morning wood
- Sep 22, 2014
- 8
- 0
1979 Performance 19
PJB hull ID prefix
Have titles and valid registration with current stickers and new plate
Trailer rolls good on the freeway, lights work with flat adapter, brand new tires, bearing buddies
Stringers and floor and bulkhead and 1/3 completed cap job are funky
Has a little hole in the hull on the bottom as if there was a turning fin or something?
Original gel is the coolest I've seen on one of these boats.
Silver metal flake surrounding the dark blue, there are red pinstripes on the deck and even some light blue ones in the middle of the dark blue in spots.
Seems like it would take to a buffer, same with the trailer.
The interior vinyl is serviceable, wood is completely (100%) shot, foam seems OK
Could cut new wood for existing material and be on the water in short order....
I have two spun aluminum fuel tanks with mounts, OG fuel fills are intact, chrome ski pull, engine mounts for BBC, Glenwood plates, adapters and Hardin exhaust logs as were originally installed.
Berkeley transom plate and JC pump (minus bowl)
Reduced to $3200.00
The boat is in Tehachapi
Please call or text me directly
Thank you
Mark
805.705.8405
May trade toward clean, late model open bow jet only or enclosed 20' trailer, no VW powered trikes please.
TX19 TX-19 Youngblood Gullwing Performance California Performance Performance 19 Earl Smith jet boat Berkeley big block race boat hot boat drag boat
PJB hull ID prefix
Reduced to $3200.00
Thank you
Mark
805.705.8405
