1988 Vector V-drive
Blownbillybob
Custom made hole saw 12”
HAP
Same way I did mine except the hull was bottom up.
R,
HAP
lenmann
Awesome! Thanks for sharing the pics, I've got one to do later this year.
wettrthebettr
Your project is coming along nicely
That is a cool way to drill the Hull, reminds me of how I used to install a Lateral sewer line insert, then tapping into main sewer line, then trimming with a root cutter
Sounds gross but same technique
Blownbillybob
Been awhile but slowly working on it again been super busy lately!!!!
v-drive is mocked up!!! Braces are done also but didn’t get a pic!!
rudder is out and stuffing box is out!
making new blast plate extending it a couple inches as the prop has forward of the front of it jus a smige???
Blownbillybob
Doing some glass work this weekend!!
Extending the blast plate 2” cause the strut got moved forward!!
This pick is looking from inside the boat with a light shining up from the bottom!!
so u can see where I have routered the plate recess forward 2”U can also see where it looks like they were gonna run a drop threw strut and did the cut out and holes but from some reason it didn’t happen?? And they plugged it??
I did notice some funky glass work on the inside of the boat but had black gel over the top and didn’t realize what was going on till I ground it out!
and I’m glad I did !!!!! Proper repairs coming!
bunch of parts at the polishers now and waiting for some stuff from Menkins
Blownbillybob
First layers of 1708. 2 layers over the first cut out 1 over thewhole thing then 2 more for the blast plate relief. And more to go??
Blownbillybob
new cav plates made up with revised water pick up location ready for polisher
lenmann
Wow, you have been busy.
The bilge looks great, what did you coat it with?
On the rudder, how did you determine how long to make the keyway?
Did you make a new blast plate or weld on an extension?
Keep up the great work!
Blownbillybob
bilge got sprayed with gel coat!!
key on rudder I measured off old rudder
new blast plate!!
pixrthis
Really nice work, I can’t wait to hear how much the handling is improved. I helped rig the first Vector v drive with the plates on piano hinges, the owner tried lots of new ideas that didn’t work out that well. I think your handling is going to be much improved.
Blownbillybob
Thanks!! Been a long 2yrs on this last go around!!
the boat actually handled really good before!! My gripe was that it wasn’t mile an houring ??
And the strut was more set up for family ski/ cruiser!! I got most of the setup #s from coin toss and it’s close. Somethings landed a little different but I think for the most part it should be fine !!
Blownbillybob
Score the anodizing
