jetboatperformance
- Jan 1, 2008
- 8,409
- 18,086
Atascadero water sucks balls , we dont drink it except via the filtered water at the Fridge any suggestions as to a simple in line set up ?
My wife will only drink out of our Royal Berkey with fluoride filters. Loves it. It’s great for natural disasters as well.You looking for drinking water? Get one of these... I thought my wife was nuts, but it proved me wrong. Other filtered water tastes like crap, especially the fridge
We have the royal as well and even take it in the trailer. Works well for the pirate cove camping water. I did think my wife was nuts for getting it, but had to eat my words.My wife will only drink out of our Royal Berkey with fluoride filters. Loves it. It’s great for natural disasters as well.
We have the Water Boy system as well and it seems to work great. It backflushes itself and no maintenance. We've probably had ours for 7 or 8 years now. Had them out last year to test everything & all is still good.I have a whole house water system by Water Boy. There are other similar/same systems out there. But this greatly improved the water taste, my fridge filter can go 3 times as longer before changing. I see very little calcium on the faucet and shower heads. This is not a soft water system, but it does reduce the hard water spots on the shower & faucets. Also I put a new water heater in at the same time as the whole house filter system, and I’ve notice allot less sediment in the water heater when I drained it.
The only thing that is different about these chamber tank filters is they do a weekly backflush to clean the filters and make them last longer. It’s suggested to tie the backflush into your plants, so not to waste the water, but in my case that was not an option, so my flush just goes down a drain.
Also something to think about is your outside hose bibs. If they are on the side of the house, then your hose bib water is going through your filter. I don’t use the two hose bibs on the walls of the houses because of this. But I did run multiple hose bibs off the irrigation line, which is before the water comes into the house.
Depending on the size of system you get the filter tank can last 7-10 years before needing to be changed. I chose to go one size bigger then what was spec’ed for my size home, number of people in the home and past water usage. It was not a whole lot more money, but in theory the filter should last much longer.
