WTB / Mercury 20" outboard driveshaft
ONE-A-DAY
Anyone have an old outboard lower unit from a mercury 2.0, 2.4 or 2.5 liter laying around that has a decent 20" drive shaft in it?
Walt 661-373-0791
Outdrive1
Yes. lol.
I might just have a couple 2.4 lowers (1 lost forward and haven't opened it up yet) at Nacimiento if can find what you need.
ONE-A-DAY
Checking to see if od's is the same as my sportmaster, as guess cle's had two different types, one will work one won't, the older cle with single row bearing won't work, the newer cle has dual row bearings and should be the same as a sportmaster, or so they say
ONE-A-DAY
Somebody messaged me that had one in Huntington Beach, can't find the message anymore, looking to pick it up this week.
STV_Keith
There's a single bearing and dual bearing. The later style has dual bearings, one to take load under acceleration, when the pinion is pushing up on the bearing, and one to take load during decel, when the shaft pushes back down. You can run a dual bearing in an earlier case, with a spacer Merc makes. If you need the dual bearing style, only a dual bearing DS will work.
If you haven't found one, did you try Kevin @ R&R?
