2018 Schiada w/ Merc 400R Outboard
rivergames
Interesting how the rear hatch will be side hinged, a little different. I'm curious, why a RC and not a 21 RT? Wouldn't a RT ride better and be faster? Or was the 400 to heavy for the RT?
RT's are faster, but don't turn like the RC will.
I can't so see how the hatch work will turn out! Gonna be trick when at the sandbar!
Andy01
Yes true on the turning part, and being in Parker that is kind of important :D. I told Lee I wanted a 24RT with a 400. I like stuff that is new and different, the idea of the hatch is a great one. Especially if you can open each side separately. Have a buoy holder in one side, and the hardware in the other, or some nice use of the area.
rivergames
They will both open separately. I also have 2 bouy brackets to be mounted under the hatch. At the sandbar, I will keep 1 open with my cooler inside and a wired remote for the stereo and the other one closed to get in and out of the boat
rivergames
Also, why go 1 400R on a 24', when you can go with 2!?!?!
rivergames
I agree, if you got the cg right with a tank in the front or weight simply added in the bow I'd think a 24 with twin 400's would run well.
My 2 batteries and pumps are mounted under the deck to help with weight
AZMIDLYF
River, do you have a ballast tank as well? Transom pick up?
HB2Havasu
Love your new hot rod! Did you buy the 400R separately or thru Schiada?
milkmoney
Love the colors. Not an outboard fan , but it is going to haul the mail....
How many shit boxes do u need [emoji6] [emoji202]
Sent from my SM-G930V using Tapatalk
rivergames
I had a older 21' RC V-Drive (that I bought off Commjnity on RDP) prior that I was going to convert to hang the 400R. I even drove down to SD and took the boat to Kevin at KMG. It was going to cost a lot of money and still not be as stout as having Schiada lay up a new one. I made a deal with Boatmasters at that time. Then had Schiada lay up a new hull and sold the other 21 that Boostpower just finished up!
TCHB
Nice boat.
Garages look like where I grew up!!
rivergames
I sold my 20' at the beginning 2017. I've just had my mini as my river boat! She's still running tits!
Rivrat
Maybe with the right driver..
KAP
Today was a GOOD Day!
I've kept this boat project quiet, but she is so close to hitting the water!
Took my 2018 Schiada with a Merc 400R Outboard to Quality Performance Marine in
Corona, CA today. They are a Merc Certified Shop that completely knows what they are doing! I have never experienced a shop that was so on point with everything needed to be done!
Over the years, I have never used Quality Performance Marine. Well today, they made a customer out of me!
If anyone needs quality work done to their boat in So Cal, I fully recommend Quality Performance Marine Phone: (951) 735-5503! Thanks again guys!
Today, my new hot biatch fired up for the first time on my new Schiada!
After she was dialed in at QP, I dropped her back off at Schiada for the install of the Interior!
She should be getting wet for testing in 2-3 weeks!
Great post and I will join your comments and add the following. Quality Performance Marine is a Platinum Mercury service center specializing in outboards. I take my Doug Wright to them not because I have to but because I want to! I have tried other alleged outboard shops only to discover they were all hype and no substance.
I live in San Diego and it is a 2 hour trek along with setting up appointments for service work at QPM. The staff at QPM get it done and fix the problem and make recommendations if they see any other issues. I had a trim issue on one motor spent three days at another service center that allegedly knows outboards only to leave the establishment with the same problem. So why did I go to this other service center...simple I wanted an alternate choice for service. As it turns out I had to go to QPM who found the problem in minutes and corrected the issue. Moral of the story always take it to the shop that you trust and has a track record of getting things done.
I have an issue right now with my wife's boat Merc 150 OB and will schedule service with QPM here shortly after the Memorial weekend.
rivergames
Saw your boat hanging on the wall right when you walk into the office! Looked good bud!
Reactions: KAP
1. For improved visibility for the "Right of Way" starboard front quarter.
2. To offset (With driver's weight) the right hand prop torque rotation which can cause the boat to lean to port.
Smaller boats have plenty of visibility to the port side from the starboard.
And when a motor is ran in a surfacing position the blade re-entering the water tends to lift the starboard side slightly more so. And most performance Outboards are ran in a surfacing position in one way or another.
Sent from my SM-G935V using Tapatalk
Essentially my explanation was generalization of why "Most" manufacturers decided long before you were born to run the helm on the starboard side. I do realize that certain applications might prefer the opposite, like circle racing as one example.
Also with the increased popularity of open bow seating, again the starboard helm would provide better viewing of your "Give way" quarter.
Interesting, so lifting the starboard side is wholly different than dipping the port side due to torque ? Wouldn't it still be advantages
to have more weight on the starboard side to offset or mitigate this lift ?
I think you two are agreeing
Yup. It appears my misinterpretation of your post screwed shit up. Lol! Appears we are in agreement. Lol!
SBMech
Fixes Broken Stuff
74 spectra20 v-drive
That is outstanding, love the floors man. You are making me dizzy with everything you have going on brother, and it all looks great!
rivergames
Thanks bud! She is set up to be the perfect Parker boat for what I do on the river.
Wait till you see the hatch setup after all the interior is complete!
footer
looking for a v-drive
I have a new favorite boat. Freaking awesome.
rivergames
Today was a damn good day!!!! She tested better than expected. I never take a selfie, but I'll take that one!!!!! Only cruised her up to 55 to test her out at Lake Pyramid.
I'm so F'n Stoooooked!!!!!!
My brother will post video tomorrow!
Thank you to everyone at Schiada for the amazing piece! I can't be any happier with her!!!!
rivrrts429
Arch Stanton...
Congrats, that is a bad ass ride.
Love the dolly style trailer too. Kind of a hybrid. Can you share details on it? This would be something that I could definitely use.
X Hoser
BEAUTIFUL BOAT!!! 'nough said! Still regret not buying the 21 RC hull and trailer form you.
SKIA36
You'll see it cross the finish line of the Enduro for the gold! ;-)
I will bring the Blue fin tuna sushi and the TYKU Sake to the buffet on the deck of this incredible Sheee haaaada. (Will be on a 3.5 day tuna trip out of SD on the Ranger85 7/27-31) But you will have the Bronze as we #312 and #307 will be ahead of you!!!!!!!!!!!!!!
Love ya baby!!! I will bring my Maja and push that sled to the wood!!!!!
dezrtracer
That is one bad ass build ... Great job and can't wait to see it in person ....
rivergames
All day! I told my brother I'm pissed we didn't bring our rods for some bass with some LA Chlamydia in Lake Pyramid!
Man nice job all the way around!! Love the details and the simplicity of it all! Red pins on the hull and motor are subtle but perfect! Nicely done!!!
Uncle Dave
Looks great and super fun! Congrats.
What are you expecting to get out of it?
I just put that same fosgate head in my boat.
UD
Hallett_Whacker
Such a nice boat.
The attention to detail is phenomenal. Not too many RC outboards out there either.
Nice job!
