2017 ford f350 power outlet wont work with igniton off
vstdispatch
Is there a way to have my power outlet work when ignition is off? I can't stand not charging phone when truck is off
Melloyellovector
Costco mycharge power hub. Plug into outlet, then plug into phone. Honestly you could likely charge it once or twice a week and charge phone‘s everyday.
I use it for glamis to charge phones, tablets, headsets for sandrail etc. I charge it maybe every other trip. About same size as phone, but store a lot of power.
Angler
Tritoon Racing
Easy to run a wire from the battery or fuse box.
Angler
Tritoon Racing
Why do this when it's already set to work that way
You can run a direct positive straight from the battery, or the hot side of a fuse to it. Just put an inline fuse on it.
Your lighter will have 12 volts where the key is on or off.
TimeBandit
FORScan can do it.
BCM configuration
Modify outlet power settings (power point timeout)
Save, and test.
