1988 Vector V-drive
Blownbillybob
These are the snap rings for the intermediate clutch pack
The top right is stock .095 the lower 1 is a stock ring out of a torgueflight trans it is .110. Top right is a Spiro lock and is .085
This is what holds the 2nd gear clutch pack in the case the stock ones are know for popping so u can get the thick 1 which has more tension to it or the Spiro lock which is not going to come out!!
Now u also need to remember this mostly happens in the automotive world and may not be needed in a boat trans if u plan on not using second gear very hard. But it’s also cheap insurance. About. 12.99 for the Spiro!!!!!!
Blownbillybob
View attachment 618299 These are the snap rings for the intermediate clutch pack
Oops. The left is stock
Blownbillybob
Some more head work today!!
Checked guide clearance they were about .0017 so took a couple tenths out. A few were a little tighter???
And a surface job!!!
There Hot tanked bagged and waiting on some springers!!!!
Outdrive1
[emoji106]
Blownbillybob
So as I’m waiting on parts one of my customers transmissions shop is closing down,so he tells me grab whatever core parts I want??
So I see this trans in the back with the HD on it and ask him what’s up with it he said it’s his last core and for sale??? Price was wright. I grabbed it!!!!! It was out of like a 2 ton bobtail with E brake drum on tail so I tore it down and it was like new inside!! Cleaned it up and transferred my parts over!!!
Blownbillybob
So the front pump was like new on the HD trans!! So rebuilding it for my boat trans. I came across this upgrade to restrict the fluid to the converter. I have no converter jus the power adapter!! So don’t need all that oil flow up there for nothing when it could be going somewhere else!! So I tapped the hole 5/16-18 with a starter tap jus a few turns and use a set screw, drilled it with a .125 drill bit and locktite it in!!
RogerThat99
Parker Is Now OPEN
I've seen that boat before on the Delta. That first picture is Discovery Bay Ski Beach. I think the guy brought it to one of the Dog & Andy V-Drive deals last year. I don't know anything else about it. Nice boat.
Blownbillybob
Yes!!!!!
GOLIATH!!! WILL be coming to a water way near U soon!!!!
BE READY?????
Blownbillybob
Checking timing marks to see if TDC lines up and u can see it’s a hair on the top side
Ever see stainless steel freeze plugs ?
Checking clearance and figment before sealing up the pan
Blownbillybob
So I picked up this nice KE intercooled on OSO awhile back. Got it and put it on the shelf!!!
So I pulled it out to check a few things and was looking in the holes and seen some crap?????
So I took off the end cover and looky here!!!!! WOW??? Really!!!
That would have been a bad deal !!!
So cleaned it up. There was like big chunks of wood stuck in the passages, blew them out most of them are clear now but 2 are clogged was using some bailing wire and got most of them clean but 2 so gonna find something alittle more heavier!!
Blownbillybob
Not my first choice out of the 4 that I have but the best fitting to the engine
Still a good manifold tho!!
I picked it up quite a few years ago at a swap meet and jus wanted to make sure everything was flat and square only .003 off the bottom and about .006 off the top!!!!
farmo83
View attachment 609544 View attachment 609545
Can’t find a name it says 12. 15
But I measured from center out to the edge of 1 blade and got 5.5. So looks like it’s been worked over
I was under the impression Stainless wasn't good in these kind of applications as it more of a risk to throw a blade at high RPM as it doesn't flex. Not trying to thread jack or anything just curious.
vdcruiser
Yes, be careful, I've thrown a blade off 2 different stainless 3 blades on my 21 Howard.
Blownbillybob
Jus talked to menkins on Monday from what I understand is they do flex work harden then snap off???
So will be getting a new prop and Might have to regear, motor is going to be dynoed for sure now so I can get some real word #s
But thanks for the heads up!!!!!
Blownbillybob
Have dual cable set up!!
Didn’t like the 2 into 1 bolt set up??
Bolt was super loose in the hole and beat up!!!
This is 7076 alum with 2 separate bolts and swivels. I hope it will work for a hyd steering set up later down the road
lenmann
Nice work. You have a hell of a broad range of skills.
Keep the updates coming.
Blownbillybob
Straight from the polisher to the mill and was off a little
I like this style carb adapter?? Don’t know why?
Maybe because the blower has a fuel enriched atmosphere to suck from instead of those little 3/4 thick plates not sure if it’s gonna make that big of a diff. Will see what she does on the Dyno???
Blownbillybob
Blownbillybob
Got an idea
Didn’t like the stuff I was finding on line and in catalogs. So making my own 1 off???????
Blownbillybob
So motor is jus about done gotta get her on they dyno hopefully???
So changed int manifold to another 1 I had all because I couldn’t get my temp sensor installed anywhere on the other 1. And this 1 fit some what better. But went threw all the #s on this like the other 1 gasket match mill all surfaces!!!
Plus. Like my new kick a$$ thermostat housing!!!!!!
Blownbillybob
Ready for some. Cubic Inches
Blownbillybob
Here’s a little inside shot
Modified the c-500 side of safety loop that’s bolts to the 500 was pretty shady????
And last year I made a new driveshaft with spicer lifetime 1350s both ends and forged slip yoke. The old 1 had a 1310 in it???
Never mind the mess memorial weekend is coming fast!!! And I’m thrashing????
vdcruiser
Like what you're doing here, I might have missed it but what are the specs on your engine/blower/v-drive gears ? You know you sorta grabbed this boat out from under my nose, I live in Va.
Blownbillybob
Ha!! Caught U sleeping!!!
533CI. Pro-Topline heads ported flowed
Solid roller custom Bullett cam
8-71. 10psi
Not sure on gears. Someone changed them. Either. 1.29 or 1.32 ???
vdcruiser
Sounds good, she oughta run . I use a 10:71 on a 548 ci with a bullet solid roller and 12 psi boost. It runs pretty good and has been very reliable. I also run 48% gears with a 11 3/4 X 16 Menkens 2 blade. You'll probably have to try it out to find the best gear set up.
sintax
And thats where the C500 gets painful. Trying out gears is not an easy (or cheap) proposition.
I cant wait to see some vids of this thing running. Everything looks so good on it! Keep up the work.
oldschool
Ain't that the truth. Depending on what you're doing with the boat might be better going to a split case. Another thing to look carefully at is the way the prop shaft fits in the output flange. Any slop in there and you have the potential for a big issue. There are a couple fixes for that.
Blownbillybob
I’ve allready talked with Menkins in Cali and he’s going to set me up with a prop and tell me what gears to run
But will be next years project I’m tapped out for this year
Blownbillybob
Little update on the trans!!
WORKS KILLER!!!
Can feel a harder hit from drive threw neutral to reverse
That regulator spring pumped up the pressure????
Still has some drag on the clutches in neutral but not as bad as before I hope it will get a little better as everything breaks in
lenmann
Nice and congrats on making summer!
What is that place that you can back your toy hauler up to the beach where you anchor your boat?
Blownbillybob
Lake Ber
Lake Berryessa. Putah Creak resort
Nor-Cal
Check out Berryessa Hot Boats on FB having there first hot boat bash at end of month. Back in the day it was every Easter !!!
sintax
nice! glad you were able to get it wet.
vdcruiser
So what prop are you running, and have you had a chance to step on it yet ?
RogerThat99
Parker Is Now OPEN
Bill it was great to meet you again at Berryessa. The boat looked and sounded killer. It was so rough, you were showing a lot of fin. [emoji106][emoji106] We will have to meet up on the Delta sometime.
Blownbillybob
Same prop that was on it
It’s stopping the engine at 5500 rpm so jus waiting for some funds to show up and will be getting a new 1 from Menkins
Blownbillybob
Yes!! Nice shooting the crap!!!
Tryin to make Dog&Andys in a few weeks hope to see u there!!!
Blownbillybob
Pop goes the rocker arm
And these are Crowers???
Time for some shaft mounts!!!
vdcruiser
Damn on the rocker arm. I just got a new set of Crower steel shaft rockers, hope they are better than that.
