 2's with stainless fenders. disc brakes, frenched L.E.D's, swing away tongue, cat walk, extended rear steps for longer cav plates, and rollers in the back.
SFV2RVR
How much $ ?
Im bringing them the wheels and tires, taking care of the powder coating, and all the lights and wiring. Basically they are building me the chassis and thats it! You would have to call stan at the van nuys shop for a price.
LV R SCHIADA'S
Nice, you'll love those disc brakes, Mike will hook you up on that build, you sure you want it powdercoated, the Cardinal Hi-Solids paint they used to use at Ellis was some nice stuff, held up extremely well, may want to think about that ???
One thing I did on mine when I did the catwalk flooring was seal the wood prior to covering it with the marine grade carpet and used all stainless fasteners.
Keep us posted.
Scott
SFV2RVR
Keep us posted.
Scott
Scott, I originally wanted to use the cardinal Hi-Solids paint, but I cant find anyone out here that does it. Im definetely gonna seal all the wood for the cat walk before I cover it too.
Schiada Time
Gotta powder the trailer yellow dude. Gotta powder it yellow. White trailers just dont look that cool
SFV2RVR
Im going with black! It would be waaaay too much yellow if I did the trailer yellow too. I agree with you on the white also.
I'd do it yellow if it was me Mark.. :) Black doesn't really match anything on the boat? (not that it won't look sick)
Maybe a pewter grey with yellow tones? or vice versa.
sangermike
how about white with a yellow perl overlay. :skull
LV R SCHIADA'S
Mark,
There is a Cardinal Dealer by the Sky Harbor Airport here in Phoenix, pretty reasonable for a gallon, I think I paid around $75, you could maybe see if Zieman in Havasu would spray it for you?
SFV2RVR
Here are a few updated pics from today.
Rollers are installed
Corners rounded on extended steps
Stainless bezel that I had made to fit 15" L.E.D's
Aluminum spacer that I had made so I could use the center cap of my wheels to still work with bearing buddys. (There is a clearance issue without using this spacer)
Mondorally
How much for 6 spacers? I have torque thrusts sans center caps on the 27' trailer. :D
Mark, couldn't you just make a little wheel spacer that goes behind the wheel so the center caps would fit still? Or were you concerned about that making the trailer too wide?
SFV2RVR
I could've done that, but didnt want it to wide. Someone also mentioned that I could have also machined 3/4" off of the bearing buddy, but when I asked about it, they said the way the bearing was assembled you wouldnt be able to do it. This was the easiest and most cost effective way I think.
Wavemaker
Just my thoughts: Black trailer with some tasteful yellow pinstriping matching the yellow off the boat would look cool. Great job on the spacers for the wheels and caps!
SFV2RVR
Helped mike @ Schiada flip the trailer over today. Time to weld up all the bunk supports.
All the axles showed up while I was there today too!
SFV2RVR
I was gonna do black, but i'm actually leaning towards a charcoal gray now. I just think yellow is gonna be too much yellow!
SKIA36
I like the charcoal...with white/yellow pinstripes.
SFV2RVR
Bunk supports all welded up.
All the axles would have been installed today too, but realized the company did not send V-Drive axles!:smackhead
CampbellCarl
Looking good Marc!
The box that creates the rudder/prop guard, are you planning to infill that space? Polished diamond plate would look nice there, help protect the prop from road rash and if one of the 15" leds is goin in that slot forward would look bitchin at nite!
CC
SFV2RVR
Looking good Marc!
CC
I didnt plan on filling that space. A 15" led is going in the slot that is already cut.
CampbellCarl
OK, got it...........now go ahead and put the polished diamond plate there and tell everybody that it was your idea!.......I'll never tell and it'll look VERY cool!
Marko
BIG member
V-drive axles? enlighten me please. :headscratch:
SFV2RVR
V-Drive axles have a "V Bend" in the middle instead of being totally straight like the ones pictured. I guess they make them so that there is clearance for the Fin and the underwater gear.
Schiada Time
I moved my bow stand up a 1/2-inch on my 22 trailer for this very reason so when my boat is winched up in the bow roller my fin will be ahead of the axle so when it travels up it wont tap my skag
Marko
BIG member
I thought all axles had a little bend in em. The ones in your pic arent straight, they have a little bend in em. Now ya got me wonderin, I guess I'll have to look at mine tomorrow and see what you're talkin about. :headscratch:
SFV2RVR
Mike at schiada told me that the "V-Drive" ones are way more exagerated than the ones pictured.
SFV2RVR
Got all the fender steps mounted.
Welded all the "ribs" in place to support the cat walk.
Cut the plywood for the rear extended steps.
Cut all the plywood for the cat walk.
Got back the tongue from chrome.
Schiada Time
Looking good Marc. I should have my trailer back later this week from Hampton Trailers. Full restoration was done.
Marko
BIG member
Lookin good! Hurry up , its gonna get warm in a hurry! :champagne:
djunkie
Broke mo fo
Just curious, what are you doing with your old trailer?
Marko
BIG member
So post some pics of the " V-drive axles"
SFV2RVR
They are suppose to be here on Tues. of next week. The one you see in the pic, is the wrong one. He was just using it as mock up so he knew where to mount the steps and fender. Your axles on your schiada do not have a "v-bend" in them because they are mounted with leaf springs, so they sit down lower. Mine are torsion bar, so on a v-drive they need extra clearence for the underwater gear.
Marko
BIG member
That makes sense.
420HOA
FIRM MEMBER
That makes sense.
There only 2' long on my trailer, they dont go across the center, I thought it was pretty slick, keeps the whole center of the trailer open.
Marko
BIG member
I've seen those before. Cool set up for V-drives.
Bense
lookin good marc - Can't wait to see it.
SFV2RVR
Here are the V-Drive torsion bar axles ive been waiting for.
Here are some pics to show the clearance they will provide for the underwater gear.
Marko
BIG member
Wow! Nice! a radius bend ! I thought they would just cut em up to get the V in em. Those are cool.:thumbsup
steveo143
Looks great. Would be over the top with one of these! Yes, it is a shameless plug.
